Series I Series 1 Full restoration (5 year plan) - Page 3
Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 41 to 60 of 137
  1. #41
    Sep 2014
    Thanked: 130
    Default Re: Series 1 Full restoration (5 year plan)
    Nice!!! Well done
    Wolverine : 93' Range Rover Classic 3.9L EFI
  2. #42
    Thanked: 518
    One job I will not do again. Rather pay someone to do this I think.
    After battling for ages to remove the shackle bushes from the chassis, I HAVE ONE NEW ONE IN PLACE.
    The other 3 will not go in.
    I stripped both my threaded jacking rods to force the Damm things in.
    The hole was drilled clean with a wire brush, the bushes had been in the freezer for a week.
    Dipped them in grease BUT NO they now remain half in
    So now I will shop for a ###### pusher puller thing to get them in.
    What a battle to remove and install.
    Should have shoved poly bushes in
    Defender Kalahari
    Series 3 SWB
    Series 2 SWB (Near Future)
    Series 1 Station Wagon 88''
  3. #43
    Thanked: 518
    Anyone know how to find and install the steering relay sleeve thing.
    This could be part of the chassis because when I pushed the 62 year old relay out the sleeve crumbled out.
    Might have to out engineer the problem and make a plan.
    Left below is the part hidden within the Chassis.
    Above right is mine crushed to bits.
    I have a new steering relay so may as well get a new sleeve thing.
    Defender Kalahari
    Series 3 SWB
  4. #44
    Thanked: 518
    Diffs all stripped and clean ready to reassemble with brand new parts, all bearings and seals will be new
    Another part to install is the proper rear bumper as below.
    Will need to cut the old rubbish off and weld this new one on.
    A jig of square tubing will be made to keep alignment and all dimensions correct as it is now for the "bak" fitment. (well I think that is how it should be done)
    Just trying to get my head clear for a few days and forget about Shackle Bushes till Monday when I will get the holy grail of pushers or pullers
    Defender Kalahari
    Series 3 SWB
  5. #45
    Thanked: 439
    Default Series 1 Full restoration (5 year plan)
    Tip #1 - cut your replacement bushes in half.......
    Tip #2 - make a jig that bolts on the existing tub mounts before you cut anything. You want to bolt to the front tub supports (back of the seat box)
    Tip# 3 - steering relay sleeve is just a piece of schedule water pipe. I’ll try remember to get sizes for you
  6. The Following User Says Thank You to GaryFrank For This Useful Post:
  7. #46
    Thanked: 439
    DIY
  8. The Following User Says Thank You to GaryFrank For This Useful Post:
  9. #47
    Dec 2014
    Thanked: 1836
    DIY
    Great progress, mate!!
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  10. The Following User Says Thank You to JohnnoK For This Useful Post:
  11. #48
    B-gowrie Randburg
    Thanked: 293
    ... are those shackle bushes hard steel ?
    ... or couldnt you put a hacksaw blade through
    and then fasten upside-down into hacksaw ...
    etc
    2002 Defender 130 DC HCPU. : Own the road...Any road
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8... The Greatest Rover.
    ‘1975 Series3 88 PUP... Simply Classic...
    ‘2017 Metalian Mini ... A Home from Home
  12. #49
    Thanked: 439
    I normally burn the rubber out to get the inner sleeve out and then cut the outer sleeve with a hacksaw
  13. #50
    B-gowrie Randburg
    Thanked: 293
    Im sure the tactic works but ...
    ... must be smokey business ...
  14. #51
    Thanked: 518
    I cut them out with a hacksaw then pressed them out. Eventually they shot out.
    Getting them back is a problem. To late to cut them now.
    Thanks Gary, I see the relay at the machined lower end is 66.3mm.
    The chassis roughly is 110 height and 70 for the sleeve, but I will wait for in the week please.
    Defender Kalahari
    Series 3 SWB
  15. #52
    Thanked: 439
    Stinky smoke
  16. #53
    Apr 2011
    Thanked: 19
    Fantastic thread, thank you!
    Subscribed.
    Guillaume
    Fortuner Epic 4.0 V6 AT
  17. #54
    Thanked: 518
    WELL, that was easy, really easy.
    Shows you, walk away and try another day.
    No need for freezer and sukkel
    High tensile steel threaded rod M12. Special long nuts, Power bar and they are all planted into the chassis.
    Next job
    Defender Kalahari
    Series 3 SWB
  18. #55
    Jul 2013
    Gauteng
    Thanked: 27
    Great looking work!!
    I am planning on doing the rear chassis bushes on my S2A this weekend - do you have a photo of the M12 threaded rod setup (are you using washers etc as well as nuts)? Did you just buy this at a normal hardware store?
    Thanks a million!
  19. #56
    Hunters Close, Port Elizabeth
    Thanked: 77
    nice progress Greg. those schackle bushes are not that old. fitted in 2012 when the springs replaced and maybe 3000km max use over 4 years.
    Luke aka Jedi
    1954 Landy Rover Series 1 86"- Rambling Rose
    Best company slogan: Cherrybomb performance exhaust, Disturbing the peace since 1968
  20. #57
    Thanked: 518
    Default Re: Series 1 Full revamp (5 year plan)
    I have been away so need to get back into this "hobby"
    I want to cut off the rear cross member and install the new one.
    How do you make a jig.
    1. Is the jig only to hold the rear sides in place to stop twisting and opening up.
    2. Is the jig only to line everything up as it is now.
    I bought some 32x19 steel to use as a jig but cant find info on how to build a jig.
    @ Gary Frank, the size diameter of the steering relay, have you found the size pipe yet ?
    PLEASE
    Defender Kalahari
    Series 3 SWB
  21. #58
    Dec 2014
    Thanked: 1836
    Quote Originally Posted by imgreg View Post
    There is no hard and fast "this is how you build a jig" info out there. For a one-off job, just wing it.
    All you need to do is make it so you can remove the old piece and fit the new one with accuracy.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  22. #59
    Thanked: 439
    My RCM jig bolts to the tub mounts (seatbox area) and rests on the tub supports. Will try remember to take a pick..... and measure that pipe
  23. #60
    Dec 2014
    Thanked: 1836
    It's a 6m length, Gary...
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
