Page 11 of 11 FirstFirst ... 2 3 4 5 6 7 8 9 10 11
Results 201 to 211 of 211
  1. #201
    Thanked: 115
    Default Re: Indeflate - Inflate, or deflate two tyres simultaneously!
    I tow a Bush Lapa, would I need to purchase the 5m extension pipe to be able to inflate the Bush Lapa tires?
    Thanks.
    Ben
    RY WAAR JY MAG MET PASSIE
    2009 Toyota Hilux 3.0 D4D DC 4X4
  2. #202
    Gqeberha
    Thanked: 5537
    Depends where you compressor is, but probably.
  3. The Following User Says Thank You to Dirk For This Useful Post:
  4. #203
    Helderkruin
    Thanked: 602
    Laat sit net vir jou voertuig n plug agter op en plug dan kompressor daar in baie nader aan karavaan tyers dan
  5. The Following User Says Thank You to Leon Venter For This Useful Post:
  6. #204
    King Williams Town
    Thanked: 1994
    I bought an I deflate then bought 5m extra same type hose from a pneumatic shop dealing with hoses. I also installed those quick connect valve connections onto pipes. Compressor can run when I'm moving to the tyres as it does not build up pressure until connected.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  7. The Following 2 Users Say Thank You to hunter26 For This Useful Post:
  8. #205
    I received a 2 x Tyre Indeflate as a present in Jan 2020 used on 2 x trips to Moz , the best gift I received in years.
  9. #206
    Feb 2008
    Thanked: 114
    I have an Indeflate and it is one of the best pieces of kit I have. The one thing that is a bit annoying is that you cannot see to where you have delated whilst you are busy doing it. Has anyone tried to combine it with something like a Staun Deflator? Can Indeflate not come up with a way to calibrate to which pressure you want to deflate?
    By the way - I also don't trust the gauge on the system. Still using my hand gauge to take a pressure reading when using it.
    Gerrit Laubscher
    Angola sempre
  10. #207
    Wartburg
    Thanked: 2614
    Quote Originally Posted by lirritma View Post
    An inline pressure gauge while deflating is not accurate anyway as it is an open system during deflation. If you had two valves per tyre, then you could add a pressure gauge to the second valve for real time pressures. With a single valve, you have to stop deflating every now and then to check the pressure - very easy on the indeflate with the moving bit.
    The pressure gauge on mine also does not correspond to the gauge I have used and trusted for many years. But it is consistent. I've made a note of my calibration, eg if I want 2.0b, I will use 2.1b on the gauge. I have not calibrated it with an accurate gauge, and for all I know, it might be accurate and my old gauge might be out
    Mike Lauterbach
  11. #208
    May 2007
    Welgelegen, Cape Town
    Thanked: 289
    Pse help, yes mine does not equalise, and when I pump, one tyre is always .2 higher than the other.
    Am I doing something wrong?
    Toyota D4D Legend 45
    Triton Clubcab 2x4 2.5 DID
    Bushlapa Vlooi 652
  12. #209
    Gqeberha
    Thanked: 5537
    That does not sound right, give Indeflate a call I am sure they will help you.
  13. #210
    Wartburg
    Thanked: 2614
    Quote Originally Posted by Kaptein Jack View Post
    It id virtually impossible for the tyres to be at different pressures without some serious blockage in one pipe. When you apply pressure to the indeflate, without connecting the ends, does air flow freely fro each end?
    How are you measuring the pressure in each tyre?
    Mike Lauterbach
  14. The Following User Says Thank You to mikeml For This Useful Post:
  15. #211
    May 2007
    Thanked: 289
    I will check on that, doubt it, as it pumps both tyres, but always the difference of .2, same when deflating.
    But did contact Indeflate, they are going tp sort it out, thks
    Bushlapa Vlooi 652
