The 'IT ARE TIME' thread - Page 954
Page 954 of 1044 FirstFirst ... 454 704 854 904 929 944 945 946 947 948 949 950 951 952 953 954 955 956 957 958 959 960 961 962 963 964 979 1004 ... LastLast
Results 19,061 to 19,080 of 20862
  1. #19061
    Thanked: 973
    Default Re: The 'IT ARE TIME' thread
    Friday evening we made pizza with my newly arrived pizza pans. I finished splitting and packing bulk meat purchases after 21:00 so the pizzas went in the oven. It was amazing! I want to do a focaccia on the coals later. Pics to follow. Sorry guys you know when it comes to braaing I am always the agteros, thats why I havent been active here lately. Pics from the Friday evening pizzas.
ID:	579433   Click image for larger version.
    12 Conqueror courage
    Dawie van der Merwe
    If you fail to plan, you plan to fail.
    A goal without a plan is just a dream.
  2. The Following 5 Users Say Thank You to LandyLove For This Useful Post:
  3. #19062
    Ruimsig
    Thanked: 13206
    Quote Originally Posted by LandyLove View Post
    You are here. Thats what counts Boet. Cheers
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
  4. The Following 5 Users Say Thank You to Estee For This Useful Post:
  5. #19063
    Jun 2016
    Randfontein
    Thanked: 2567
    No fancy cooking this side. Just some newspaper chips on fresh bread.
    Willie Knoetze
    2020 Nissan NP300 2.5TDi S/C
  6. The Following 10 Users Say Thank You to FWM For This Useful Post:
  7. #19064
    Richardsbay, KZN
    Thanked: 15282
    Pizzas done and dusted.
ID:	579437   Click image for larger version.
    Walker Evans, Photographer
  8. The Following 7 Users Say Thank You to Riaan van Wyk For This Useful Post:
  9. #19065
    Richardsbay, KZN
    Thanked: 15282
    The Teenage Blonde came up with this scheme. She folded the edges over in a robust fashion and added extra topping. Which of course makes it difficult to slide off the deksels I use for the initial into the huvin stage but as she smaaks a slightly doughy base, it is perfect for her.
  10. The Following 5 Users Say Thank You to Riaan van Wyk For This Useful Post:
  11. #19066
    Richardsbay, KZN
    Thanked: 15282
    Then flatten a bird, cut randomly with a naaf, generously douse with peri peri sauce and rub and vryf into the exposed areas. Leave to tune and pour some more rum.
  12. The Following 7 Users Say Thank You to Riaan van Wyk For This Useful Post:
  13. #19067
    Feb 2014
    Thanked: 781
    Chisa Nyama
    Okumnandi ngempela
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
  14. The Following 8 Users Say Thank You to Zapiture For This Useful Post:
  15. #19068
    Thanked: 973
    Quote Originally Posted by Riaan van Wyk View Post
    I know I don't have space for a oven, but the more I look at your creations the more I WANT TO NEED ONE. I might ask you for specs and some do's and don'ts in the near future.
    That looks delicious!
    Dawie van der Merwe
  16. The Following 5 Users Say Thank You to LandyLove For This Useful Post:
  17. #19069
    Ruimsig
    Thanked: 13206
    Boyz are tjuning the flames today
    Hummer H3 V8
    W.A.P Objectivist
  18. The Following 3 Users Say Thank You to Estee For This Useful Post:
  19. #19070
    Richardsbay, KZN
    Thanked: 15282
    Then Karlien's Oven needs to rev, add more wood till on about two Mississippis which is quite close to 300 deg C if I remember correctly, said measurement done manually. Cover the roasting pan with shiny stuff and let it vuthela for thirty minutes or so.
  20. The Following 7 Users Say Thank You to Riaan van Wyk For This Useful Post:
  21. #19071
    Thanked: 973
    Daar vat hy!
    Rump steak marinated overnight in some of dis stuff. Wiff some wors, garlic focaccia, roosterkoek and potatoes and some greens for the birds.
ID:	579448   Click image for larger version.
ID:	579449   Click image for larger version.
    Dawie van der Merwe
  22. The Following 8 Users Say Thank You to LandyLove For This Useful Post:
  23. #19072
    Ruimsig
    Thanked: 13206
    Boyz. Anyone tried this. I have to pass it in the rum aisle so thought I would pick up a bottle. Not much info on it. R50.00 a bottle at 18%. Ricardo Dominion Rum Company. I found it was registered in the 1930s in DBN. Now owned by Distell
    Initial impression was Fenzedol cough syrup watered down but its actually quite pleasant. Expecting a weak rum but more like a cheap Jager.
    Quite liqourice-y. Not bad. Click image for larger version.
    Hummer H3 V8
    W.A.P Objectivist
  24. The Following 3 Users Say Thank You to Estee For This Useful Post:
  25. #19073
    Ruimsig
    Thanked: 13206
    Back label
    Hummer H3 V8
    W.A.P Objectivist
  26. The Following 2 Users Say Thank You to Estee For This Useful Post:
  27. #19074
    Jan 2016
    Thanked: 1295
    I don't know the criteria for this thread, but Swambo's chicken curry - wow...
    2001 Gen 3 Pajero swb 3.2 Di-D
  28. The Following 7 Users Say Thank You to Jens78 For This Useful Post:
  29. #19075
    Richardsbay, KZN
    Thanked: 15282
    Foil comes off, slice and skweez the juice out of a lemon and place on top of the nkuku. Back into the huvin for ten minutes to finish, the high walled pan helps to shield the dish from the refracted flame heat so one needs to swaai the pan around just once in the ten minutes. Remember to ladle the sous over the nyama before going back into the huvin.
ID:	579453   Click image for larger version.
  30. The Following 8 Users Say Thank You to Riaan van Wyk For This Useful Post:
  31. #19076
    Oct 2017
    Rustenburg
    Thanked: 3880
    This thread is cooking tonight
    Andrew van Staden
  32. The Following 3 Users Say Thank You to Hedgehog For This Useful Post:
  33. #19077
    Richardsbay, KZN
    Thanked: 15282
    And leaving just enough time to pour some more rum, the chicken is ready. Leave to rest and now we move into the twilight zone as I need to do something else in the oven but don't need it to have flames and preferably would like to lose maningi levels of degrees C.
  34. The Following 6 Users Say Thank You to Riaan van Wyk For This Useful Post:
  35. #19078
    Richardsbay, KZN
    Thanked: 15282
    Place the huvin's door to close the entrance and block the chimney with a round stone which fits more or less perfectly. This will starve the oven of oxygen and kill the vuthelaring stories. It will still be very hot inside but there are ways and means around that problem also.
    If the door looks like I made it with my dumb hands you would be correct as I did
  36. The Following 5 Users Say Thank You to Riaan van Wyk For This Useful Post:
  37. #19079
    Thanked: 973
    Quote Originally Posted by Jens78 View Post
    Criteria is anything lekker. Usually things made on the fire, but is is winter, so anything goes.
    Dawie van der Merwe
  38. The Following 3 Users Say Thank You to LandyLove For This Useful Post:
  39. #19080
    Richardsbay, KZN
    Thanked: 15282
    With the leftover sourdough used for the pizza bases, form some broodjies.
  40. The Following 6 Users Say Thank You to Riaan van Wyk For This Useful Post:
