Grand Vitara Engine
Results 1 to 17 of 17
    Jul 2015
    Default Grand Vitara Engine
    Hi
    I seem to have a problem with my 2009 Grand Vitara 2.4 auto.
    It recently recieved a new head, pistons, sleeves ( basically a rebuild).
    I have been driving it for about 3000km and it is using about 1pint of oil every time I refill for petrol. It seems there might be water also disapearing.
    There is no visable signs of leaking or smoking. I do however pick up that it seems there is smoke coming out of the dipstick hole and the oil refill cap(when removed).
    Something is wrong, don't know what. Would like to know what it is before I take if back to the mechanics.
    Ps: will it be able to replace the engine with the 3.2v6 easily?
    Thanked: 1451
    Default Re: Grand Vitara Engine
    Guess the rebuild wasn't good. Have it inspected at the person doing the rebuild.
    Sent from my iPhone
    Thanked: 245
    Who did the rebuild and why was it done?
    Suzi Blue , 2008 Nocturne Blue Suzuki Grand Vitara 3.2 V6
    Dobinson's 40mm suspension, Wizerd rock sliders, radiator, sump and diff plates
    Frontrunner RoofRack, NL 2nd Battery Box, Llumar sun protection
    16" Hyundai Tucson rims, 235/70R16 General Grabber AT3 tyres
    Thanked: 1267
    Prepare for a fight, maybe ask for a compression test and see if the results are what is expected after a rebuild.
    You could work the engine so that the rings will bed in properly, do this before you do the compression test and then you say you have worked the engine already.
    It should improve over time if they did the job properly, new sleeves/rebore, new rings etc.
    Of course, if they did not then then they will have to redo the job, but they will tell you the "rings are not bedded in yet", which is a standard reply...
    Dec 2010
    Thanked: 135
    Please share more info - year, mileage, why rebuilt engine, who did it etc.
    Jul 2015
    2009
    Rebuid was on 132K
    I bought it second hand from a dealer, took it back to them when i realised it was using oil.
    They fixed it on their cost, they have their own workshop.
    They replaced the cracked head, new pistons, rings and sleeves. They did a rebuild on the engine.
    How would I know if They did a good job or for that matter did what they say.
    Now, after 3k of driving it still uses oil
    Thanked: 1451
    Quote Originally Posted by armandearl View Post
    2009
    Rebuid was on 132K
    Speak to them again and explain the issue. This sort of thing should not be your problem.
    Sent from my iPhone
    Apr 2014
    Thanked: 17
    Yoh!! Now the second one with a a cracked head. Good luck with the fight!
    Thanked: 1451
    Quote Originally Posted by iondb View Post
    Apparently it is an issue with the pre-2012 models.
    Sent from my iPhone
  10. The Following User Says Thank You to Rebel 4x4 For This Useful Post:
    GKE
    Apr 2014
    Thanked: 17
    So, an issue with hairline cracks on some of the blocks for the first batches and now cracked heads on some until 2012.................hopefully these are sorted in the new models. We will only see when the younger models start to get mileage on I guess.
    Jan 2015
    Gladstone, QLD
    Thanked: 513
    If I recall correctly it was only on 2008 and 2009 models and confined to the 2.4 engine...Sorted in 2010. Can anyone second me on this?
    Dec 2010
    Thanked: 135
    There was a recall for the head, new ones are sorted.
    Thanked: 128
    I would perhaps start by asking for some invoices or a parts list on what they used for the rebuild? They could have used second hand or pirate parts in the rebuild- NOT accusing anyone- and in there, they might have used an older, second hand head from a pre-2012 2.4 engine. Again- I am also speculating and I am not accusing anyone of any wrongdoing.
    Although I would start by investigating the method and parts used during the "rebuild".
    2019 Ford Ranger Wildtrak 2.0L bi-turbo A/T 10Spd 4x4
    Venter Offroader 4x4 trailer with howling moon tent
    Previous: Suzuki GV 3.2 V6 A/T
    Current Platkar: BMW F30 330d A/T
  15. #14
    Swellendam
    Quote Originally Posted by SuzukiPiet View Post
    I have it in writing from Suzuki. 2008 only.
  16. #15
    Thanked: 21
    2009
    Rebuid was on 132K
    Was this a Suzuki Dealership or a Used Car Dealer?
    2008 SUZUKI GRAND VITARA 2,4 A/T
    WIZERD LIFT KIT, WIZERD BASH PLATES,
    WIZERD TRANSFER CASE PROTECTOR,
    WIZERD ROCKSLIDERS, 235/65/17 BRIDGESTONE A/T
    1984 SUZUKI SJ 410
  17. #16
    JHB
    Thanked: 83
    Quote Originally Posted by Ratsalad View Post
    What exactly did they change on the GV engine that prevents the new models from cracking the block
    2012 Pajero Sport 3.2 A/T
    2020 Forester 2.0IS CVT
    EX: 2001 colt V6, 2010 jimny
  18. #17
    Dec 2010
    Thanked: 135
    Quote Originally Posted by whatyamacallit View Post
    There was a slight change to the actual block design where it cracked - just a thicker webbing for casting or something like that. I'll try find the link to the change.
