Series I Series 1 Full restoration (5 year plan) - Page 6
Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 101 to 120 of 137
  1. #101
    Thanked: 518
    Default Re: Series 1 Full restoration (5 year plan)
    Defender Kalahari
    Series 3 SWB
    Series 2 SWB (Near Future)
    Series 1 Station Wagon 88''
  2. #102
    Nov 2011
    Langebaanweg
    Thanked: 1124
    Nice work. Enjoy.
  3. #103
    Thanked: 518
    Yes nice parts are starting now, all the messy work is done.
    ANY IDEA HOW I CAN STEAL MY GEARBOX. ITS NOT EVEN 5KM FROM ME
    Defender Kalahari
    Series 3 SWB
  4. #104
    Thanked: 518
    Stripped all hinges and galvanized bits and pieces today.
    The doors still look good.
    Defender Kalahari
    Series 3 SWB
  5. The Following User Says Thank You to imgreg For This Useful Post:
  6. #105
    Thanked: 518
    Bit of progress today.
    Gearbox fitted, it took about 4 minutes to fit the gearbox
    Seems easy without all the goodies around it.
    Defender Kalahari
    Series 3 SWB
  7. The Following User Says Thank You to imgreg For This Useful Post:
  8. #106
    Nov 2011
    Langebaanweg
    Thanked: 1124
    Seriously envious.
    Great work.
  9. #107
    Thanked: 518
    The next job is to try and get the older style air cleaner mounted.
    This S1 never came with one mounted.
    I got this one from a friend. I will look see on my S3 how it is mounted.
    Defender Kalahari
    Series 3 SWB
  10. #108
    Thanked: 439
    Quote Originally Posted by imgreg View Post
    There’s a “framework” which bolts onto the battery tray (steering column runs underneath it”
  11. #109
    Thanked: 518
    Thanks Gary
    I have this one and can surely cut and trim to fit.
    I think its off a Series 2. Any picture of the frame next to the battery tray
    Defender Kalahari
    Series 3 SWB
  12. #110
    Sep 2008
    Thanked: 142
    Greg, the air cleaner in the photo looks like one from a Series 2A or 3. The Series I air cleaner was shorter to clear the bonnet. Just make sure that the one you have will clear the bonnet when you make a frame to fit the air cleaner.
    1951 Land Rover Series I 80" 2-litre ioe tilt (project)
    1975 Land Rover Series III 88" 2.25 p soft top (workhorse)
    1998 Land Rover Defender 90 2.8i CSW (expedition vehicle)
    1977 Land Rover Series III 109" 2.25 p station wagon (sold)
  13. The Following User Says Thank You to lrswb For This Useful Post:
  14. #111
    Thanked: 518
    Decided before starting with the body i needed to check all panels.
    The rear cross member is a new genuine part.
    The Bulkhead / Firewall is a second spare one.
    Only place i am not 100% happy is the rear tub mounting plates, few mm too far in.
    But its not bad. Need to check if the front tub mounts must face front or rear.
    So when dropping the tub must the front tub mounts be hidden behind the inner tub or see the mounts from set area.
    Defender Kalahari
    Series 3 SWB
  15. #112
    Thanked: 439
ID:	568058Click image for larger version.
    This be it......
  16. #113
    Thanked: 439
  17. #114
    Dec 2012
    Secunda
    Thanked: 98
    Stekte as die Series 1 klaar is gaan hy soos nuut wees
  18. #115
    Thanked: 518
    Update on progress.
    Started the engine sounds perfect.
    Did all the new brake pipes.
    Defender Kalahari
    Series 3 SWB
  19. The Following User Says Thank You to imgreg For This Useful Post:
    jfh
  20. #116
    Thanked: 518
    The reason for the update
    I have found another S1 and will go and do final arrangements on Sunday
    And i have no space
    The picture posted is not the exact one but to show a very very similar one with same patina
    It is virtually identical and i WANT IT.
    Defender Kalahari
    Series 3 SWB
  21. The Following 4 Users Say Thank You to imgreg For This Useful Post:
  22. #117
    Thanked: 518
    Update:
    All shocks, done with some other items finished.
    Found new diff breathers and some other stuff.
    Body will be tackled now, all parts in for light sand blast then galvanizing.
    After testing the engine and gearbox on tresles i have a major problem with the rear output shaft. OIL
    Defender Kalahari
    Series 3 SWB
  23. #118
    Nov 2011
    Langebaanweg
    Thanked: 1124
    Just be careful with sandblasting aluminium panels.
    I know a guy that buggered up his doors.
  24. #119
    Thanked: 518
    Yes. No Ali gets blasted.
    Only all the trimming and Firewall.
    BUT I HAVE A NEW PROBLEM LOOMING.
    Go check my new post
    Defender Kalahari
    Series 3 SWB
  25. #120
    Nov 2011
    Langebaanweg
    Thanked: 1124
    I won't worry about that, I know you have the skills to quickly sort this out.
