Engine does not start after putting the gearbox back - Page 5
Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 81 to 100 of 101
  1. #81
    Thanked: 393
    Default Re: Engine does not start after putting the gearbox back
    The Perkins?
  2. #82
    Gordon's Bay
    Thanked: 4378
    The Perkins?
    no, the gearbox. silly.
  3. #83
    Thanked: 393
    Hmmmm....post private pics VS lifetime forum ban.......
    Will have another look at the pics and will get back to you......
  4. #84
    Langebaan
    Hi Guys
    My normal route of troubleshooting is to eliminate the easiest and quickest checks:
    1) Take the battery to a proper supplier and have it load tested, they will clear this up without any questions.
    2) If you have a good battery in the vehicle, take care to connect up as someone mentioned, Batt positive onto Batt, BUT earth onto the engine direct to avoid voltage drop to the point required.
    3) If all good, remove the starter and bench test it, if it works then the problems lies deeper...................either double check installation or get help.
    4) If you removed the starter then make sure the hold down bolts are original and not longer, not sure how your vehicle is but many years back a longer bolt could actually lock upon the fly wheel and cause havoc on some older vehicles.
  5. #85
    Langs die rivier, op n berg
    Thanked: 2462
    Quote Originally Posted by chris novello View Post
    Hi Guys
    Die heel maklikste toets heel eerste, kyk of jy die engine met jou hand kan draai. As hy vas is, help dit niks om battery en starter te toets...
  6. The Following User Says Thank You to Reenen For This Useful Post:
  7. #86
    Dec 2013
    Bapsfontein
    Thanked: 159
    Gary het dan vertel die Barbie pop het n powerbar gebreek om die enjin te traai draai. Die bestw starter en battery gaan nie die ding draai as die enjin vassteek nie. En dis net nadat die gearbox uitgehaal was. So obviously het iemand daar tussen ratkas en enjin ### aangejaag. Gee al die boute skiet op die ratkas en check dan of die enjin steeds vas is. Ek post in afrikaans want dan kan die spanjaard nie verstaan nie.
    Defender powered by Isuzu
  8. #87
    Thanked: 10044
    Quote Originally Posted by CarloIsuzu View Post
    As ek reg onthou het Barbie dit ratkas oorgedoen ook.
  9. #88
    Thanked: 393
    My taal isnt what it should be......but the Jelo Miester be right. I tried a 1" power bar.....still nothing. Box needs to be pulled off the engine. Told the dude that much but he wants a freebie
  10. #89
    Thanked: 2462
    To be fair, it's his ex wife's box....
    (Ek was bang as ek dit in afrikaans post, word ek verban...)
  11. The Following User Says Thank You to Reenen For This Useful Post:
  12. #90
    Thanked: 393
    Quote Originally Posted by Reenen;346445in 6 years
    And only used twice in 6 years.........
  13. #91
    Thanked: 2462
    Het jy haar toe uitgehelp met n service op haar box?
  14. The Following User Says Thank You to Reenen For This Useful Post:
  15. #92
    Thanked: 393
    I know nothing
  16. #93
    Mar 2014
    Ermelo
    Thanked: 109
    Is the box at least selecting low range? Or is it full of spiderwebs? Oil thick?
    Four wheels move the body,
    Landys move the soul.
    0614512283
    Current: Discovery 1 V8i
    Next landy, D3 V8 HSE Previous one.D1 300 TDi donkey, D1 V8 Fuel THIEF!!! freelander 1, biggest pos known to man,
  17. #94
    Wilderness
    Thanked: 1073
    This looks like the box torture from the Spanish inquisition? Nogals breakin 1/2" powerbars. She must be a tough nut (box) to crack!
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  18. #95
    Thanked: 393
    Spiderwebs removed and all gears (high & low range) were in 100% working condition by the time I was finished with my Inspection/annual birthday service.
  19. #96
    Thanked: 393
    Seems like the blind dudes back.....
    http://www.4x4community.co.za/forum/...t=#post3555790
    http://www.4x4community.co.za/forum/...ionally-beyond
    Funny thing is that he's looking for a "co-driver/adventurer" but fails to mention that the Landys carnet as well as his visa has expired...
    Also no mention of the fact that he's clinically blind.....
  20. #97
    Sep 2014
    Thanked: 90
    @ GaryFrank
    Cant you just collect and keep the car until he pays you?
    Wolverine : 93' Range Rover Classic 3.9L EFI
  21. #98
    Hillcrest, Malaysia
    Thanked: 5950
    Unbelievable. I've followed this issue from the start.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  22. #99
    Thanked: 393
    Quote Originally Posted by whosthejman View Post
    @ GaryFrank
    Unfortunately I cant attach the Landy, its not on my premises...
    In theory, it now belongs to the SA gov, and as such cannot be stripped for parts.....either the dude pays a fat fine or it gets crushed.
  23. #100
    Thanked: 10044
    "I may not ask you for anything other than your share of gas and some other expenses that may arise along the way (e.g. repairs)."
    Nice how he casually ends the sentence with potentially the biggest problem.............
  24. The Following User Says Thank You to jelo For This Useful Post:
