Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 65
Thread: Peg hammers
    Mar 2011
    Walker Bay
    Thanked: 1392
    Default Peg hammers
    Which hammers do you recommend for tent pegs.
    I see there are some fancy hammers available - are they worth while.
    The Thor Deadblow 3lb hammer sells for R349!
    Feb 2008
    Thanked: 3538
    Default Re: Peg hammers
    The good old-fashioned hard rubber head hammers work fine for me. When using 18 or 20mm rebar pegs into hard ground like the Tankwa, I use a three pound hammer.
    Tony Weaver
    1991 Land Rover 110 Hi-Line S/W 3.5l V8 carburettor
    Cooper Discoverer STT tyres, four sleeper Echo rooftop tent
    2012 Mitsubishi Outlander.
    Previously Land Rover 1968 SII, 1969 SIIA, 1973 SIII, 1983 Toyota HiLux 2litre, 2006 Land Rover Freelander TD4 HSE.
    Jan 2010
    Thanked: 6487
    This8)
    Christa
    Wartburg
    Thanked: 2613
    Many like the rubber mallets, like above. I prefer the 3 pound steel hammer. It's also smaller than the mallet for packing purposes, and is useful to have in your toolbox (#1 LR tool )
    Mike Lauterbach
    Thanked: 49
    This8)
    Find the steel shaft ones twist in your hand.
    Bought a
    MASTERCRAFT 60MM Dead blow Hammer
    Never looked back.
    Has some kind of Inertia center.
    Find fellow campers coming to loan mine all the time.
    1996 : 80 Series Landcruiser 4500 GX SW
    Thanked: 203
    That is a good price!
    Isuzu Frontier 280LX 4x4 2001
    May 2015
    Thanked: 21
    I use a copper head hammer the best for 20yrs now
    Aug 2008
    Thanked: 73
    If the ground's that hard, use a 150mm long X <peg dia concrete drill in your battery drilling machine.
    Your mind is your strongest weapon.
    Then there's.....POWER TOOLS!
    '94 LC 80 GX
    '00 Frontier 280DT 4X2
    2002 Sprite Surfer Nomad
    Klerksdorp
    Thanked: 64
    Sometimes I've experienced more difficulty getting the pegs out than in! What do you do when the pegs just do not want to budge on pulling them out? In these cases I end up pulling them out with pliers with a twisting motion
    The plastic pegs especially can be really tough in sticky clay type soil. The last time I had this issue we had to run a big flat screwdriver down the sides of the peg to 'let go' of the soil
    2009 Toyota Fortuner 3.0 d-4d 4x2
    Custom off-road trailer with Echo TTT
    Wartburg
    Thanked: 2613
    I normally use the big L shaped pegs to pull out stubborn ones.
    Mike Lauterbach
    Melbourne
    Thanked: 155
    Dead blow hammer is R170 at Adendorfs
    Wartburg
    Thanked: 2613
    A dead blow hammer will be better than the rubber mallet, which bounces back from a hard surface, which is why I don't like the rubber mallets. It will also not slip as easily off the pegs than the metal 3 pound hammer which I've used to date.
    Maybe I'll swop to the dead blow hammer as well....
    Mike Lauterbach
    Plett/Paulshof
    Thanked: 1649
    Quote Originally Posted by LenArtman View Post
    Bought a
    Never looked back.
    Agree 100%. Got mine in bright orange from campworld so easy to see!
    Bruce Hunter. 2021 Defender D240HSE,2019 FJ Cruiser, Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), Bush Lapa Kewer 2202, Fusion 17 boat-Yamaha FT100hp 4st.
    Thanked: 247
    If you are on really hard ground and know getting the
    pegs out will be a problem then when you start packing up walk around with a 2l bottle of water and pour a good glug onto each peg. By the time you are almost done pulling the pegs is much easier.
    4x4 less.
  15. The Following 4 Users Say Thank You to Brian1 For This Useful Post:
  16. #15
    May 2010
    Bergbron, Roodepoort
    Thanked: 253
    Bought a
    Never looked back.
    Also got the same hammer just a cheaper version of the Mastercraft one
    For paved stands I use thicker pegs and a claw hammer.
  17. #16
    Oct 2015
    centurion
    I use one of these. Aluminium, very effective.
  18. The Following User Says Thank You to Pilgrim For This Useful Post:
  19. #17
    Nov 2006
    Thanked: 488
    The heavier the hammer the easier the job.
    Forget about rubber, plastic etc.
    Get a small sledge hammer type head, cheapest from Agri.
  20. #18
    Apr 2012
    Bela Bela
    Thanked: 371
    I have tried a rubber mallet and a deadblow hammer but did not like either.
    I now use a 1.1kg sledge hammer.
    For extraction I made up a puller using 10mm square bar with a chain link welded on the end.
    Pete Williamson
    ADVENTURE BEFORE DEMENTIA
  21. The Following 2 Users Say Thank You to petewill For This Useful Post:
  22. #19
    Mar 2011
    Walker Bay
    Thanked: 1392
    That puller looks excellent - better than commercially available items!
  23. The Following User Says Thank You to Paul Dold For This Useful Post:
  24. #20
    King Williams Town
    Thanked: 1994
    Very true,I found rubber hammers tend to bend my cheap tent pegs in hard soil,but using a proper hammer it drives the peg in first time with no bending.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
