center locking mechanism
Results 1 to 5 of 5
    Aug 2019
    Nuremberg
    Default center locking mechanism
    I have pajero 3 3.2
    was setup 2din radio and now central locking mechanism wont work.
    only unlock the door on what the key
    byt when the car started, centrer locking its working, i try it with spare key
    p.s. its not remote key locking. its locking with key,
    what wire should i look and point
    thanks
    Feb 2012
    Bloubergrant
    Thanked: 137
    Default Re: center locking mechanism
    Unfortunately I have limited knowledge of electrical fault finding. My go to solution would be to take battery cables off for a while and reconnect, maybe that resets the system?
    2007 Hilux 2.5 D4D SOLD
    Aug 2019
    Nuremberg
    that was the first thing i try
    also some other things dont work, like console for temperature (air condition view, above radio), also radio
    i check most of the fuses, all are fine
    Feb 2019
    Thanked: 71
    Hi,
    I'd bet its a fuse that has blown. Are you aware there are two fuse boxes one at the drivers right knee (right hand drive) and one in the engine bay. I would check all of them again. Then start looking for issues with the double din installation.
    Hopefully this helps.
    Aug 2019
    Nuremberg
    its not fuse,
    I see on 3 main fuses, directly conected to + on battery, middle one 40A with red wire, when i take off the fuse its still same issue, so its main red wire, byt i put new fuse there still problem, maybe the wire its disconected somewhere, will take it to electricion to dive it
