Nissan Bellhousing Compatibility Info - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 60 of 62
  1. #41
    Langs die rivier, op n berg
    Thanked: 2867
    Default Re: Nissan Bellhousing Compatibility Info
    Gilo het n adapters vir die td/qd na toyota gearboks....
  2. #42
    Nov 2017
    Strand
    Thanked: 80
    mods - sticky please
    '01 HB DC 3.2D 4X4 (SE)
  3. #43
    Thanked: 2867
    Why so bad on the fuel consumption?
    Standard Sani, non intercooled with 76mm straight exhaust on 245,75,15 tyres gave me 9-10km/l.
    31" tyres drop it to 8. The 33s drop me another km/l. I struggle to get 7,5-8 at the moment. And it will probably get worse when I add an additional 30% to the drive train drag with the second TC and that big ass rear diff.
    My consumption was swak, want my timing was uit. Gee my nou konstant 10km/liter, met firefighter, offroad, boot sleep, oop pad. Baie happy nou, en baie krag
  4. #44
    Thanked: 2867
    Td42, TD27ti, tb42, tb45, tb48 is almal dieselfde
    Td42 en td27/qd32/z30 hardbody is glad nie selfde nie.
  5. #45
    Jun 2012
    Capetown
    Thanked: 32
    Post Re: Nissan Bellhousing Compatibility Info
    Hi all we should add the VQ SERIES engine and gearbox combos too. since some of us are venturing and will venture in that directions too. a VG30 (hardbody v6) does NOT work on a VQ so if anyone know what box fits the VQ engine or even close will be a great help.
    as some may know i have aVQ30det( soon to be TT) project and have been looking for a compatible gearbox. a 350z box is a direct bolt in aswell as a v6 NAVARa box. but the prices are still more than i can pay. i have gotten myself a 2.5 6 speed Diesel NAVARA BOX and have not check if it will mate up to my motor. if it doesnt what the better option sell the box and get the 350z box? what can i get for the box it is a 6 speed after all. i will post a seperate post for this delema
  6. The Following 2 Users Say Thank You to nizmozilla For This Useful Post:
  7. #46
    Apr 2008
    My Nissan patrol VG30 1991 has a conrod through the block. I am looking to buy a brand new complete crated Nissan Vq25de engine with clutch for R15 000. To install in my Nissan 3L V6 4x4 bakkie. I also need advice on whether it will fit, and how to mate it to the VG30 gearbox. It will need an aftermarket engine management system. The Nissan VQ engines were rated among the 10 best engines in the world. I am hoping that the new technology engine will give me better fuel consumption.
  8. #47
    Apr 2008
    My Nissan patrol VG30 1991 has a conrod through the block on its third engine. I am looking to buy a brand new complete crated Nissan Vq25de engine with clutch for R15 000. To install in my Nissan 3L V6 4x4 bakkie. I also need advice on whether it will fit, and how to mate it to the VG30 gearbox. It will need an aftermarket engine management system. The Nissan VQ engines were rated among the 10 best engines in the world. I am hoping that the new technology engine will give me better fuel consumption. The VQ engine fits onto the 350z 6 speed box, I think. The engine output is similar to the VG30 I believe.
  9. #48
    Thanked: 12942
    Quote Originally Posted by HunterFisherman View Post
    As per nizmozilla's post on 2018/05/08, the VG and VQ are not compatible patterns.
    Rather buy a VG30E, VG30DE or VG30DET from an engine importer. As far as I know, the VG30DE is wider and might fit the RHD engine compartment but maybe have a look on the NISMO internet sites.
    http://forums.hybridz.org/topic/7783...to-d21/?page=2
    http://www.infamousnissan.com/forum/...ad.php?t=28837
    https://forums.nicoclub.com/vg30de-swap-t388660.html
    https://forums.nicoclub.com/help-nee...a-t592670.html
    https://www.nissanforums.com/hb-truc...zx-vg30de.html
  10. The Following User Says Thank You to jelo For This Useful Post:
  11. #49
    Jun 2012
    Capetown
    Thanked: 32
    yes the VG30 bell housing does not match up to a VQ engine. a good engineer can do a bell housing conversion or adapter plate but it does require some work. my VQ engine has a 6 speed Navara diezell box with a 350z bell housing welded to it. does require the engineer to have motor with flywheel clutch and gearbox to make this work. i was lucky i had a complete 350z(vQ35) bell housing to cut up. unfortunately the bell housing from the 350 and navara box are too different to just be mounted on the the navara box so this required weling it on. sounds crude but was done nicely.
    a 4L v6 navar box should be able to be bolted to the vq since the 4l is a VQ45. BUT since u running 4x4 and have more than 1 output that will requir some other work to make that work so thats a hole lot of other engineering and mounting etc to be fabricated plus the 4l 4x4 Navara box will cost a fortune.
    i think i coverd all the options.
  12. The Following 2 Users Say Thank You to nizmozilla For This Useful Post:
  13. #50
    Dec 2012
    Thanked: 23
    And here I was about to start a new thread about the Nissan vq25de engine. This time in my 2.4 double cab. Still running the KA engine, which is now on its way out, very little compression left in here. I suppose at over 460k on the clock it was bound to happen.
  14. #51
    Thanked: 2867
    Nog n rd28 na L28
  15. The Following User Says Thank You to Reenen For This Useful Post:
  16. #52
    Thanked: 12942
    Nog n rd28 na L28
    thanks
    very valuable photos
  17. #53
    Apr 2008
    Quote Originally Posted by nizmozilla View Post
    When the VQ25DE brand new crated and complete engine price dropped to R10 000, I could no longer resist, and it's now game on. The mechanic replacing the VG30 engine with it in my 4x4, is confident he can do it, especially with all the motor engineering skills in the Uitenhage, Dispatch and PE area. So watch this space, I'll post updates!
  18. The Following User Says Thank You to HunterFisherman For This Useful Post:
  19. #54
    Thanked: 12942
    you'll need an adapter plate at least, not sure who makes them
  20. #55
    Apr 2008
    I believe one of his engineering contacts has already made this, the VQ25DE flywheel also doesn't fit, so the VG30 flywheel has been engineered to fit. I will be visiting the project in this week, and post an update and pictures. I did receive the following photos so far.
  21. #56
    Thanked: 12942
    start a new thread please, I will update this thread if needed
  22. #57
    Apr 2008
    Here are the photos of the VQ25DE installation Click image for larger version.
  23. The Following User Says Thank You to HunterFisherman For This Useful Post:
  24. #58
    Apr 2008
    Photo of VQ25DE conversion
  25. The Following User Says Thank You to HunterFisherman For This Useful Post:
  26. #59
    Thanked: 12942
    Peter commented on converting a TB42/45 petrol to TD42 diesel:
    Re: Nissan Patrol info
    That is correct Jelo, except for the starter motor, which is different (3 bolts instead of two, with a larger spigot and with the bolts spread more widely apart).
    However, the actual bell housing casting is the same, IE there is room to machine a TB bell-housing out to fit the TD starter.
    Changing back from TD to TB is obviously a little bit more tricky...
  27. #60
    Thanked: 2867
    Daar is ook n lengte verskil tussen die diesel en petrol bellhousing op die patrol. So mens doen die swop met engine se bellhousing
