Volkswagen Problems! - Page 3
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 41 to 60 of 81
  1. #41
    Mosselbaai
    Thanked: 88
    Angry
    Model: Transporter 2.0 Bitdi 4Motion
    Year:2011
    Mileage:110000
    Problem: Oil Leak
    Cause of problem(if known): Wear & Tear
    Specifics of repair work carried out:Camshaft seal,Crankshaft seal, tappet cover seal, Injector Seals, New timing belt and waterpump + Service
    Cost of repair: Labour R5400, Parts R9234
    Who did the repair: VW Mosselbaai
    Vehicle under warranty, Y/N:N
    Was damage covered by warranty:N
    No money for a real 4x4 so I pimped my
    2011 Volkswagen Transporter 2.0 BiTdi 132kw 4Motion DSG
  2. #42
    Thanked: 18
    Model: Amarok BiTDI D/C Auto (132kw)
    Year: 2014
    Mileage: 20 000km
    Problem: Airbag warning light came on
    Cause of problem(if known): Faulty hooter ring (according to dealer)
    Specifics of repair work carried out: Replaced hooter ring
    Cost of repair: not sure
    Who did the repair: Autohaus Windhoek
    Vehicle under warranty, Y/N: Y
    Was damage covered by warranty: Y
    2014 Amarok DC 4Motion Auto
    Conqueror Conquest
  3. #43
    Mosselbaai
    Thanked: 88
    Angry Erg
    Model: VW T5 2.0 BiTdi 4Motion
    Year:2011
    Mileage:116500
    Problem:Engine & Glowplug light came on Vehicle in limp mode
    Cause of problem(if known):EGR
    Specifics of repair work carried out:Replace EGR
    Cost of repair:Parts R12917.34 Labour R2083
    Who did the repair:VW Mosselbaai
    Was damage covered by warranty: N
    __________________
  4. #44
    Sep 2014
    Model: VW Amarok BiTDI 4 Motion DC
    Year: 2011
    Mileage: 65 000 km
    Problem 1: Cambelt broke
    Problem 2 : Next day after repair on 1 - Blown Turbo
    Cause of problem 1: Broken fan belt
    Cause of problem 2: Propably ,made on a Friday afternoon before a long weekend
    Specifics of repair work carried : replaced valves, cam etc... Replace Turbo
    Cost of repair: Waiting for the Bill --- All together +/- R 80 000
    Who did the repair: VW Autohouse (Swakop & Windhoek)
    2011, VW Amarok (120kw) BiTDi 4 Motion
    2014, Suzuki Jimney 4x4
    (ex) Toyota Fortuner 3D4D
    (ex) Mitsubishi Triton 3.6 4x4
  5. #45
    Sep 2013
    Thanked: 17
    Model:Amarok 132kw
    Year: 2013
    Mileage: 31xxx
    Problem:Left rear door lock faulty,opens up intermittently.
    Cause of problem(if known): No idea
    Specifics of repair work carried out:Replaced with new lock
    Cost of repair: 0
    Who did the repair: VW Tavcor
  6. #46
    Sep 2013
    Thanked: 17
    Model:Amarok 132kw
    Year: 2013
    Mileage: 32xxx
    Problem:Window washer bottle leaking
    Specifics of repair work carried out:Replaced with new washer bottle
    Cost of repair: 0
  7. #47
    Aug 2010
    Default Volkswagen Problems!
    Model:Transporter
    Year: 2013
    Mileage: 92000
    Problem:Key hinge broke
    Cause of problem(if known): wall thickness of hinge where roll pin hole is drilled through the material. This is the second of my keys to break in the same place.
