Volkswagen Problems! - Page 4
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 61 to 80 of 81
  1. #61
    Model:Amarok
    Year:2015
    Mileage:40000
    Problem: Turning left then the vehicle will drop 300 rpm - every time
    Cause of problem(if known): According to vw a gearbox issue
    Specifics of repair work carried out: Bulletin out and their words "live with it"??
    Cost of repair: Not sure
    Who did the repair: N/A
    Vehicle under warranty, Y/N: Y
    Was damage covered by warranty: N/A too early to say
  2. #62
    May 2010
    Model: Polo 1.4 Comfortline Sedan
    Year: 2014
    Mileage: 14,500
    Problem: Massive brake judder.
    Cause of problem(if known): Front brake discs warped.
    Specifics of repair work carried out: Replace with new discs and pads (not done yet - see below).
    Cost of repair: R3,500.00
    Who did the repair: Tavcor William Moffett was supposed to do it, but at R3,500.00 for discs that will just warp again, I will rather get better aftermarket discs and pads and install those myself.
    Was damage covered by warranty: No. Brake discs are apparently only covered for 1 year/10,000km.
    As a side note, our previous 2011 Polo hatch had exactly the same problem. Front discs replaced twice in under 30,000km. First time they were replaced at 16,000km under warranty (WTF?), second time was for our account. VW is apparently aware of the brake issue on the Polo. The replacement discs on our first Polo were "upgraded". Lasted for about 6,000km before warping again. So between 2 Polos and in less than a combined 45,000km we've destroyed 3 sets of discs!
    During the same period we did 56,000km in our Amarok, and 30,000km in our Passat, so driving style and maintenance, IHMO, does not play a role in this. It's a 1400 Polo for crying out loud. We sold our Mazda Midge at 146,000km with it's original non-ventilated discs!
  3. #63
    Thanked: 2573
    Model: Amarok Auto 4motion
    Year: 2014
    Mileage: 30,000
    Problem: Park Distance Control just stopped working
    Cause of problem(if known): Faulty wiring
    Specifics of repair work carried out: Replaced sensor and wire
    Cost of repair: 0
    Who did the repair: Zimmerman
    Was damage covered by warranty: Y
    VW Touareg V6 Tdi Escape
    Bush Lapa Boskriek 816
  4. #64
    Springs
    Thanked: 20
    Default Re: Volkswagen Problems!
    Year: 2014
    Mileage: 39,000
    Problem: Sweating rear diff,
    Cause of problem(if known): Pinion shaft seal sweating
    Specifics of repair work carried out: Replaced seal and all associated service items under warranty
    Who did the repair: VW Springs
  5. #65
    Sep 2013
    Thanked: 17
    Model:Amarok 132kw
    Year: 2013
    Mileage: 56xxx
    Problem:Drivers door lock faulty,locks and opens up intermittently.
    Cause of problem(if known): No idea
    Specifics of repair work carried out:Replaced with new lock
    Cost of repair: 0
    Who did the repair: VW Tavcor
  6. #66
    Mosselbaai
    Thanked: 88
    Model: VW T5 2.0 BiTdi 4Motion
    Year:2011
    Mileage: 166000
    Problem: rattling noise from gearbox, only when vehicle is in P and moved to R or D. Sounds like metal plates rattling
    Cause of problem(if known): Dual Mass Flywheel
    Specifics of repair work carried out:Replace DMF
    Cost of repair: Parts R9500 Labour R7000
    Who did the repair:VW Mosselbaai
    No money for a real 4x4 so I pimped my
    2011 Volkswagen Transporter 2.0 BiTdi 132kw 4Motion DSG
  7. #67
    Jun 2016
    Secunda
    Thanked: 11
    Model: VW Amarok 2.0 TSi
    Year: 2012
    Mileage:108000km
    Problem: timing chain tensioner failure
    Cause of problem(if known): Design flaw
    Specifics of repair work carried out: Part replacement
    Cost of repair: R5800
    Who did the repair: VW garage
    Vehicle under warranty, Y/N: Extended warranty Y
  8. The Following User Says Thank You to Ratelrooi For This Useful Post:
  9. #68
    May 2008
    Krugersdorp
    Thanked: 76
    Model: Golf GTI DSG
    Year: 2014
    Mileage: 45k
    Problem: Boots spoiler and side beadings lose (for second time)
    Cause of problem(if known): Bad double sided tape and clips
    Specifics of repair work carried out: Remove and replace
    Cost of repair:
    Who did the repair: VW dealership
    Was damage covered by warranty: It better be...
