Inflating 4 tyres at once - DIY Inflator
Results 1 to 5 of 5
    May 2013
    Thanked: 144
    Default Inflating 4 tyres at once - DIY Inflator
    So I made this recently There's a hand valve at each end so that you can close off each valve...this means that you equalize pressure between 2-4 tyres and also pump and deflate 1-4 tyres at once. I wouldn't use this to deflate tyres as there is a lot of pipe to unravel but it makes inflating easier as you inflate all 4 tyres at the same time.
    Another perk I discovered after making it is that the gauge doesn't go up to 4.5 bar like it used to when inflating just one tyre, it now sits close to the actual pressure. This means that I don't have to turn on and off compressor every 5 minutes to check the actual pressure.
ID:	447059   Click image for larger version.
ID:	447060   Click image for larger version.
ID:	447061   Click image for larger version.
ID:	447062   Click image for larger version.
ID:	447063   Click image for larger version.
ID:	447064   Click image for larger version.
ID:	447065   Click image for larger version.
ID:	447067   Click image for larger version.
ID:	447068   Click image for larger version.
  2. The Following 5 Users Say Thank You to tintin_85 For This Useful Post:
  3. #2
    May 2013
    Thanked: 144
    Default Re: Inflating 4 tyres at once - DIY Inflator
    In the third pic you can see the original brass valve connector that I removed, along with the black pipe that connects to the back of the gauge, and this is where I joined the new blue pipes.
    Fittings are 1/4" standard air fittings as well as 10mm push-in fittings. The push-in fittings are great as you remove sections at will. In the second last pic you can see a short blue pipe from the gauge to the T-piece fitting and I just disconnect that to make it easier to pack up and store away. Air pipe is rated at 10 Bar, so more than capable of doing the job.
    Another nice feature is that all fittings and pipe is modular and easily interchangeable. If I need to I can very easily replace any item.
    May 2013
    Thanked: 144
    All in all it cost about R1000 and I'm sure I could've got it a bit cheaper if I really had to shop around for parts but for convenience sake I bought everything from the same tyre-fittings distributor.
    Air pipes are long enough for my wheelbase but if I get something bigger one-day then I can just buy more air pipe nice and modular
    May 2013
    Thanked: 144
    Oh, and the last perk is that I don't have to stretch that yellow curly pipe all the way to the back tyre on the other side of the car...always feels like it's stretched too far
    Oos Transvaal / Laeveld
    Thanked: 153
    nice.
