Snomaster 85lt fridge freezer Qeuations
Results 1 to 5 of 5
    Feb 2017
    Weltevredenpark
    Default Snomaster 85lt fridge freezer questions
    Hi,
    I have decided to get a Snomaster BD/C-95D that is the 85 lt double door option (figuring bigger is always better). I will be using the fridge/freezer for the first time on a 2 week trip in Namibia and will be transporting it in the boot as my camping trailer does not have the side fridge door option. I have the following questions:
    • What does this freezer weigh? Would it be possible to get this out of the X5's boot at our camping spot or should I have a mobile crane available
    • Looking at the dimentions should I rather look at the smaller fridge like the 60lt option?
    Thanks in advance for your replies.
    Chris
    Brackenfell
    Thanked: 275
    Default Re: Snomaster 85lt fridge freezer Qeuations
    m2cw, pretty much any fridge packed with stock 60l and above is not a one man job anymore. LIfting it out of storage or vehicle becomes a heavy job.
    I would personally rather have 2 X 60's/52l (maybe even 40-45lt's). then you have the option of running a deep freeze in one and fridge in other.
    IIRC those dual units are not able to adjust on both sides. One side adjustable and other +-10 deg cooler(Correct me if I am wrong)
  3. The Following User Says Thank You to Dwayne P For This Useful Post:
    Secunda
    Thanked: 76
    Hi Chris
    Go to Snomaster in Meadowdale. They have all their fridges on display and will be more than happy to advise you and do a test fit.
    Apr 2014
    Thanked: 17
    I have one of those 80l Snomasters.
    Fully loaded you will not do it on your own,except if you want some serious discomfort in
    your back. But myself and the wife makes it pretty much a easy job. It is not something you carry around a lot. Rather get help
    than trying to do it on your own.
    If there is no help available, remove the racks inside and move it where you want it,then replace the racks.
  6. The Following User Says Thank You to Soundadv For This Useful Post:
    Feb 2017
    Weltevredenpark
    Thanks for the reply guys.
    I decided on getting two 40lt fridges, one for a freezer and on for a fridge.
  8. The Following User Says Thank You to ChrisX5 For This Useful Post:
