Discovery 4 V8 service schedule after 100k km?
Results 1 to 20 of 26
    Thanked: 324
    Default V8 service schedule after 100k km?
    Anybody got a list of what gets serviced at what km readings?
    Oct 2006
    Thanked: 152
    Default Re: V8 service schedule after 100k km?
    My V8 was serviced mostly by Walter at LRXtreme after 100 000km. Every service all oils and filters etc were changed, as far as I remember all the same oils and filters every time. At 120 000km it is advisable to put Dr Tranny and flush the gearbox. At 140 000km I had to replace the water pump again (first done at 93 000km), as well as a water pipe. Brake disks you can expect to have to replace between 120 000 and 140 000km. Somewhere the pollen filter was also changed - can't remember the intervals.
    Service intervals used to be 12 000km, but somewhere along the line LR changed service intervals to 28 000km - based on what I am not sure. Due to this change I was not sure whether to change to 28 000 km service intervals for my 2010 model and mailed LR Centurion. They confirmed the change to 28 000km even for my 2010 model. The computer at LRX also changed the interval to 28 000km / 1 year before the service required warning came up, so I decided to stick to 28 000km intervals. The last service I had done was with Peter at Landyworx during the time when Walter was moving to the British 4x4 shop and I couldn't get a spot in his schedule. The Landyworx computer reset the service required interval back to 12 000km. Landyworx also put a sticker on the window showing next service due in 12 000km, so in the end I wasn't sure which way to go - 12 000 or 28 000 km intervals?
    Current: Touareg V6 TDi
    Ex: Discovery 4 V8 - Sold at 149 000 km. Awesome vehicle, but a bottomless pit.
    Ex: Fortuner D4D - Best vehicle I've owned Sold at 267 000 km.
    Ex: Hilux 2.7i - sold at 241 000 km.
    Ex: Hilux D4D - sold at 330 000 km.
    Kenridge
    Thanked: 97
    This may help a bit:
    Some lessons were hard learnt by the Cape Land Rover Club, some come from the Disco 3 forum in the UK (excellent source of info) and some from personal experience.
    @ 100 000 km:
    - remove CAT
    - blank off EGR’s. But NOT on post-2007 models – will result in a permanent dash alarm
    - replace thermostat housing (aka water manifold) every 100 000km
    - service air suspension compressor – check / replace valves and silica gel or replace compressor with AMK version (AMK requires software upgrade, should come with new housing etc – a mod, not a straight replacement))
    - replace lower control arm bushes
    - check/replace steering arm balljoints or replace steering rack
    - check/replace battery and check alternator
    - check / replace rear diff oil – if contaminated, check / replace rear diff actuator motor
    - replace brake light switch to avoid Christmas tree heartstopping experience!
    - replace turbo inlet hose
    @ 120 000 km:
    - consider turbo service, especially actuator
    - replace wheel bearings
    - check / overhaul / replace alternator
    - replace water hoses with silicone versions
    2005 Disco 3 TDV6
    Thanked: 324
    Thanks all.
    George mine is the NA V8 petrol and not the diesel.
    Plett/Paulshof
    Thanked: 925
    I would not service 28000km's but every 12000.
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa ?, Fusion 17 boat-Yamaha FT100hp 4st.
    Thanked: 139
    The Range Rover is serviced every 12000kms though it is supposed to be serviced every 24000kms - with the mileage (about 40000kms) I do it means 3 services per year.
    Now the D3 only does about 8000kms per year and is serviced once a year.
    Better to spend money on services than to get a surprise when least expected.
    2007 Disco3 (SWAMBO)
    2004 Merc platkar (SWAMBO) - no more
    gti-eater (opel gte)
    Oct 2006
    Thanked: 152
    Quote Originally Posted by vnitos View Post
    Jip, totally agree. One of the reasons I never felt comfortable with my V8 and eventually sold it is there are so few of them on the road that there is a real scarcity of info on them so you are never 100% sure you are not inadvertently building a time bomb even when you follow LR's directions.
    Thanked: 324
    OK,
    I am planning to do an oil change every 12000km, but what gets serviced every 24000km then?
    What needs to be replaced at what km reading?
    Trying to budget for the big services.
    Thanked: 324
    Resurrecting one of my old threads.
    Anybody else on specifics for servicing what at what kilometres?
    Forest Hills, KZN
    Thanked: 782
    No specifics as such, but I have done / will do:
    12000km
    Oil
    24000km
    Filters (Air only as no fuel filter) and also oil.
    80 000km
    Spark plugs i believe
    Every 160 000km
    Gearbox double flush (i did mine at 140k km) and will do again at 280k km.
    Brakes I check as they go and see how they are doing each service. So far the powerbrake is amazing. After 20k km the discs look still new and the pads are wearing well. I presume to get about 80k km out of them.
    I'll try find more info on recommended schedules and what gets done.
    2004 LR Discovery 2 Td5 GS - Hybrid Turbo, Intercooler, 33's, 2" Lift, V8 TC, Ashcroft CW&P 3.75 + ATB lockers. (Ingwe)
    Thanked: 324
    12000km
    Oil
    24000km
    80 000km
    Every 160 000km
    Thanks a stack. Was looking at the Powerbrake option over the weekend and the prices seems decent.
    Are there anything like a cambelt service that I need to save for?
    Will also replace my waterpump at 130k.
    Have done the gearbox double flush at 110k
    Forest Hills, KZN
    Thanked: 782
    Powerbrake better and cheaper than stock.
    V8 has chain, no cambelt, so all good there.
    I think i'll do waterpump at next major service. Has already been done at 100k km.
    May 2010
    Bergbron, Roodepoort
    Thanked: 221
    I regestered here. http://www.roverparts.com
    They offer a very detailed schedule in pdf format of what needs to be done on my Disco 2 and when, maybe they have the same kind of schedule for your Disco.
  14. The Following User Says Thank You to Flagster For This Useful Post:
  15. #14
    Forest Hills, KZN
    Thanked: 782
    Quote Originally Posted by Flagster View Post
    Just registered but they have nothing listed for the LR4 as yet.
    Thanks though.
  16. #15
    Forest Hills, KZN
    Thanked: 782
    See attached what I just found...
  17. #16
    Thanked: 324
    Wowww thanks a stack.
    Looking at 120k service I see they indicate the following:
    Change rear locking differential oil
    Change transfer box oil; replace drain and fill plugs and washers
    Was not aware the transfer box oil is seperate from the gearbox.
  18. #17
    Forest Hills, KZN
    Thanked: 782
    Wasn't aware of that either... will change to my indy and see what they say.
  19. #18
    Thanked: 324
    https://www.youtube.com/watch?v=WovObbfStf4
  20. #19
    Oct 2006
    Thanked: 152
    80k km would be really good. If you can achieve that, then it would take away one of the regular expenses on these heavy beasts. It would be interesting to get feedback one day when you have to change the pads.
  21. #20
    Feb 2012
    Thanked: 368
    12000km
    Oil
    24000km
    80 000km
    Every 160 000km
    Who did the double flush for you? I'm thinking mine is due.
    Regards,
    William
    D4 v8 --Sold
    Quote Originally Posted by Murray Walker
    “I don't make mistakes. I make prophecies which immediately turn out to be wrong.”
