Carnage Canyon 16-18 June 2017
Page 1 of 29 1 2 3 4 5 6 7 8 9 10 11 26 ... LastLast
Results 1 to 20 of 564
    Polokwane
    Thanked: 23
    Talking Carnage Canyon 16-18 June 2017
    OK boys & girls,
    It is time for the yearly wheeling fest, that is Carnage Canyon!
    All the interested parties that would like to join us, please drop me an e-mail [email protected]
    I will then send you the info, and you can decide if you comply with the recommended minimum requirements for the trail.
    This year will be a true minimalist camping/wheeling trip, meaning you will have to bring everything, and take everything out with you.
    The dates chosen ensures that no vehicles will require scuba gear this time around
    Here is the latest list of all that have confirmed to be there 22-05-2017:
    1. Ronald Hairbottle
    2. Leon Papenfus Jnr.
    3. Jimmy Olds
    4. Deon Smith
    5. Dirk Van Reenen
    6. Sakkie Coetzee
    7. Reenen Kritzinger
    8. Jean Van Niekerk
    9. Francois
    10. Dawid Loubser
    11. Vic Rundle
    12. Hansie Coetzee
    13. Arche Coetzee
    14. Lourens Rautenbach
    15. Nico Fourie
    16. Bruce Swatton
    17. Jan Bredenhann
    18. Shaun Van Rooyen
    19. Johnny/Rudolf Durant
    20. Fransie Smit
    Still deciding:
    1. Andre De Klerk
    2. Leon Papenfus Snr.
    3. JJ Jacobs
    Spectators:
    1. Woolf Freinkel
    Vehicle requirements:
    • Reliable vehicle, no limping components, if it is suspect, replace it prior to the trip
    • At least 33" tires, 35" + preferable
    • Lockers front & rear preferable (You will battle with open diffs)
    • Diff protection
    • Steering protection
    • Belly protection
    • Sill protection i.e. rock sliders
    • Remember, any lost clearance is bad, so fit protection that doesn't rob clearance
    Recommended spares:
    • Axle shafts - front & rear
    • U-joints for front axle shafts & propshafts
    • Gearbox, t-case & diff oil, power steering fluid
    • Sealant for diff covers
    • Fuses, relays & electrical wire
    • Tools that suit your vehicle
    Recovery gear:
    • Proper front & rear recovery points (A tow ball is not a recovery point)
    • Fire extinguisher
    • High lift jack
    • Jack buddy
    • Collapsible axle stand
    • Spade for pooping duties etc.
    • Tire plug kit & tire valves
    • Compressor
    • Tow rope, snatch strap & tree protector
    • Winching accessories, if winch fitted:
      • Snatch block
      • Rope weight
      • Bow shackles
      • Gloves
    Here are some pics to whet your wheeler appetites
    Wild About Wheeling!
    God forgives, rocks don't!
  2. The Following User Says Thank You to 4RNRRON For This Useful Post:
    Mosselbaai
    Thanked: 455
    Default Carnage Canyon 16-18 June 2017
    Thanks Ronald it's going to be awesome!
    Tjiep Softroadertjie
    Toy Rollover
    Mar 2012
    Krugerdorp
    Thanked: 51
    Default Re: Carnage Canyon 16-18 June 2017
    Damn!!!!!! Gonna miss it again:-(
    This one is my bucket list!!
    Dominik says:
    Build them, Don't buy them
    2004 TJ Sahara
    4.5 Rubicon Express, SYE, 35"Maxxis, Custom Hi-lift mount, winch and plenty other things
    1975 Willys CJ6
    Dec 2010
    klerksdorp
    Thanked: 96
    I don't know how to go about this but I please need to go with if possible.My email address is [email protected]
    Langs die rivier, op n berg
    Thanked: 2204
    Kan nie wag nie.
    KEMPTON PARK
    Thanked: 279
    Ronald could I suggest that you start an attendees list ? seems that this one can be big.
    05 TJ SAHARA
    08 3.8 JK ULTD RUBICON
    Polokwane
    Thanked: 23
    Quote Originally Posted by johnnybritz View Post
    Hi Johnny,
    E-Mail sent.
    Polokwane
    Thanked: 23
    Quote Originally Posted by NEON DEON View Post
    As soon as we get confirmation, i.e. money in the bank, I will start an attendee list.
    So far there are quite a number of victims that say they are keen, so keep them coming!
    Dec 2006
    Thanked: 745
    Granny, ek en Adele kom saam!!! Nadat ons laas 'n sideshaft gebreek het halfuur in die trail in, wil Adele net met mag en mening terug gaan.
    Granny loop nou op 'n M89 agter. Nie eers met die 307 crawlers in kan 'n 280 daai diff breek nie. Voor het sy chrome-moly side shafts in en "lifetime guarantee" Longfield CVs
    Altwee diffs op 4 spiders in plaas van die normale 2.
    ....en amper 600mm onder die pens, en high steering arms om die belangrike goete so vr moontlik van die klippe af weg te kry.
    Vir 'n padvoertuig is sy omtrent so reg soos wat kan kom.
    Ek dink ek moet twee kompleet props en ten minste een centre bearing saamvat. Gaan beslis 'n paar steering rod ends saamvat.
    Sakkie Coetzee
    Thanked: 2204
    Ek is def in. S net waar ek moet betaal.
    Wat voertuig betref..., ek moet hom seker trail ready kry.... nou nie heeltemal op oom Sakkie se standaard, so sal werk daaraan.
    Hopelik is my ruiltransaksie op my 37" dan al klaar, dan kan ek my 35" af gooi en 37" kevlar op muds op h.
    My hoogte onder pens is seker beter as gemiddelde voertuig, maar dan neem ek aan die is nie vir gemiddelde voertuie nie...
    KEMPTON PARK
    Thanked: 279
    Elke ou moet maar die spares inpak wat hy dink hy gaan nodig kry, belangrikste spre is die regte attitude, die is n extreme fun event.
    Ek het Carnage al twee keer gery, eerste keer baie rim rash, tweede keer drive shaft geduik en shock afgery, maar nog steeds die trail klaar gemaak. Twee dae se ry is baie tyd om versigtig te wees.
    Maar dinge kan skeef gaan, beplan deeglik, service propshafts voor die trip. Gaan oor alles wat jy dink kan skade optel op n klip crawl trail .
    05 TJ SAHARA
  13. The Following User Says Thank You to NEON DEON For This Useful Post:
  14. #12
    Mosselbaai
    Thanked: 455
    Nou raak jy te windgat, 37" bande!
    Toy Rollover
  15. #13
    Mosselbaai
    Thanked: 455
    Quote Originally Posted by Sakkie View Post
    Sjoe 600mm is impressive Oom, ek het maar 310 onder die TJ op die oomblik so het nog baie werk om te doen voor carnage.
    Toy Rollover
  16. #14
    Mosselbaai
    Thanked: 455
    Eks bly Oom kom ook saam!
    Toy Rollover
  17. #15
    KEMPTON PARK
    Thanked: 279
    Het nou net my jeep gaan meet ,450 mm onder die pens , reken dis ok , as dit nie is nie dan skuur ons maar oor die klippies .
    05 TJ SAHARA
  18. #16
    Thanked: 2204
    Het myne gaan meet. Soos hy nou staan, het hy 600mm onder pens onder transfercase.
    450mm onder my crossmember wat ek ingesit het om voor prop te beskerm,
    300mm onder my pampoen.
    Ek wil gaan na 37", maar sal dan nog so n duim moet lig op suspensie om te maak pas, dan het ek darem 325mm onder pampoen, 500mm onder prop gaurd, en 650mm onder pens.
  19. #17
    KEMPTON PARK
    Thanked: 279
    Some pis of the last trip
    05 TJ SAHARA
  20. #18
    KEMPTON PARK
    Thanked: 279
    Lets try again
ID:	441088   Click image for larger version.
ID:	441089   Click image for larger version.
ID:	441090   Click image for larger version.
ID:	441091   Click image for larger version.
ID:	441092   Click image for larger version.
    05 TJ SAHARA
  21. #19
    Mosselbaai
    Thanked: 455
    Dis hoekom die staal plate daar is. En n pel met n punt vir die winch as mens bietjie hard begin skraap
    Toy Rollover
  22. #20
    Sep 2011
    Potch/Brits
    Thanked: 476
    Reenen, wat van n roll cage?
