ENGINE CODE P0382: Glow Plug/Heater Circuit "B"
Results 1 to 20 of 24
    Mar 2013
    Thanked: 13
    Default ENGINE CODE P0382: Glow Plug/Heater Circuit "B"
    Hi Guys
    Just had the engine light come on this morning. OBD2 code read. P0382: Glow Plug/Heater Circuit "B"
    Any idea where to look first. Fuse is ok. I suspect either relay or so.
    Could a fault glow plug also cause this code to come up.
    Engine is Hover 2.5 TCI. 117 000 kms on.
    Oppierotse
    Thanked: 262
    Default Re: ENGINE CODE P0382: Glow Plug/Heater Circuit "B"
    First test if there is power going to the glow plugs. If not then trace back to fuse and relay.
    If there is power then you must test the glow plugs individually. Remember that glow plugs that don't glow, will carbon up to such a extend that they stuck to the c/head and will brake off when you try to undo them.
    98 Hilux 2.8D D/C 4x4
    Mar 2013
    Thanked: 13
    So I've checked everything.
    Fuse OK
    Relay OK - replaced it with another relay and made not difference/
    Power to the glow plugs - OK.
    Only thing now is to replace the glow plugs.
    My question is if a faulty glow plug could bring up this error code still?
    Thanked: 1026
    With the gwm, you dont have to waste time.
    A glow plug error is a glow plug error.
    Get the gwm ones. The ones from autozone don't work well
    Jun 2016
    Thanked: 30
    Out of pure curiosity, what is the price of the glow plugs.
    And also, if the glow plug is faulty, would your car still start?
    Mar 2013
    Thanked: 13
    Quote Originally Posted by JDeere85 View Post
    Cast starts no problem, especially common rail diesels don't really have a problem in our SA weather.
    Its the older diesels that struggles to start in the cold without glow plugs.
    Mar 2013
    Thanked: 13
    R780 later (eeekkk!) and the glow plugs replaced. Issue sorted. Why did I not just do this first time around. Instead I went all complicated and looked at other causes first.
    Well issue sorted, engine light off and all ok.
  8. The Following 2 Users Say Thank You to Higgins77 For This Useful Post:
    Mar 2013
    Thanked: 13
    So after replacing the glow plugs the engine light stayed off...until today. It's back on again and with the exact same error code.
    Seems the new glow plugs only helped for a little while.
    Note these are the GWM glow plugs and not the Midas version.
    I'm at a loss now. Relay checked out fine. Fuse still ok, I cant find an issue on the wiring.
    Could it be that one of the glow plugs is a dud?
    Or is there somewhere esle I need to look?
    Thanked: 1026
    Quote Originally Posted by Higgins77 View Post
    Measure it. It shouls have a very low resistance.
    Alldays
    R780 later (eeekkk!) and the glow plugs replaced. Issue sorted. Why did I not just do this first time around. Instead I went all complicated and looked at other causes first.Well issue sorted, engine light off and all ok.
    Higgins where did you get the glow plugs from? Dealers are quoting me R323 excl vat each and the other places can't find a ngk equivalent. MPD for some reason quoted more than the dealers, but no stock
    Mar 2013
    Thanked: 13
    Quote Originally Posted by Gustav14 View Post
    Got them from MPD in Roodepoort. Was R780 for all 4. Had stock. No issues.
    No code has to be inserted here.
    Oct 2017
    Vereeniging
    Hi guys. I have the same problem on my 2.8tci. replaced glow plugs reseted the computer but yet the engine light comes on.
    Mar 2013
    Thanked: 13
    Quote Originally Posted by floris91eloff View Post
    Are you using the GWM glow plugs or the ones you get from Midas/ Autozone. You must use the GWM ones as the computer doesn't like the ones you get from Midas/Autozone
    Have you checked the glow plug relay? Test it by swapping it out with one of the other same relays and see if the engine light still comes on.
    Either that or a wire to one of the glow plugs has a loose connection.
  15. #14
    Oct 2017
    Vereeniging
    Gwm plugs. Where does the glowplug relay sits? Next to the batery or is it a small box at the firewall? I hear it clicks near the firewall next to the 4x4 booster
  16. #15
    Mar 2013
    Thanked: 13
    If the same as mine, it should be in the fuse box next to the battery.
  17. #16
    Mar 2013
    Thanked: 13
    So the Glow Plug/Heater Circuit B error code is back on again. Glow Plugs only 5 moths old. I cant think that the glow plugs could give problems again.
    I am now at a loss as to what the problem could be.
    What is have checked.
    - replaced relay.
    - replaced fuse.
    - tested and there is low resistance on all 4 glow plugs meaning that they should all be fine.
    - tested wiring and there is current to all 4 glow plugs when turning on the ignition so wiring should be fine.
    Not sure what else is there to look at besides the glow plugs, wiring, relay and fuses.
    The only solution I can think off is to replace the glow plugs again. But the current ones test fine on resistance and I also have no problem with starting the cold engine. Everything seems to work just fine.
    Could it be that one of the plugs I installed 5 months ago is dodgy?
    Is there some other control unit that I perhaps need to look at?
    Any ideas?
  18. #17
    Jun 2016
    Arrow Re: ENGINE CODE P0382: Glow Plug/Heater Circuit "B"
    - replaced relay.
    - replaced fuse.
    Any ideas?
    Hi. If I may ask, did you manage to resolve your problem above and if so how.
    I have tried everything and yet the same problem.
    Will appreciate help
  19. #18
    Mar 2017
    louis trichardt
    Thanked: 24
    Please dont qoute me on this as it was my personal experience.
    Had the exact problem and tested glowplugs and found the faulty one and replaced it just to have the light to come on again later note it was a gwm glowplug i replaced with a gwm glowplug.
    I set out to find a replacement and found that there are similarities between the glowplugs on the gwm2.5tci and the isuzu kb250 glowplugs took a sample to my parts guy and compared them measured them as they almost looked exactly the same only differences was the isuzu plugs had thread that went higher towards where the wire should connect.
    Bought 4 NGK glowplugs for isuzu and my problem was solved and mill light hasn't been on yet and its been nearly 8 months down the line.
    Please note this was my solution and not in any way saying this is what you must try to solve the problem at hand.
    DIESEL POWER
  20. #19
    Jun 2016
    Quote Originally Posted by nicodwt22 View Post
    I will surely try it. Thanks for the response.
    Every piece of info or help is appreciated. Definitely worth a try.
  21. #20
    Mar 2017
    louis trichardt
    Thanked: 24
    Quote Originally Posted by ConnieG View Post
    I will send you the NGK part number tomorrow 1st thing when i get home
    DIESEL POWER
