Results 1 to 5 of 5
    Jun 2016
    Thanked: 30
    Default Replacing front and rear brakes
    Gents, i need to replace my front pads and rear shoes. Are these off the shelf for GWM at spares shops(in Kempton park i usually support Litts2000), or should i consider other brands?
    What would you guys suggest?
    2014 GWM Steed 2.0 VGT D/C
    2011 Jurgens Camplite
    Jun 2016
    Randfontein
    Thanked: 4122
    Default Re: Replacing front and rear brakes
    I found that Ferodo is better than the ones GWM sells.
    Willie Knoetze
    2019 Nissan NP300 2.5tdi d/c 4x4
    Thanked: 250
    MPD in Boksburg - 010 492 0690
    2013 Tata Xenon 3.0 Dicor D/C
    2006 Honda Civic EXi FN2
    Jun 2016
    Thanked: 30
    Thanks guys, went through to MPD, and picked up the pads.
    Will see if I can install them tonight. Any of you that have done this before to give some heads up on what surprises to expect?
    Mar 2012
    heidelberg g
    Thanked: 25
    neewat nie veel surprizes nie.
    die dromme stel jy et n spiel
    dit gaan ju dalk n rukkie neem as ou dromm uit gewear s