    Specifics of repair work carried :to be replaced at my expense
    Cost of repair: R2000
    Who did the repair: no work required
    2006 T5 4Motion 174HP TDI Seikel Dakar STOLEN IN KALK BAY
    2013 T5 4Motion 180HP TDI Seikel Desert HD Wearing bush stripes with pride
    A6 3.0 Multitronic 225HP
  8. #48
    Evander
    Exclamation Volkswagen Transporter 2.5 TDI
    Model: Transporter Crewbus 2.5 TDI 128 kW
    Year: 2007
    Mileage: 120000
    Problem: 1.My crewbus loses power while driving and then i have to stop switch off and then start again?. 2 The gearbox oil started to boil the one time while i was pulling my exclusive caravan but we had a nose wind that was pounding. I took it for a service and asked the VW guys to have a look, but when i got my bus back they said nothing was wrong. Well the weekend past now i came back from Margate and was driving hard when i got to Standerton the oil Was boiling again?
    Cause of problem(if known): ??
    Cost of repair:
    Who did the repair:
  9. #49
    Thanked: 11
    Default Amarok 120kw
    Model: VW Amarok BiTDI 4 Motion DC 120kw Manual
    Year: 2011
    Mileage: 42827km
    Problem: Clutch shudder
    Cause of problem(if known): Clutch & Flywheel
    Specifics of repair work carried out: Replaced Flywheel & Clutch Kit
    Cost of repair: n/a
    Who did the repair: VW menlyn
    2014 AutoAmaRock
    RSI Signature Canopy
    Pirelli Scorpion ATR 265/70 R17
  10. #50
    Thanked: 11
    Default VW Amarok 132kw DC 4 Motion Auto
    Model: VW Amarok 132kw DC 4 Motion Auto
    Year: 2014
    Mileage: 38000km
    Problem: Central locking malfunction
    Cause of problem(if known): Faulty lock
    Specifics of repair work carried out: Replaced left front door lock
    Cost of repair: n/a
    Who did the repair: VW Silveroaks
    Last edited by RiaanR; 2015/05/17 at 07:26 PM. Reason: Suspension squeak removed as repairs was not needed and did not resolve the issue. Leaf spring rubbing against leaf bracket.
    2014 AutoAmaRock
  11. #51
    Jun 2015
    ellisras
    Exclamation
    Model:VW Transporter 4 motion 2.0 l
    Year:2012
    Mileage:59000 km
    Problem:front shocks with extended reach( I have lifted it)
    Cause of problem(if known):shock broken
    Cost of repair:
    Who did the repair:
    Vehicle under warranty, Y/N:Y
    Was damage covered by warranty:?
  12. #52
    Sep 2013
    Thanked: 17
    Model:Amarok 132kw
    Year: 2013
    Mileage: 40xxx
    Problem:Left front door lock faulty,opens up intermittently.
    Cost of repair: 0
  13. #53
    Feb 2007
    Thanked: 25
    Model: Touareg 3.0 v6 Tdi
    Year: 2008
    Mileage: 150 000
    Problem: Main seal oil leak
    Cause of problem(if known): Age?
    Specifics of repair work carried out: Replaced main seal and timing cover seal
    Cost of repair: 0
    Who did the repair: Audi Rivonia
    Vehicle under warranty, Y/N: No
    Was damage covered by warranty: CPA
    2008 VW Touareg 3.0 V6 Tdi
    White, Steel Suspension, BKS engine
  14. #54
    Sep 2013
    Model: Scirocco 1.4 Tsi
    Year: 2009
    Mileage: 86000km
    Problem: Piston 3 no compression and misfire
    Specifics of repair work carried out: None. Traded immediately at reasonable price
    Cost of repair: R20600
  15. #55
    Thanked: 984
    Model:Amarok 132kw
    Year: 2013
    Mileage: 53000
    Problem:Noisy in the morning- Diesel knock
    Cause of problem(if known): Faulty injector
    Specifics of repair work carried out:Replaced all 4 injectors
    Cost of repair: 0
    Who did the repair: Unitrans
    Good service like usual.
    [email protected]
    +27824453301
  16. #56
    Nov 2012
    Newcastle
    Thanked: 27
    Quote Originally Posted by RolfB View Post
    Model: Amarok DC Trendline 90 Kw
    Year: 2011
    Mileage: 124000 Km
    Problem: Diff lock switch not working properly. When I push the button the light on the dash only flashes. Can not engage diff lock. Light also starts flashing on its own after driving app 450Km and goes off as soon as vehicle has cooled down ie overnight. Does not come on normal city to city driving.
