Conqueror Companion A-Frame Failure!! - Page 7
Page 7 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 121 to 140 of 166
  1. #121
    Thanked: 205
    Default Re: Conqueror Companion A-Frame Failure!!
    Quote Originally Posted by Erwin Schimper View Post
    I have a few trailers. Build and desiged one myself. All for cargo. The Goudi trailer I bought in 2004. It is has a payload of 2ton it is double axle. This trailer has done 100 000km plus with a full load on tar and dirt loads with no problems. The A frame is 100mm x 50mm x 5m channel and has gusset plate were the trailer body meets the A frame. The one I build I use 100mm x 50mm x 3mm tube also with gusset plates. This is important as this is where the A frame has the biggest stress and bend.
    Yes the highest bending moment is at the location. The highest tensile stress is only at the outside face of the bottom flange. That face will suffer crack initiation if the stress is too high.
    To weld a gusset to the side of the beam or weld across the top face of the beam is acceptable because the maximum tensile stress doesn't occur there. (the top flange is in compression)
    Maybe someone who's worked with this more recently can advice, but on memory I think that one can allow 150MPa tensile stress to have infinite life for cyclic loading. Add a weld across the bottom flange and you don't allow more than 30MPa (nominal stress)! Add a hole and you probably rise the stress by a factor of two to three, forcing you to change your design so that you reduce the nominal stress to 50 or 75MPa.
    Currently enjoying my new platkar: Alfa MiTo Quadrifoglio Verde - she's a beauty!
    JKU Rubicon Pentastar
    JKU CRD (sold)
    XJ 4liter (sold )
  2. The Following 3 Users Say Thank You to Jeepiscool For This Useful Post:
  3. #122
    Sep 2015
    Jhb
    Thanked: 63
    Quote Originally Posted by Congo View Post
    Now my trusted insurance company have given me notice of cansellation of policy due to repeated claims on the Conquerors.
    Eish, fun times.
    In the meantime my replacement on the A-frame (the strong one) is going in to galvanizing today and should be all done by next week.
    Hi Congo I've heard from other people who have had this happen that it is best to see if you can ask them if you can cancel the insurance from your side rather - it is then much easier to get insurance the next time than if they had cancelled from their side. Don't know exactly why because your claims history is still the same, but apparently being cancelled by an insurer is a bad thing (worst case if there was non payment of premiums, but even cancellation for high claim to premium ratio is not a good thing).
  4. The Following 3 Users Say Thank You to tkk For This Useful Post:
  5. #123
    Okahandja, Windhoek
    Thanked: 759
    Quote Originally Posted by Jeepiscool View Post
    The problem is one dont know what design criteria did they use. Stresses will be much less than that for static loads if only 50kg on the towbar. There is probably a standard load, and load factor (x5 as you mentioned?) to increase the load for live loads (impacts) to use in the industry for such applications. Did they use that or not, if yes, then obviously there is somewhere an issue, which they don't want to address seemingly, and put the claim on abuse. Up to know it seemingly don't hurt them.
    Johan Kriel
    LCs, Hilux and Echo Chobe
  6. #124
    May 2016
    Thanked: 2800
    Regardless of the load, you don't put a hole in the bottom (stressed) flange of a 'box' element!
    2006 VW Touareg V10 TDi
  7. The Following User Says Thank You to 4eTouareg For This Useful Post:
  8. #125
    Okahandja, Windhoek
    Thanked: 759
    That also!
    Johan Kriel
  9. #126
    Brisbane
    Thanked: 282
    Your numbers are pretty much on the money for fillet welds.
  10. The Following User Says Thank You to BruceB For This Useful Post:
  11. #127
    Langebaan
    My 2017 Companion A frame is definitely reinforced in that area. On the bottom and inside the channel.
    Merlin van Zyl
    Isuzu KB300 D/C 4x4
    Nissan Pathfinder 2.5 Dci 4x4
    Conqueror Companion Platinum
  12. #128
    Sep 2010
    newcastle
    Thanked: 12
    Could you post a Photo Merlin. I would like to compare it to my older Companion.
  13. #129
    Langebaan
    Will do, as soon as I get it back from Conqueror.
    Merlin van Zyl
    Isuzu KB300 D/C 4x4
  14. #130
    Thanked: 24
    New A-Frame made and fitted.
    We used 100 x 50 x 5mm rectangular tubing, the area under the cross member was reinforced by a oval fish plate. To this plate we mounted brackets that attached the body.
    Standard compression pipes were fitted where needed.
    I do believe that this will last for a trip or 2.......
ID:	450233   Click image for larger version.
ID:	450234   Click image for larger version.
ID:	450235   Click image for larger version.
    Land Rover is not a vehicle it is a cult!
    Gas Gas 300 with training wheels.
  15. #131
    Thanked: 24
    Quote Originally Posted by Merlin4WP View Post
    Kindly post some photo's would love to see
  16. #132
    Thanked: 24
    These are a pic or 2 of the hole on the frames that we did emergency repairs on
ID:	450237   Click image for larger version.
ID:	450238   Click image for larger version.
  17. #133
    Jun 2017
    Livingstone
    [QUOTE=DCTheron;3583709]
    "Even though I did my best to avoid any damage to the A-frame, I was constantly aware of the weakness and had a brand new A-frame lying in my garage just in case. (I still need to get rid of it)."
    Hi Theron. I just bought a second hand Companion, and after reading this thread I checked it and found it to be cracked on the A frame exactly where the others have found the cracks. Im looking to replace the A frame and would be interested in the one you are looking to get rid of, if its available? What would be the best way to contact you?
  18. #134
    Jun 2017
    Livingstone
    Quote Originally Posted by DCTheron View Post
  19. #135
    Thanked: 24
    Why would you wan't to replace an A-frame that clearly has cracks as stated with the same design? They have not changed anything.....
  20. #136
    Oct 2008
    Thanked: 269
    Did you remember to drill the holes the same as Conquerors design
    (sorry, just a tongue in cheek reply)
    Mitsubishi Triton 3.2 DI-D 4x4
    BL925 - Ratel 4
  21. #137
    Thanked: 24
    Talking Re: Conqueror Companion A-Frame Failure!!
    Quote Originally Posted by Charlie100 View Post
    LOL......yep. Actually only attached it with Silicon and 5 rivits like the rest of the body.....
  22. #138
    Langebaan
    Here are the pics of the reinforcement.
ID:	451579   Click image for larger version.
    Merlin van Zyl
    Isuzu KB300 D/C 4x4
  23. The Following User Says Thank You to Merlin4WP For This Useful Post:
  24. #139
    Langebaan
    Seems they also added new holes!
    Merlin van Zyl
    Isuzu KB300 D/C 4x4
  25. The Following User Says Thank You to Merlin4WP For This Useful Post:
  26. #140
    Sep 2010
    newcastle
    Thanked: 12
    Thanks for the photo's. Is that not the "skid plate" Congo referred to in post 32 ?
  27. The Following User Says Thank You to gerrit fourie For This Useful Post:
