Vibtation at 70 km/h
Results 1 to 20 of 30
    Jul 2007
    Thanked: 75
    Default Vibtation at 70 km/h
    I have a strange vibration on the Rok. It starts at about 65km/h hits its peak at exactly 70km/h and tapers off at 80... The steering wheel does not vibrate at all it feels as if its coming in from the chasis somehow.
    Its only speed related.
    The clutch can be in or out, any gear 3,4,5 or 6 its even there when free wheeling in neutral...
    I thinking that it may be the tyres...
    2011 VW Amarok BiTDI DC 4Motion
    (Ex) 2007 Mitsubishi Triton 2.5 DID DC 4x4
    (Ex) 2001 Mitsubishi Colt 2.8 TDI DC 4x4
    Thanked: 568
    Default Re: Vibtation at 70 km/h
    Sounds like a loose engine or gearbox mounting.
    Jul 2007
    Thanked: 75
    Would that not be ralated to the engine speed? The revs can be idle or 3000 rpm it makes no difference.
    Thanked: 568
    Quote Originally Posted by Cobus80 View Post
    I'm not so sure. It could be tyres. When last did you rotate them?
    Robertson/ Larissa, Greece
    Thanked: 3314
    On a bakkie that sounds like a typical universal joint problem. Can be rim or tire as well
  6. The Following 2 Users Say Thank You to Francois Theron For This Useful Post:
    Apr 2014
    Thanked: 17
    I had the same problem on my previous Amarok. They replaced the propshaft and all was good again.
  8. The Following User Says Thank You to Soundadv For This Useful Post:
    Feb 2012
    WC
    Thanked: 12
    hi, i had a vibration on a brand new rok from 120km/h to about 135km/h, VW could not resolve it over a period of about 6 months and eventually took the vehicle back but refused to replace it. Very bitter experience.
    Hope it gets ammicably resolved, all the best!
    Jul 2007
    Thanked: 75
    Its got two brand new tyres on the back... lost one last week in the baviaanskloof...
    Fronts are on the front for about 15000km.
    Thanked: 568
    Maybe not balanced properly?
    Jul 2007
    Thanked: 75
    Quote Originally Posted by Soundadv View Post
    Did you get the vibration even with no drive to wheels?
  13. #11
    Apr 2014
    Thanked: 17
    Do you mean when the clutch was engaged (pressed in)?
    Yes it was still there.
  14. #12
    Jul 2007
    Thanked: 75
    Yip, I can even go into neutral.
  15. #13
    Jan 2016
    Groot Gat
    Thanked: 29
    Mine does exactly the same. On 70km/h. Below 70km/h and above there is no vibration.
    I suspect it is the propshaft as i have 4 new Grabbers on and it still does it.
    And also you mostly feel it through the seat and not on the steering.
    If i got time will have it balanced and will report back.
    '10 Vw Amarok 2.0 BiTdi D/C 4trek
    Mikem Suspension Lift
  16. The Following User Says Thank You to StephanJvR For This Useful Post:
  17. #14
    Bethlehem
    Thanked: 4357
    Klink soos 'n U joint.
    2008 Mercedes Benz CL 500........................"Bullet" (going....going...)
    2006 Mercedes Benz C 180K........................"Sussie"
  18. #15
    Jun 2016
    Randfontein
    Thanked: 2075
    My bet would be on the rear wheels not being balanced or it can even be mud or something on it. It would be cheaper to start looking there as well. BTW I had a similar issue and found that they tried to seal my wheels so the wheel nuts were loose.
    Willie
    2020 Nissan NP300 2.5TDi S/C
  19. #16
    Bethlehem
    Thanked: 4357
    You prolly right F...........maybe just change the tyres back to front first and see what happens??
  20. The Following User Says Thank You to Petri Oosthuizen For This Useful Post:
    FWM
  21. #17
    Jan 2016
    Groot Gat
    Thanked: 29
    Everything checked & balanced on wheels on mine.
    Even fitted my spare set of 17" mags on with the new tyres and still the same.
    Was done on mine.
    Vibration was there before i fitted new tyres and still there.
  22. #18
    Apr 2014
    Thanked: 17
    Yes indeed. Same with mine.
  23. #19
    Thanked: 936
    Do you have a canopy? Mine behaves exactly the same and I know it is a resonance from the canopy.
    Perhaps yours is the same?
  24. #20
    Thanked: 11
    Mine has a similar vibration 60-100 km/h...sometimes at higher speeds too.
    I replaced the tires...no luck
    Removed the suspension and put back the original shocks and coils...no luck
    VW eventually replaced the propshaft...no luck
    Anyone want to buy my rok? I am now tired, gatvol and out of warranty...
    2014 AutoAmaRock
    RSI Signature Canopy
    Pirelli Scorpion ATR 265/70 R17
