Is my load bin loose?????
Results 1 to 20 of 27
    SECUNDA
    Default Is my load bin loose?????
    Hi all.
    I fitted an RSI canopy.
    When I drive over small bumps it is like my load bin is loose or something.
    Its quite irritating.
    The canopy is held down nicely.
    This is with no load.
    Will test with a load.
    Any one have this problem?
    Thanked: 880
    Default Re: Is my load bin loose?????
    There should be zero play on any loadbin.
    What makes you think it is loose?
    Did you experience this before or after the RSI fitment?
    SECUNDA
    After fitment.
    I can hear the load bin shaking and I can see it moving when I look through rear window.
    Jan 2016
    Moloto Road,R573
    When you pull and shake it. Is there any play?
    BIGGER THE BUILD-UP,,,THE BIGGER THE BLOW
    JHB
    Thanked: 126
    The cab is mounted to the chassis at 6 places, on rubber buffers. The loadbin is also mount at 6 places, but directly to the chassis(metal to metal)
    A bit of movement is normal, as the cab will have a little movement on the chassis. This bit of movement is now noticeable because you have a reference between the cab and the canopy.
    If however there is any noise, klanking etc, your loadbin may be loose. Get in under the bakkie and re-tighten the loadbin bolts.
    2012 Bi Turbo 4Motion, on Bilsteins with a 50mm suspension lift and 20mm body lift. 76mm pipe and software.
  6. The Following User Says Thank You to JohnBoy For This Useful Post:
    Jan 2016
    Moloto Road,R573
    JohnBoy is absolutely right. Could'nt write it better myself. If there is any looseness, I would take it in to the dealers if it where me.
    SECUNDA
    Nothing seems to be loose when I shake the canopy and all.
    Only when driving over bumps in the road or gravel road that I hear the shaking noise. duddd dud dud dud.
    Thanked: 1051
    Is your spare wheel solidly fixed? The sound could be coming from there?
    Thanked: 1189
    Could be the canopy touching the cab somewhere...
    Toyota FJ Cruiser
    BMW F800GS
    When in doubt, paint it black
    Postmasburg
    Shock?
    SECUNDA
    Nope
    Not a shock or spare wheel.
    Will go to vw. They must check.
    Thanked: 1051
    Rublux, make very sure it's not the spare wheel - mine had a similar rattle after I fitted larger tyres. The spare wheel was basically able to move a bit up and down on the sides. The centre was solid. I hope I'm making myself clear here..
    It was simply a case of adjusting it and it's perfect now.
    SECUNDA
    Hi Johan.
    Het gekyk. Spaarwiel is mooi vas.
    As ek oor hobbels ry en ek kyk deur die agter ruit dan kan ek sien hoe beweeg die canopy.
  15. #14
    Thanked: 1051
    Eish, in daai geval moet jy hom dadelik invat. Daar kan niks goed van kom om dit te los nie.
    Dis eintlik snaaks, want die canopy bout net vas binne die bak - so dit maak nie sin dat die bak nou los is nie? Of vermoed jy hy was nog altyd los?
  16. #15
    SECUNDA
    Die geluid en die beweging is daar vandat ek die canopy op gesit het in Junie/Julie.
    Dit raak irriterend.
  17. #16
    Harrismith
    Ek het ń Andycab canopy en hy maak ook so
  18. #17
    Jan 2014
    Northern KZN
    Thanked: 225
    My ondervinding met altwee my Amaroks was dat dit die Canopy self is wat teen die Cab stamp. In my geval n Beekman canopy gewees. Later vervang met `n RSI en die probleem is weg.
    Groetnis
  19. #18
    Thanked: 3653
    Myne maak ook so. Klink asof die canopy teen iets skaaf. Ek het n Airite op. Myne skaaf definitief nerens teen die cab nie. Dis meer asof dit die canopy self is wat flex. Dink maar net nie die veselglas het dieselfde structural integrity van die Alu produkte nie.
    VW Touareg V6 Tdi Escape
    Bush Lapa Boskriek 816
  20. #19
    Portchefstroom
    Thanked: 8
    Nou die dag in my pasin gery hy het beekman een dink ek maak net so sal my lam maak hehe
  21. #20
    Sep 2016
    Brackenfell
    Quote Originally Posted by RUBLUX View Post
    Hi all.
    I have exactly the same problem. I have now noticed the gap between the cab and the load bin on left hand size is wider than the other side. Will have it checked out tomorrow.
    2013 VW Amarok 132kw 4x2 (M)
  22. The Following User Says Thank You to Slaqq For This Useful Post:
