Echo Power Panel EPP12AS Solar Connection
Results 1 to 4 of 4
    Jun 2012
    Default Echo Power Panel EPP12AS Solar Connection
    Hello All
    First I must apologise if this has already been answered I have searched but cannot find anything specific.
    I have bought a solar panel and now on closer inspection I see that my Echo Panel Model EPP12AS Rev 2 has "100w Solar charge controller (Optional)" on it. How do I know if the option is fitted. Not too keen on opening it up but will do if necessary. I have attached 2 pictures. Front and top. The solar connection is fitted to the top but it does not have a "socket" fitted so I assume that mean it does not have the solar option fitted, and I need to add a solar charge
    controller.
    Thanks in advance for advise.
    Nick
ID:	440163   Click image for larger version.
    Friemersheim, Southern Cape
    Thanked: 2125
    Default Re: Echo Power Panel EPP12AS Solar Connection
    There are no connector blocks on Sol?
    Presumption that it is not solar ready, thus no charge controller.
  3. The Following User Says Thank You to Prof For This Useful Post:
    Okahandja, Windhoek
    Thanked: 737
    Yes no solar connection. I fitted a victron 75/15 solar charger separably, as the echo panel could not take the 180 watt solar panel.
    Johan Kriel
    LC's and Echo Chobe
  5. The Following User Says Thank You to JLK For This Useful Post:
    Jun 2012
    Hi
    Thanks that was my thoughts! I have ordered a separate unit. Thanks you gents.