    Edit: VW says the boot spoiler was torn out of the clips (we were hanging on the spoiler) and we need to take to a panelbeater at own cost. SWAMBO is livid and says she's trading the car in on a Corrolla.
    Toyota Corolla 1.8 Exclusive CVT - My platkar
    Toyota Fortuner GD6 2.8 Auto 4x4 - (SWAMBO's taxi)
    Honda NC700x Silver - Saving the budget
  10. #69
    Nov 2014
    Kloof, Durban
    Thanked: 21
    Model: VW Polo Vivo 1.6CL
    Year: 2015
    Mileage: 5K-8500KM
    Problem: Noise from the front
    Cause of problem(if known): "Apparently" faulty engine mounts
    Specifics of repair work carried out: Remove and replace engine mount bolts and apply a paste of sorts
    Cost of repair: Warranty
    Was damage covered by warranty: Yes
    2015 Suzuki Jimny 1.3 Manual
    2007 Subaru Forester XT (SOLD)
    2015 VW Polo Vivo 1.6 Comfortline (SOLD)
    2006 Toyota Corolla 140i (SOLD)
  11. #70
    Aug 2016
    I think I have the same issue with my amarok, except it's the ESP and seatbelt lights.
    Vehicle has been to 3 separate workshops all of whom weren't able to fix the problem. I don't suppose you know a specialist in PTA who can help me?
    Lastly, was your Rok able to engage "off road" mode whilst having this problem?
    Model: Amarok TDI 90kw 4x2
    Year: 2011
    Mileage: 57000
    Problem: ABS and ESP Lights on instrument cluster light up
    Cause of problem(if known): Left rear ABS sensor wire broken inside wiring harness
    Specifics of repair work carried out: Replaced ABS sensor (Didn't solve problem) Fixed the wire inside the harness
    Cost of repair: N/A
    Who did the repair: Alan Hudson Nelspruit
    Was damage covered by warranty: Yes[/QUOTE]
  12. #71
    Jan 2016
    Groot Gat
    Thanked: 29
    Model: Amarok 120kw bitdi 4motion
    Year: 2010
    Mileage: 122000km
    Problem: Sounds like boost leak when driven hard for long period or when towing heavy trailer
    Cause of problem(if known): Pipe between Exhaust manifold and EGR cooler cracked
    Specifics of repair work carried out: Replaced small bend pipe and gaskets
    Cost of repair: R1010.00
    Who did the repair: Myself
    '10 Vw Amarok 2.0 BiTdi D/C 4trek
    Mikem Suspension Lift
  13. #72
    Groblersbrug grenspos
    Thanked: 13
    Model:VW T5 Crewbus 2.0 BiTdi 4 motion
    Year:2013
    Mileage:105000km and 111000km
    Problem1)105000km Rattling sound from gearbox when shifting from P to R or d.
    Problem2)111000km bad clack sound on left front wheel when turning.
    Cause of problem1) Dual mass flywheel (2)Teared CV boot cause CV damage
    Specifics of repair work carried out1)Relaced DMF (2) replaced CV boot as well as Cv
    Cost of repair1) paid R5000.00 for part of labour only.VW SA paid the parts as well as half of labour thanks to Lannie VW in Tzaneen.(2)R 9000.00
    Vehicle under warranty.In both cases N
    Was damage covered under warrenty1)Vehicle was out of warranty but VW SA paid for the repair.(2)N
  14. #73
    Feb 2007
    Thanked: 25
    Model: Touareg V6 TDI (BKS)
    Year:2008
    Mileage: 189000
    Problem: Horrible grinding noise when driving made even worse when turning left or right
    Cause of problem(if known): Front wheel bearings
    Specifics of repair work carried out: Right hand side bearing was pressed out and replaced. Left hand side bearing, bearing carrier and hub was replaced
    Cost of repair: Right hand side R2500, Left hand side R5500
    Who did the repair: Tim (Right hand side), VagSpecCentre (Left hand side)
    Vehicle under warranty, Y/N: Aftermarket warranty
    Was damage covered by warranty: Right hand side was on my own account, but the left hand side was paid for by Aftermarket warranty
    2008 VW Touareg 3.0 V6 Tdi
    White, Steel Suspension, BKS engine
  15. The Following User Says Thank You to cor1903 For This Useful Post:
  16. #74
    Thanked: 840
    Default Volkswagen Problems!
