Conqueror Companion A-Frame Failure!! - Page 6
Page 6 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 101 to 120 of 166
  1. #101
    Langebaan
    Default Re: Conqueror Companion A-Frame Failure!!
    Deleted
    Merlin van Zyl
    Isuzu KB300 D/C 4x4
    Nissan Pathfinder 2.5 Dci 4x4
    Conqueror Companion Platinum
  2. #102
    Mar 2017
    Okahandja
    Thanked: 649
    I have a few trailers. Build and desiged one myself. All for cargo. The Goudi trailer I bought in 2004. It is has a payload of 2ton it is double axle. This trailer has done 100 000km plus with a full load on tar and dirt loads with no problems. The A frame is 100mm x 50mm x 5m channel and has gusset plate were the trailer body meets the A frame. The one I build I use 100mm x 50mm x 3mm tube also with gusset plates. This is important as this is where the A frame has the biggest stress and bend.
  3. #103
    Mar 2017
    Okahandja
    Thanked: 649
  4. #104
    Okahandja, Windhoek
    Thanked: 756
    Quote Originally Posted by Congo View Post
    No amount of computer simulation or FEM testing can ever compete with real time live field testing. No manufacturer will field test their product with the same level of disrespect as would some rental customers.
    The rental market provides invaluable information to manufacturars on items that might fail at zero cost to the manufacturor.
    How a specific manufacturor responds to a failure..... Well, that is where the differance lies.....some might chose to fix the issue and provide their clients with an improved product, some might chose to ignore the issue and some might choose to profit from supplying the parts to repair the failure that they were responsible for in the first place.......
    Agree. Best test is feedback from clients. If the safety- or live load factor used in the design was not adequate then you need to make modifications. Mostly a trail and error thing as live loads cannot necessarily predicted, its more of a type of standard used in the industry.
    How much must fail till you accepted there is a problem. I think one is enough to investigate and make modifications if required. It can be a very cheap modification as the stresses problem is limited to that point from where the A frame extents under the caravan/trailer body to the towbar.
    Johan Kriel
    LCs, Hilux and Echo Chobe
  5. #105
    Gaborone, Botswana
    Thanked: 989
    Most heavy caravans and trailers use this U-Channel for the A-Frame. It doesn't crack or break like rectangular tubing.
    76 x 38 x 6
    Kobus
    Nissan
  6. #106
    Thanked: 993
    If you subject any steel to extended periods of stress it will fail. So you can reduce structural failure by changing the design, material and thickness. Furthermore you can add stiffeners on high tensile spots to reduce metal fatigue. I have seen failures like that hundreds of times. I will be able to fix that problem easily. Just some steel and bit of effort
    Training: 4x4, bushmechanics, recovery, defensive, 4x4 trucks
    Angel Construction
    [email protected]
    +27824453301
  7. #107
    Thanked: 24
    Now my trusted insurance company have given me notice of cansellation of policy due to repeated claims on the Conquerors.
    Eish, fun times.
    In the meantime my replacement on the A-frame (the strong one) is going in to galvanizing today and should be all done by next week.
    Land Rover is not a vehicle it is a cult!
    Gas Gas 300 with training wheels.
  8. #108
    Jun 2012
    Klerksdorp
    Thanked: 64
    Not a good sign!
    2009 Toyota Fortuner 3.0 d-4d 4x2
    Custom off-road trailer with Echo TTT
  9. #109
    Thanked: 240
    What did you claim on the conquerors? Must be accident claims because no insurer will pay for mechanical breakdown.
    Francois
  10. #110
    Thanked: 24
    Quote Originally Posted by Francois111 View Post
    2 x recoveries from out of country, damage caused by a-frame failure......
  11. #111
    Thanked: 240
    And they cancel you because of 2 recoveries? That is a bit harsh!
    Francois
  12. #112
    Jun 2012
    Klerksdorp
    Thanked: 64
    Do you know if it is just yours or is it all their clients with conquerors?
  13. #113
    Thanked: 240
    No insurer will cancel you because you have a certain brand they will cancel you because of to much claims.
    Francois
  14. #114
    Oct 2006
    Thanked: 15
    Eish, fun times.
    On claims they are not willing to pay? Wow, that is worrisome.
    Regards.
  15. #115
    Thanked: 212
    Quote Originally Posted by konstanddp View Post
    my guess is the other companion owners will only find this out once they need the support..in the meantime, the insurance will gladly take the money every month, no question asked..
  16. #116
    Midrand Estates
    Thanked: 50
    Spoke to three insurance company's and have no issue with the Conqurorer brand but the problem is the number of claims from insuree .
    Once again would the same be applicable to (Toyota, VW, Ford, example) if Avis, Buget, Euro Car, came with a warranty claim on a rental 2010 model with + 150k km.
    How can you be old and wise
    if you were never young and wild
    2016 Ford Ranger 3.2 XLT 4X4 Auto
    2015 Ford Ranger 3.2 XLT Auto
    2015 Mini Countryman
    2016 Conqueror Companion 2B
  17. #117
    Brisbane
    Thanked: 282
    76 x 38 x 6
    You're joking...
  18. The Following User Says Thank You to BruceB For This Useful Post:
  19. #118
    Gaborone, Botswana
    Thanked: 989
    Quote Originally Posted by BruceB View Post
    You're joking...
    Why ?
    Kobus
    Nissan
  20. #119
    Thanked: 24
    Quote Originally Posted by Grant1 View Post
    Sorry but I'm confused here, what is the difference between Avis etc and a single owner coming up with a warranty claim on a chassis failure at the same age and mileage? Do manufacturers only build vehicles to last 2 years? Are you saying that multiple users are the issue? What about the second hand market then?
    Should the manufacturer then not clearly state that our product will only last for X years or y Botswana trips there after it will fail and we will charge you for the repairs?
    Really?
    Does not seem to be the message portraid in their advertising?
  21. #120
    Oct 2008
    Thanked: 265
    Kontak dalk die versekering ombudsman, hulle kan nie net kanselleer sonder n goeie rede nie.
    Die probleem is dat jy gaan sukkel om by n ander versekeraar geplaas te word omdat jou huidige mense jou kanselleer het
    Mitsubishi Triton 3.2 DI-D 4x4
    BL925 - Ratel 4
