Wireless headphones for TV??
Results 1 to 20 of 31
    Thanked: 906
    Default Wireless headphones for TV??
    My father is seriously deaf and apart from many clutches burnt out in his car he is about to blow the TV speakers!!
    Can anyone recommend decent wireless headphones that won't break the bank??
    FJC - Just Cruising
    Thanked: 182
    Default Re: Wireless headphones for TV??
    I have one of these cheapies, http://www.takealot.com/stylish-5-in...e/PLID44514010
    I actually bought mine on BidOrBuy for even cheaper. It works great for tv.
    "The whole problem with the world is that fools and fanatics are always so certain of themselves, but wiser people so full of doubts" : Bertrand Russell
    2014 Nissan Navara 2.5 4x2
    1995 Nissan Sani 3.0 V6 4x4
  3. The Following User Says Thank You to staalwol For This Useful Post:
    Hillcrest, Malaysia
    Thanked: 6476
    Quote Originally Posted by dirtshark View Post
    Wireless headphones are nearly all Bluetooth. JBL is a bit pricey. They come in two sizes, mine is the bigger size. I prefer full size headphones for extended periods of use. The JBL also has a direct input so I can use them on a plane, which I do often. Musica has a really great range of Wireless headphones in all price ranges.
    Besides the headphones you will also need an Audio-Bluetooth converter/transmitter to attach to your TV or Decoder. You will need to do some research as to which Audio output you are connecting to and get the appropriate BT converter with correct connectors/cables. (The nice thing about this is that I can also BT my TV audio to my little Marley portable speaker for when I braai.)
    I went thru this process last month, for much the same reason.
ID:	444879   Click image for larger version.
ID:	444880   Click image for larger version.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  5. The Following User Says Thank You to Fluffy For This Useful Post:
    Rangeview Krugersdorp
    Thanked: 1251
    Looking too and wondering if battery life of the transmitter is a factor as well?
    Ford Figo 2016
    Thanked: 1251
    Quote Originally Posted by staalwol View Post
    What sort of battery life is there or do I need to get a power cable and plug in somewhere?
    Ford Figo 2016
    Thanked: 880
    From my binge-gaming days, I learned to get full-ear headphones.
    They are so much more comfortable.
    Other earphones sit too snug or compress the ears and will likely start hurting over long use.
    I'd rather pay a bit more and have comfort.
  9. The Following 2 Users Say Thank You to Rustie For This Useful Post:
  10. #7
    Hillcrest, Malaysia
    Thanked: 6476
    Quote Originally Posted by Rustie View Post
    Exactly my feeling. I've had a couple of the smaller ones, not necessarily cheaper either.
    The ones that cover the ears completely drown out background noise, which may or may not be desirable. If I want to hear what's going on I simply just slide one side halfway off.
    ZS5KAD
    3 V8's
  11. #8
    Thanked: 182
    I don't use them every day, but batteries last quite a long time, for daily use I guess a couple of weeks. You can also try rechargeable batteries. Sender station and headphones use 2 x AAA each, no power cable. It has an earphone cable / AV plug that plugs into tv from the base station.
  12. #9
    Thanked: 1251
    Thanks. Ordered from Takealot. Arriving Friday.
    Ford Figo 2016
  13. #10
    Thanked: 906
    Thanks, at that price it's worth a looksee.
    FJC - Just Cruising
  14. #11
    Thanked: 13692
    Can't he just get a hearing-aid?
  15. #12
    Hillcrest, Malaysia
    Thanked: 6476
    Correct, if they aren't up to scratch doesn't really matter.
    Another nice thing with them is the radio and also the fact that one transmitter can service "n" amount of headsets. Rather handy for when MIL is around.
    ZS5KAD
    3 V8's
  16. #13
    Thanked: 1251
    Surely you mean earplugs ?
    Ford Figo 2016
  17. #14
    Hillcrest, Malaysia
    Thanked: 6476
    Black Sabbath and Deep Purple are way better than mute silence.
    Hell, even Jim Reeves and John Denver are better than .............err maybe not.
    ZS5KAD
    3 V8's
  18. The Following User Says Thank You to Fluffy For This Useful Post:
  19. #15
    Thanked: 906
    Ai, it's a loooong story mixed with stubbornness, flat batteries and a shower or two........let's just say I'm trying
    FJC - Just Cruising
  20. #16
    Hillcrest, Malaysia
    Thanked: 6476
    Eish, I know the story, promise you.
    ZS5KAD
    3 V8's
  21. #17
    Thanked: 1251
    Being a bit shy of technical knowledge, how would I configure the wires so that SWAMBO doesn't have to pull the wire out of the TV H/P jack to hear TV as normal ?
    Our TV is in a difficult spot to get behind without moving the whole heavy stand. We never got the little bit of cable with 3 jacks so am putting the black jack from the emitter straight into the TV H/P hole.
    ps sound seems fine without any adjustments.
    Ford Figo 2016
  22. #18
    Thanked: 13692
    We all know you're stubborn. And you're also very trying, it's true.
  23. #19
    Hillcrest, Malaysia
    Thanked: 6476
    You wanna see grumpy. Try me after getting into a shower wearing a brand news R65k set of hearing aids.
    For somebody who doesn't know that they are hearing impaired, check the smile on their face when you slip a decent quality set of headphones on their heads.
    ZS5KAD
    3 V8's
  24. #20
    Thanked: 13692
    SWAMBO says I have selective hearing.
    I can all it residual damage from several thousands of 5.56 and 7.62 rounds.......
    I can't hear SQUAT in a place like a crowded pub. Just white noise.
  25. The Following User Says Thank You to jelo For This Useful Post:
