Series I Series 1 Full restoration (5 year plan) - Page 4
Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 61 to 80 of 137
  1. #61
    Thanked: 520
    Default Re: Series 1 Full restoration (5 year plan)
    I found this thanks GARYNow just that pipe OD and ID for the Steering Relay.Please share that Love you always talk about.
    Defender Kalahari
    Series 3 SWB
    Series 2 SWB (Near Future)
    Series 1 Station Wagon 88''
  2. #62
    Thanked: 520
    Managed to cut off the channel iron rear crossmember.
    Made up a sort of jig to keep everything straight and level.
    The new one is not secure yet.
    I want to get it all level and straight then re-check all my dimensions to the drawing in the manual.
    Defender Kalahari
    Series 3 SWB
  3. #63
    Thanked: 439
    76,3 OD
    69,3 ID
    Steering relay pipe
  4. The Following User Says Thank You to GaryFrank For This Useful Post:
  5. #64
    Thanked: 520
    Thanks Gary i found Hollow bar and will have it machined to fit the steering relay and the chassis.
    I will need to find a picture to see how much this needs to be sticking out the bottom.
    Or is it similar to my S3.
    Defender Kalahari
    Series 3 SWB
  6. #65
    Dec 2014
    Thanked: 1839
    Quote Originally Posted by imgreg View Post
    Surely the 2 locating bolts at the top will determine how far it sticks out the bottom?
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  7. #66
    Sep 2008
    Thanked: 142
    It is the same as the Series 3 - you will also need the flange plate fixed by 4 bolts to the chassis frame.
    1951 Land Rover Series I 80" 2-litre ioe tilt (project)
    1975 Land Rover Series III 88" 2.25 p soft top (workhorse)
    1998 Land Rover Defender 90 2.8i CSW (expedition vehicle)
    1977 Land Rover Series III 109" 2.25 p station wagon (sold)
  8. #67
    Dec 2014
    Thanked: 1839
    Wouldn't it be cheaper to buy the required length off Gary and courier it up to you rather than paying someone to do that turning work?
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  9. #68
    Thanked: 439
    Hahaha....that might take another month or 2.....
    The tube sits flush with the bottom of the CM. Then there a “locator plate” that is bolted to the bottom of the CM.
    Said plate centers the steering relay. Pack that puppy with copper slip when you put it in, grease just melts away and makes a mess of your pretty chassis
  10. #69
    Jul 2015
    Kilkivan
    Thanked: 242
    I run a bit of silicone sealant around the top in the gap between the relay and the chassis. This stops any water and muck getting in there to rust and bind it up. Makes it easier to remove next time.
  11. #70
    Thanked: 520
    Decided to strip the engine.
    Head has gone in for nice new parts and full check.
    Inlet and outlet manifolds are being acid washed.
    What a mess draining the sump and cleaning. Managed to bump 3 L of old oil on the floor
    Made a very very rough engine stand for cleaning rebuilding and spray painting.
    Defender Kalahari
    Series 3 SWB
  12. #71
    Thanked: 520
    Almost ready to start assembling the chassis with both diffs and engine.
    Diffs all new bearings. Engine cylinder head re-done.
    I like referring to this site http://www.geoffslandroverblog.com/
ID:	538449   Click image for larger version.
ID:	538450   Click image for larger version.
    Defender Kalahari
    Series 3 SWB
  13. #72
    Nov 2011
    Langebaanweg
    Thanked: 1124
    Very nice work.
  14. #73
    Thanked: 520
    Decided to rebuild the engine totally.
    New bearings and all seals etc.
ID:	539256   Click image for larger version.
    Defender Kalahari
    Series 3 SWB
  15. #74
    Cape Town Southern Suburbs
    Thanked: 1123
    You have developed the itch that can never be sufficiently scratched, that Landy must be restored down to every last nut and bolt and then the add-ons start..
  16. #75
    Thanked: 520
    Quick update.
    Diffs are totally rebuilt all new bearings and seals.
    Engine I decided what the hell, new pistons rings and bearings complete rebuild.
    Most parts are now sand blasted and black primed.
    Defender Kalahari
    Series 3 SWB
  17. The Following User Says Thank You to imgreg For This Useful Post:
  18. #76
    Thanked: 439
    Jotun Boet
  19. #77
    Thanked: 520
    Update:
    Brand new, bearings, pistons, complete rebuild of engine, head and all.
    Found as close to dammit engine paint, the Duck Egg Blue.
    It is an odd colour that changes a lot in different lighting conditions.
    Defender Kalahari
    Series 3 SWB
  20. The Following 2 Users Say Thank You to imgreg For This Useful Post:
  21. #78
    Nov 2011
    Langebaanweg
    Thanked: 1124
    Nice work!
  22. #79
    Klipriver
    Thanked: 279
    Awesome!!! I just love threads like this, nothing more satisfying than seeing things come together.
    One day when I am big.....
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
  23. #80
    Oct 2019
    Karoo
    Thanked: 406
    As the Brits would say...its the dogs bollocks!
    Really nice job.