    Mode: amarock D.C. 90kw
    Year: 2011
    Milage: 225 000
    Problem: aircon - apparently a common problem based on how quick they diagnosed it and how quickly they gave me a quote.
    Basically 16k for a new compressor, condenser and some other bits. They say the alt has a bearing that gives up and that causes the ac to pack up.
    My concern is that I had the pulleys and fan belt replaced at the last service and there are new marks in the engine bay that make me think the buffoons were using a pry bar instead of the correct tool. It could be coincidence, but I am thinking this may have influenced the bearing failure.
  17. The Following User Says Thank You to stephenplumb For This Useful Post:
  18. #75
    Thanked: 840
    Year: 2011
    Milage: 225 000
    Problem: Sunnies holder on the roof seems to have failed while we were in Kruger last week. It seems like the wagon is stating to come apart at the seams? Bleak!
  19. #76
    Aug 2014
    Gauteng
    Arrow Re: Volkswagen Problems!
    Model: VW Amarok 3.0TDi Highline +
    Year: 2017
    Mileage: 1000km
    Problem: Vehicle wouldn't start
    Cause of problem(if known): Loose earth strap
    Specifics of repair work carried out: Earth strap properly fastened
    Cost of repair: N/A
    Who did the repair: VW Menlyn
    Vehicle under warranty, Y/N: Yes
  20. #77
    Jul 2013
    Secunda
    Model: VW Amarok Highline+ 4Motion Auto DC
    Year: 2017
    Mileage: 206 km
    Problem: Whistling noise coming from front left air vent when traveling above 100km/h. Noise especially pronounced when aircon on recirculation.
    Cause of Problem:
    Suspected poor seal on factor fitted windscreen
    Specifics of Repair work:
    Remove and re-fit windscreen.
    Cost of Repair:
    free
    Who did the repair:
    Tri-Sec Autohaus Secunda
    Vehicle under warranty (Y/N):
    Y
    Damages covered by Warranty:
    N/A
    Problem solved. Only noise now is wind noise from general vehicle design.
  21. #78
    Thanked: 100
    Model:Amarok 132kw
    Year: 2014
    Mileage: 71xxx
    Problem: Rear door lock faulty,locks intermittently.
    Specifics of repair work carried out: None yet
    Cost of repair: 0
    Who did the repair:
    Darryn Van Rooyen
    2014 D/C Amarok 4Motion H/L Auto - 76mm Decat Downpipe and Revo Stage 1 Tune
    Current: 1987 Citi Sport 1.6
  22. #79
    Oct 2012
    otjiwarongo
    Thanked: 119
    Model: Amarok 132kw
    Year: 2017
    Mileage: 30850
    Problem: Wiper motor made a noise.
    Cause of problem(if known): VW say dust and water got into it
    Specifics of repair work carried out: Replace wiper motor
    Cost of repair: 0
    2017 VW Amarok BiTDi 4Motion D/Cab
    2020 VW T Cross Highline R Line
    2019 Bushlapa Miskruier 1616
  23. #80
    Thanked: 43
    Model:Amarok 120kw
    Year:
    2010
    Mileage:
    329 000 km
    Problem:
    Vibration felt throughout vehicle similar to unbalanced wheel
    Cause of problem(if known): After multiple attempts to solve, it ended up being tired upper control arm bushes
    Specifics of repair work carried out: Replaced upper control arm bushes. Bushes need to be pressed out and in.
    Cost of repair: Parts R 400 (for 4 bushes) at GW. Labour to fit around R 700.
    Who did the repair: Quickfit
  24. The Following User Says Thank You to idea40 For This Useful Post:
  1. Land Rover Problems!
    By Barto in forum Land Rover
    Last Post: 2019/07/15, 02:35 PM
  2. Hyundai Problems!
    By Barto in forum Hyundai
    Last Post: 2016/08/08, 01:49 PM
  3. Conqueror Companion: Dream becomes nightmare
    By Alta in forum Camping, Fridges, Accessories
    Last Post: 2012/10/21, 09:54 PM
  4. Discovery 3 CD and Cruise Control problems (incl. bad experience with dealer)
    By ReadySteadyGo in forum Land Rover
    Last Post: 2011/11/09, 07:40 AM
  5. Volkswagen T5 Double Cab Problems
    By Talla in forum Volkswagen
    Last Post: 2011/09/13, 04:24 PM
