Discovery 2: Td5 Oil pump life span?
Results 1 to 20 of 23
    Aug 2016
    South Norway
    Thanked: 54
    Default Td5 Oil pump life span?
    Sorry for my TD5 season. Its summer now in Norway I cant work in winter time in 1 m snow and -15
    Therefore advice and opinions appreciated.
    Whats the lifespan of the original pump?
    Do you advise i inspect mine? 244000km now
    Symptoms related to faulty pump
    Is the pump mechanical and all metal or can it be serviced?
    Thanked: 1485
    Default Re: Td5 Oil pump life span?
    Mine is on 360k and (without a mechanical test of it's delivery,) all seems good.
    As to symptoms of faults, I guess about the only one would be the low pressure light coming on, unless you plumb in a separate gauge that reads actual pressure.
    It is mechanical, I don't know if it's worth servicing, if it's worn a new one will likely be cheaper. I don't even think internal parts are available.
    The major issue with them is the bolt holding the chain wheel on is known to unscrew itself with suitably catastrophic problems when the pump stops working.
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  3. The Following User Says Thank You to JohnnoK For This Useful Post:
    Aug 2016
    South Norway
    Thanked: 54
    if its all metal and mechanical (no gaskets and with oil film bearings ) and the bolt doesn’t unscrew then it should in other words last as long as it has serviced oil?
    maybe someone has an exploded view of the pump?
    Thanked: 1485
    For all intents and purposes, yes.
    Here is a thread where a guy opened one up, but it isn't particularly detailed.
    https://www.aulro.com/afvb/projects-...d5-engine.html
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 9303
    No. All pumps wear. I'd replace at 200,000kms.
    Dec 2009
    Melkbosstrand
    Thanked: 331
    Coming loose maybe?
    Google TD5 oil pump bolt
    Rob
    V8 Defender 90 pickup. Lexus, Spitronics, 33" KL71, beadlocks, +2" Terrafirma, ATB's, 3.75 CW&P, 1.21 TC.
    Series IIA 88" pickup
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    MG TF160 VVC ZandF remapped
    Buell XB12R
    Thanked: 145
    Shortly after I purchased my Td5 in 2004 (it is a 1999 model) I got the local Indie to drop the sump, remove the oil pump bolt and refit with loctite. Turns out it was tight anyway, but I wasn't taking a chance.
    Darron John Misplon
    Land Rover Discovery 2 Td5 ES Manual (Loaded)
    BMW F30 320i Sport Auto
    BMW R1200 GS
    'One life-Make a difference"
  9. The Following User Says Thank You to Darron For This Useful Post:
    Aug 2016
    South Norway
    Thanked: 54
    Quote Originally Posted by Darron View Post
    Is this sprocket bolt given to fail at some time?
    Thanked: 145
    No, as posted earlier, some early models were not fitted with loctite at the factory during assembly.
    Darron John Misplon
    BMW R1200 GS
    Aug 2016
    South Norway
    Thanked: 54
    got a 2000, is this considered an early model?
  13. #11
    Thanked: 145
    I think the issues were mainly in the early 1999 models, but I stand to be corrected. Jelo?
    Darron John Misplon
    BMW R1200 GS
  14. #12
    Oct 2007
    Uitenhage
    Thanked: 328
    I thought they changed the design of the pump with the face lift in late 2002, or there about? I speak under correction.
    I'm pretty sure that all those that were going to fail would have done so by now.
    2004 Land Rover Discovery 2 Td5 ES
  15. #13
    Thanked: 9303
    sorry, not a TD5 guru, I do remember the pump bolt issue though and it would have manifested by now
    Just replace the pump. Do the water pump while you are busy.
    Any pump dies eventually, we had to replace the Jeep JK's oil pump last month as the oil pressure was sub-optimal.
  16. #14
    Thanked: 641
    There is a procedure in Rave to check the tolerances on the oil pump. They are expensive to replace but cheaper than overhauling the engine.
  17. #15
    Aug 2016
    South Norway
    Thanked: 54
    Ok now ime thinking oil preassure guage, if it drops the bolt is smoked or?
    where do i connect one? Is there something universal that can screw into a hole somewhere?
  18. #16
    Aug 2016
    South Norway
    Thanked: 54
    I think i will make an inspection upon my next oil shift, i also have Locktite 263 (red) at hand unless someone know about some specific threadlock for use in submeged oil.
  19. #17
    Thanked: 1485
    Quote Originally Posted by Loeksteyn View Post
    If the bolt unscrews the oil pump drive is lost and pressure is instantly zero. You MAY get lucky if you have a borescope to feed down the front cover to try and see if the screw is still secure, but my feeling is that your issue of low/dropping pressure is elsewhere.
    I'd start with the relief valve possibly sticking slightly open and bleeding flow off.
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  20. #18
    Nov 2006
    Edenglen
    Thanked: 105
    Mine was checked at around 210,000kms and the oil pressure was slightly down. Replaced it with a new one as a precaution.
    Although the new one was a genuine LR part, we had to tap one of the bolt holes as the thread wasn't cut properly.
    Erin Bosch (082 342 1909)
    4xfagger no. GP0048
    2001 Land Rover Defender 130 TD5 D/C with everything
  21. #19
    Aug 2016
    South Norway
    Thanked: 54
    What is normal for oil preassure for the td5 then?
  22. #20
    Thanked: 641
    As per the manual, 0.7 bar minimum, usually 1-1.2 at idle with auto box. The pressure release valve opens at around 4 bar.. I get 1.1 at idle and 2. 5+ at 2750 rpm.