    Cause of problem(if known): Not known, probable defective sensor according to VW. Diff lock unit will have to be replaced.
    Specifics of repair work carried out: Not repaired. VW accepts no responsibility and no goodwill. Solely my problem.
    Cost of repair: App R11000
    Who did the repair: Not yet done, still fighting with VW as diff lock never used.
    Vehicle under warranty: N
    I am quite sure the user manual asks you to engage the difflock every 2 months. It becomes sticky. Same story with previus isuzu and ranger
    2001 ISUZU KB 280 DT 4X4 LX (WIT WILLEM) - sold
    1990 WV JETTA-sold
    2004 MERC C180 will never sell
    2011 Amatrok BiTdi
  17. #57
    Vanderbijlpark
    Thanked: 713
    Quote Originally Posted by Bakkies View Post
    Never read about that anywhere, but will go and see if it is indeed the case.
  18. #58
    Default Amarok 132 auto 4 motion
    Model:Amarok
    Year:2015
    Mileage:40000
    Problem: Turning left then the vehicle will drop 300 rpm - every time
    Cause of problem(if known): According to vw a gearbox issue
    Specifics of repair work carried out: Bulletin out and their words "live with it"??
    Cost of repair: Not sure
    Who did the repair: N/A
    Was damage covered by warranty: N/A too early to say
    __________________
  19. #59
    Model:Amarok 132kw 4 motion DC
    Year: 2015
    Mileage: 40000
    Problem: Radio reception terrible
    Cause of problem(if known): Not sure - again according to VW a bulletin is out so no action taken - "live with it"
    Specifics of repair work carried out: Nothing done, Menlyn VW would have replaced it with one from a demo model and still waiting for them to come and do it......
    Cost of repair: N/A
    Was damage covered by warranty: Hopefully
    _
    _Model:Amarok 132kw 4 motion DC
    Year: 2015
    Mileage: 40000
    Problem: Ignition - key loose
    Cause of problem(if known): Not sure - again according to VW this is the way it must be? If I get out of the vehicle it will not lock, I have to go back insert the key switch on - off, then the radio switches off and I can lock the vehicle.
    Specifics of repair work carried out: Nothing done, Menlyn VW.
    Cost of repair: N/A
    Was damage covered by warranty: Hopefully__
    Model: Amarok 132kw 4 motion DC
    Year: 2015
    Mileage: 40000
    Problem: Purchased Nudge bar when I bought the vehicle in Jan 15
    Cause of problem(if known): Not fitted and not supplied yet - Just promises from the dealer - VW Menlyn.
    Cost of repair: N/A
    Was damage covered by warranty: Paid by me in full - not a warranty item.____
    Year: 2015
    Mileage: 40000
    Problem: Front seat reclining automatically, every time have to adjust - Left seat noisy.
    Cause of problem(if known): Dealer think I am not serious - VW Menlyn.
    Cost of repair: N/A
    Was damage covered by warranty: Paid by me in full - not a warranty item.________________________
  20. #60
    Default vw Problems
    Model:Amarok 132kw auto 4motion DC
    Year:2015
    Mileage:40000
  1. Land Rover Problems!
    By Barto in forum Land Rover
    Last Post: 2019/07/15, 02:35 PM
  2. Hyundai Problems!
    By Barto in forum Hyundai
    Last Post: 2016/08/08, 01:49 PM
  3. Conqueror Companion: Dream becomes nightmare
    By Alta in forum Camping, Fridges, Accessories
    Last Post: 2012/10/21, 09:54 PM
  4. Discovery 3 CD and Cruise Control problems (incl. bad experience with dealer)
    By ReadySteadyGo in forum Land Rover
    Last Post: 2011/11/09, 07:40 AM
  5. Volkswagen T5 Double Cab Problems
    By Talla in forum Volkswagen
    Last Post: 2011/09/13, 04:24 PM
