Defender My Defender is broken.... - Page 2
Results 21 to 40 of 43
  1. #21
    Witfield, Boksburg
    Default Re: My Defender is broken....
    Got it out on Friday and dropped it off at The Gearbox Company and they allready found the issue and they started fixing it
ID:	428958Click image for larger version.
ID:	428959Click image for larger version.
ID:	428960Click image for larger version.
ID:	428961Click image for larger version.
ID:	428962Click image for larger version.
    Chris
    "Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing" Helen Keller
    1996 Range Rover P38 4,6 HSE
    1977 LandRover Series III 109" Project
  2. #22
    So what is the issue?
    '89 LR 110 V8
  3. #23
    Witfield, Boksburg
    The bearing/bearings? seized where the output shaft of the gearbox goes into the transfercase, this seized all the gears, luckily no damage to the main gears.
    And then all the spider gears including the whole 3rd diff portion is damaged on the inside (no chims between the spider gears could be found )
    That's what I can remember from the phone call.
    They are going to replace what needs replacing, using a recon unit for the 3rd diff part, and all the seals and gaskets etc.
    So it will be like new again
    Chris
  4. #24
    Witfield, Boksburg
    Got it back this morning, all new and shiny!
    Chris
  5. #25
    Nice !! Is it running yet !
    2004 Defender TD5
    1992 Defender 3.5V8
    PROJECT OVERHAUL http://4x4community.co.za/forum/show...oject+overhaul
  6. #26
    Witfield, Boksburg
    Quote Originally Posted by johannes14 View Post
    Nope,still at work....
    Tomorrow morning is go time
    Chris
  7. #27
    Witfield, Boksburg
    It's back in and working perfectly
    Chris
  8. #28
    Lonehill, JHB
    Quote Originally Posted by Crips View Post
    Great news, what did this lot cost you if I may ask?
    2014 Pajero 3.2DiD SWB
  9. #29
    May 2008
    Well done! Did you change it to Left hand drive too??
    Flip
    Member: 4x4 Action Group - GP0026 & Suzuki4x4GP
    Awesome: Suzuki Jimny;
  10. #30
    Witfield, Boksburg
    Quote Originally Posted by Flipside View Post
    That's my little brother
    Chris
  11. #31
    Witfield, Boksburg
    Quote Originally Posted by KurtG View Post
    Removed and installed it myself and replaced the oil in both diffs and the gearbox.
    Recon of the transfer case about R12k
    Oils R700
    Labour was free but took almost 1day to remove and another day to install.
    Chris
  12. #32
    And the satisfaction of a job well done. Priceless!
  13. #33
    What caused it?
  14. #34
    Witfield, Boksburg
    What caused it?
    Not sure but I think it's 260000km of wear and tear, heavy offroad use, towing quite often and not enough maintenance, like regular oil changes and making sure oil level is correct.
    Chris
  15. #35
    Sep 2010
    London/Cape Town
    I have three friends with 2012-2014 Puma Defenders. One (2.2) is on his 3rd gearbox (tows a lot) and another (2.4) on his 2nd. The other guy's only problem so far has been a blown turbo elbow (known problem recalled on some - I got him a silicone replacement).
    The irony is that the cause of the gearbox/Xfer problem is the same that LR had when the R380 came out - lack of sufficient lubrication of the output shaft to Xfer case. Just like defective oil pumps, it seems LR manages to duplicate known problem areas even in completely new vehicle designs...?
  16. #36
    Fourways Gardens
    Quote Originally Posted by CanAmSteve View Post
    It can be fixed permanently courtesy of Ashcroft
    http://www.ashcroft-transmissions.co...shaft-kit.html
    Series III 88"
    Scout Nomad
  17. #37
    Witfield, Boksburg
    Luckily no gearbox issues (touch wood)
    But apparently in the 80s and early 90s land rover recomended ATF oil for the R380 but it was to thin, especially in our climate, they then changed it to some other fancy oil (can't recall the name)
    I mixed 2l of ATF with 2l of EP90 and then used that to refill the gearbox, it's alot smoother and runs quite a bit cooler for longer (you can feel the heat difference in the cab)
    Chris
  18. #38
    Mar 2015
    New Germany
    I have always only used ATF and now using Valvoline Dextron 6 fully synthetic had the box opened to check at 360000 and was perfect inside, I change the oil every 40k
    1995 300TDi Defender with VGT Turbo
  19. #39
    But apparently in the 80s and early 90s land rover recomended ATF oil for the R380 but it was too thin, especially in our climate, they then changed it to some other fancy oil (can't recall the name)
    I always had the same opinion. I can't understand how they expect an ATF to work like an MTF. IMHO, BOT402/Castrol Syntrans should be the correct oil for a full synchro manual box.
    Stealers also recommend long life oils in their axles and boxes: not necessarily the best option for people who want to do over 200,000kms on their rigs.
  20. #40
    Springs
    have had excellent results with 75W90 full synthetic eg Castrol Syntrans in the R380
    have not tried in the dead of winter but smooth action and quiet running.
    pretty sure temps are down as well but cannot quantify
