Driving the northern side of the okavango panhandle
Results 1 to 4 of 4
    Thanked: 9
    Default Driving the northern side of the okavango panhandle
    Is it possible to drive along the northern side of the panhandle from Chobe NP to Mbiroba and then to Mohembo Border crossing during December
    Gaborone
    Thanked: 957
    Default Re: Driving the northern side of the okavango panhandle
    There are tracks / routes but they are going through concessions.
    Then December being the rainy season, a lot of the area will (or can be) flooded.
    There is no rescue in place for the area, most likely you couldn't even expect someone to come and assist f you would run into troubles. It is just to far off the normal routes and if tracks are used then by the army trucks or concession operators.
    BTW, I tried to do a crossing from Khwai to Linyanti through that area in June 2015 - and failed as we hit large areas of water where we never even expected it.
    Kalahari Safari
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
  3. The Following User Says Thank You to Kalahari Safari For This Useful Post:
    Thanked: 9
    Quote Originally Posted by Kalahari Safari View Post
    Soo there are routes through that area :? would tracks for africa have them?
    Thanked: 9
    What about the route to Ngoma through chobe?
    Would that be possible in December?
