Spare Fueltank - Leaking Caps
Results 1 to 9 of 9
    Apr 2016
    Umdloti
    Default Spare Fueltank - Leaking Caps
    Best Wishes for 2017 Everyone - May it be a year filled with lots of incredible adventures and special memories!
    Need some advice regarding diesel seeping through between the filler cap and aux tank, please.
    It comes through the "washers" at the bottom - any advice to rectify this or to change it?
    (Tanks were entirely DIY) - please see attachment for image.
    Look forward to any advice please.
    Heinrich
    @rontgen_za
    Isuzu KB300 Dteq 2010
    Jun 2016
    Default Re: Spare Fueltank - Leaking Caps
    Hi,
    That looks like a cap from a hydraulic oil tank and has a built in breather. It is not suitable for fuel.
    Apr 2016
    Umdloti
    Quote Originally Posted by John Allan View Post
    Hi,
    Thank you John, will look into it - appreciate the feedback.
    Heinrich
    @rontgen_za
    I'd say replace the cork washers with something actually sealable. Like silicon.
    Silicon not fuel resistant it will perish. Rubber seals.
    Quote Originally Posted by Jack Russell View Post
    That is true. Sorry.
    This will work:
    https://www.permatex.com/products/ga...lange-sealant/
    Apr 2016
    Umdloti
    This will work:
    Thank you very much, Jack Russell & Jelo - appreciate the assistance - will give it a try and let you know how it works.
    Heinrich
    @rontgen_za
    Brisbane
    Hi,
    Why not? What's the difference between diesel and hydraulic oil?
    Jun 2016
    The caps fitted to hydraulic oil tanks have high capacity breathers built into them to allow for the high flow rates of the hydraulic oil in the systems. Fuel, and especially petrol, is much more volatile than hydraulic oil. You are always going to get a lot of vapors and fumes coming through the cap. I suspect that the leak you see is vapors that have settled around the cap. This is also a safety risk.
