Discovery 2: TD5 - Crank Battery Replacement
Results 1 to 3 of 3
    Jul 2010
    Auckland Park - JHB
    Question TD5 - Crank Battery Replacement
    Hi all,
    Deltec HighCycle 102Ah crank battery on D2 TD5 auto needs replacing. Had contacts at Deltec and that's why I went this route at the time. Any suggestions regarding replacement brand, specs - am quite tight for moola at he moment.
    '02 Disco 2 TD 5 facelift, auto & Terrafirma +2" (retained air in back with +2" spacers) & what next
    Thanked: 14240
    Default Re: TD5 - Crank Battery Replacement
    Standard is a 671:
    94Ah, 600A cold crank
    http://www.dixonbatteries.co.za/671-premium
    Thanked: 14240
    And shop around, there are always specials at the tyre people.
    http://www.tyresandmore.com/products...turn1-battery/
  5. The Following User Says Thank You to jelo For This Useful Post:
