Speed limit with suspension max raised on GL
Results 1 to 6 of 6
    Oct 2008
    Montanapark Pretoria
    Default Speed limit with suspension max raised on GL
    Hi Everyone,
    Is there a way to increase the 20km/h speed limit on the GL with suspension raised max?
    "A day without laughter is a day wasted"
    M.Benz GL350CDi Be AMG 8) AKA "worshond"
    KTM 1190R Adventure
    Mooi River
    Default Re: Speed limit with suspension max raised on GL
    That will need someone who knows how to reprogram the car
    2000 Ford Courier DC 2.5TD 4x4
    2009 Fiat 500
    2001 Merc C200K
    2007 Disco 3 TDV6 manual
    Constantia Kloof
    Quote Originally Posted by Allegro View Post
    Hi Everyone,
    On the medium setting you should be able to do 80KM/H which is more than enough? Max setting is what, 300mm? with medium being around 280mm? when most 4x4 D/Cabs have a ground clearance around 225mm?
    Let me put it this way, my standard W164 ML 500 on raised suspension mode has never rubbed or scrubbed anywhere and would be equal to your medium setting.
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
    Oct 2008
    Quote Originally Posted by Koebelwagen View Post
    Thanks for the info, perhaps I should go RTFM
    KTM 1190R Adventure
    Worcester
    The max suspension setting is really a get out of deep SH#T setting, so there shouldn't be much need for it. We did Faces of the Namib using Level 1 most of the time and going to Level 2 only when necessary. Level 3 was used to get us out when beached or on one very rocky section, where speed is not an issue.
    Member of SSKSA
    Andre & Marlize
    Mine - '10 Isuzu KB240 S/C 4x4
    Hers - '09 Merc GL500
    '07 Isuzu KB240 D/C 4x2
    Oct 2008
    Yes, I noticed the same when I did de Wildt the other day.
    KTM 1190R Adventure
