Results 1 to 3 of 3
Thread: Gearbox noise
    Thanked: 9
    Default Gearbox noise
    Any suggestions on a 5th and sixth gear thats noisy on a 2l steed 4x4?Bearing problems or can i use another oil?As noisy from the day i bought it.Dealer said they all got that noise.100 000 0n the clock.
    Ford Ranger 2.2 4x4 2018
    Jeep 3.7 Cherokee 4x4 1996
    Toyota Raider SFA 2.2 4X4 1994
    Jun 2016
    Randfontein
    Thanked: 4041
    Default Re: Gearbox noise
    Mine had sticky gears and was also a bit noisy so i bought Wynns gear oil treatment and assembly lube. R85 from Midas per tube. Put one in the diff and one in the gearbox and problem solved. That stuff is magic.
    Willie Knoetze
    2019 Nissan NP300 2.5tdi d/c 4x4
    Thanked: 9
    Maybe i should just drain a little bit bit of oil and see if there is any trace of metal?Then its a bearing and no oil can fix that!
