The 'IT ARE TIME' thread - Page 989
Page 989 of 1046 FirstFirst ... 489 739 889 939 964 979 980 981 982 983 984 985 986 987 988 989 990 991 992 993 994 995 996 997 998 999 1014 1039 ... LastLast
Results 19,761 to 19,780 of 20907
  1. #19761
    Oct 2006
    Melkbosstrand
    Thanked: 894
    Default Re: The 'IT ARE TIME' thread
    Enjoy...
    Sitting out on the cooking thing again tonight, all the threads and posts on the subject has me busy building a potstill.
    Forums, they cause things
  2. The Following 3 Users Say Thank You to Kola For This Useful Post:
  3. #19762
    Richardsbay, KZN
    Thanked: 15349
    Quote Originally Posted by Kola View Post
    Enjoy...
    Best of wishes and good luck. A world of frustration awaits you
    Walker Evans, Photographer
  4. #19763
    Richardsbay, KZN
    Thanked: 15349
    As much as I would prefer to just sit and drink rum while staring at the flames, which I can do very well, such deeds are frowned upon by the offspring. So the bricks on the fire table are arranged like so.
    With some rum as guidance.
  5. The Following 4 Users Say Thank You to Riaan van Wyk For This Useful Post:
  6. #19764
    Thanked: 15042
    Time it areClick image for larger version.
  7. The Following 2 Users Say Thank You to jelo For This Useful Post:
  8. #19765
    Richardsbay, KZN
    Thanked: 15349
    Place a skottel on the bricks, gooi chopped hunyin and bay leaves and rev.
  9. The Following 2 Users Say Thank You to Riaan van Wyk For This Useful Post:
  10. #19766
    Richardsbay, KZN
    Thanked: 15349
    Leave a gap in the bricks ro add some small pieces of wood as and when required as this needs to be revved, klapping fast and furious moves
  11. The Following 2 Users Say Thank You to Riaan van Wyk For This Useful Post:
  12. #19767
    Richardsbay, KZN
    Thanked: 15349
    Then add some nyamayenkomo ( beef) and rev till noisy, fold a few times to create the flavours and then add a bit of water. This will be the temperature control as flames have no knoppies.
    Add water as and when the pan gets noisy, fold and repeat. This is what makes the nyama tender.
  13. The Following 2 Users Say Thank You to Riaan van Wyk For This Useful Post:
  14. #19768
    Richardsbay, KZN
    Thanked: 15349
    A spritz of lemon juice and a tin of t&o in. Fold and if needed add some water, all thst needs to happen now is to cook the tinned tomato mix, the nyama will be done.
  15. The Following 3 Users Say Thank You to Riaan van Wyk For This Useful Post:
  16. #19769
    Richardsbay, KZN
    Thanked: 15349
    When the globules of fat start seperating and the colour looks good, we know the dish is done. Off the fire to rest while I make some rice on bottled flames.
    And pour some more rum, seeing there is two minutes where I am doing nothing in this provess.
  17. The Following 2 Users Say Thank You to Riaan van Wyk For This Useful Post:
  18. #19770
    Richardsbay, KZN
    Thanked: 15349
    And a dish the laaites realy like, which I call "Maphelane Special"
    Usually served with horrog rolls, as the offspring, after scoffing grab a leftover roll or two and swipe the pan clean of any leftover sous. But tonight with rice, I forgot to buy rolls on the way home, so the laaities will have to use their fingers for the pan. Which in itself is a valuable lesson, make do with what you have.
    Sekunjalo it was.
  19. The Following 5 Users Say Thank You to Riaan van Wyk For This Useful Post:
  20. #19771
    Apr 2012
    Ter Aar
    Thanked: 508
  21. The Following 4 Users Say Thank You to kab123 For This Useful Post:
  22. #19772
    Ruimsig
    Thanked: 13308
    It Are Time Boyz
    It Are Pork Fillet Wraps thos evening
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
  23. The Following 3 Users Say Thank You to Estee For This Useful Post:
  24. #19773
    Ruimsig
    Thanked: 13308
    Take a pork fillet and.............
    Hummer H3 V8
    W.A.P Objectivist
  25. The Following 4 Users Say Thank You to Estee For This Useful Post:
  26. #19774
    Ruimsig
    Thanked: 13308
    ........escalope it.
    Then..................
    Hummer H3 V8
    W.A.P Objectivist
  27. The Following 4 Users Say Thank You to Estee For This Useful Post:
  28. #19775
    Ruimsig
    Thanked: 13308
    ......... lightly brush with oil and season with cracked salt and pepper
    Hummer H3 V8
    W.A.P Objectivist
  29. The Following 4 Users Say Thank You to Estee For This Useful Post:
  30. #19776
    Ruimsig
    Thanked: 13308
    Seal over indirect heat
    Hummer H3 V8
    W.A.P Objectivist
  31. The Following 4 Users Say Thank You to Estee For This Useful Post:
  32. #19777
    Ruimsig
    Thanked: 13308
    Give it a bit of a mop with a Morrocan spaais mop dis ting
    Hummer H3 V8
    W.A.P Objectivist
  33. The Following 3 Users Say Thank You to Estee For This Useful Post:
  34. #19778
    Richardsbay, KZN
    Thanked: 15349
    At last, some salve for the soul. Cheers.
  35. The Following 4 Users Say Thank You to Riaan van Wyk For This Useful Post:
  36. #19779
    Ruimsig
    Thanked: 13308
    Cheers RvW
    Hummer H3 V8
    W.A.P Objectivist
  37. #19780
    Ruimsig
    Thanked: 13308
    Dice the fillet
    Hummer H3 V8
    W.A.P Objectivist
  38. The Following 2 Users Say Thank You to Estee For This Useful Post:
