Help needed with Wheelnuts and Caps please
Results 1 to 7 of 7
    PTA
    Default Help needed with Wheelnuts and Caps please
    Hi All
    Not sure if this is the correct place
    However, I need help and advice with the following please:
    Vehicle is a 94 Daihatsu Rocky
    1) Where can I get wheelnuts as per picture. Autozone has the correct thread, but the taper shoulder they have is far too small.
    2) Where can I get caps to fill those ugly holes? Diameter of the centre hole is 105 mm. Anything around I can Chop, Change or Modify?
    Dankie solank
    Mike
ID:	424684   Click image for larger version.
ID:	424685   Click image for larger version.
    Thanked: 14187
    Default Re: Help needed with Wheelnuts and Caps please
    What is the PCD on that rim?
    PTA
    PCD
    About 140mm
    Thanked: 14187
    Quote Originally Posted by 110Mike View Post
    PCD
    About 140mm
    try Suzuki
    Thanked: 14187
  6. The Following User Says Thank You to jelo For This Useful Post:
    Jun 2015
    PTA
    Thanked: 82
    Tyremart Silverlakes helped me for free when I needed some
    Thanked: 732
    I've spent too much time running around looking for nuts that fit specific alloys. I only have one rule, and that is to fit the OEM nuts for the allow rim. this is a major cause of loosing wheels, because the nut does not have the necessary friction to stay put. Scrapyards or agents??
  9. The Following User Says Thank You to Heinz Modricky For This Useful Post:
