JK 2 DR Long Range Tank
Results 1 to 5 of 5
    Thanked: 361
    Default JK 2 DR Long Range Tank
    Are these available in SA?
    Who manufactures them if they are and where?
    Capacity/volume?
    Pump or gravity fed?
    Approximate cost?
    Any info is appreciated.
    Ross
    Sep 2015
    Mt. Edgecombe
    Thanked: 18
    Default Re: JK 2 DR Long Range Tank
    Maniac in CT has a 60l for a JKU (4 door) but also for a 2 door, don't know the capacity.
    Pumping the fuel from the aux tank back to the main tank with an electric pump.
    Frontrunner in J'burg has a similar system, but they told me its only for diesel engines. Don't know why.
    Hve he Maniac tank build in for my JKU, so far no problems, it jus takes a while to fill it up via the small filler pipe.
    Pietersburg
    Quote Originally Posted by Slainte View Post
    Rough cost estimate?
    Deon
    If you can't fix it with a hammer,you have an electrical problem...
    Sep 2015
    Mt. Edgecombe
    Thanked: 18
    Frontrunner see www.frontrunner.co.za
    Maniac see www.maniac4x4.co.za
    I paid about 7 or 8 kZAR for my tank
    Thanked: 16
    I got a quote for a long range tank from Maniac about 3 years ago. If I remember correctly it was an additional 40l with an electric pump, and would cost R6000 installed back then.
    2010 Jeep Wrangler Rubicon 3.8l
    3" J-Spec & Bilstein Suspension Lift
    Bilstein Steering Damper
    JKA Front Stubby Bumper
    33" Cooper ST Maxx
    Superchips Flashpaq
    Frontrunner Slimline II Roofrack
