Defender Defender V8 Lexus queries
Results 1 to 20 of 145
Hybrid View
    Apr 2016
    Default Defender V8 Lexus queries
    Hi guys - we are busy completing the V8 Lexus conversion (with the Lexus auto-box) in my 2007 110 and I have a couple of queries:
    1) We are currently getting some pretty poor fuel consumption figures. Anybody out there who has done the conversion and can share some real world figures with me?
    2) Have you changed your diff ratio's and, if so, to what?
    3) I have a bit of a shudder on pull-off, have you experienced this?
    4) What air-filter setup are you running?
    Thanks.
    BRAKPAN
    Thanked: 31
    Default Re: Defender V8 Lexus queries
    Average fuel consumption = 5km/l
    Have achieved 7.5km/l with light foot and no wind @ 100km/h.
    Pulls uphill @ 100km/h with half throttle, plenty power in reserve.
    It does lack torque, as the motor must be revved more compared to a diesel, and
    when that auto kicks down on an uphill, then it really wants to go.
    You don't really want to go more than 120km/h in a Defender, and with the V8
    uphills are no longer an issue, if i compare it to my 300Tdi.
    Shudder on pull away could be fuel related, more delivery to the pump from what
    i have experienced.
    The TC was stopped for a Disco1 V8's, don't expect a huge difference.
    If you don't drive like a yahoo, i think the diffs should be fine.
    Keep in mind, anything can be broken, if you try hard enough LOL.
    Swambo has a D90 with Lexus, auto, and Spittronix.
    There is now too much wiring, much more than i like in a Defender.
    1997 defender 90 300tdi
    2006 discovery 3 tdv6 S
    2010 polo vivo ( swambo )
    LROC - member since 2007
    Thanked: 14187
    Shaun, explain your opinion of poor fuel consumption.
    New Germany
    Thanked: 503
    Diff ratio is 3.54 on all coil sprung defenders and disco's if you have rover long nose Diffs front and back I think like the 90 and disco,you can get 2.78 crown wheel and pinions. the defender has rover long nose front and p38 or salsbary back and you can not get lower then 3.54 for the back or go 35" tires will help
    changing of the transfer case ratio gears from 1.44 to 1.22 and also get a 1.003 are your options
    and in my opinion I would not touch spitronics, you would be better off using the original Lexus ECU or go megasquirt 3
    my defender is running LS1 megasquirt ECU 4l80e auto and LT230 with 1.22 gears which I am changing next year to 1.003 and using 35" tires
    At 120 I want to do 1900 to 2000 RPM at moment doing around 2300
    2005 Defender TD5
    Thanked: 14187
    I'd also stick to a front cut if I didn't have a Spitronics boffin close by.
    New Germany
    Thanked: 503
    Is spitronics fully sequential or batch fire
    2005 Defender TD5
    Apr 2017
    anyone still on this thread
    Hi Clive did you ever manage to change the transfer case ratios to 1.003 I recently changed mine to 1.2 from 1.4 and its made the world of a difference on the top gears i now cruise at 120kmph at around 2700 rpm with 31 inch tyres . i want to drop the ratios even further but want to hear from someone who has already made the change 110 defender stock 3uz ecu with a 2 inch lift and standard 3.5 diffs
    thanks
    Plettenberg
    Thanked: 108
    Quote Originally Posted by Pavli View Post
    thanks
    I would think stay as is. I changed from 1.2 to 1.4, but that is with a 1UZ and autobox. 265/75 R16 tyres.
  9. The Following User Says Thank You to Wilk For This Useful Post:
    Aug 2010
    Bellville
    Thanked: 30
    With my old Pajero LWB lexus with Spitronics, with trailer and four kids, I got 7.5km/l going to Seweweekspoort last week, 4x4 and all. Cruising speed 95-110, revving 2400-2900rpm. Having researched the LS400 forums extensively, they seem to get best mileage at 65mph/104kph doing 2400rpm. My best to date was 9.3km/l doing 90-95kph (unladen), in town I get 5-6km/l. Verify that your Lambda sensor is working fine, this can mess your fuel computing around, especially on oem ecu.
    As for air filters, nice big donaldson should do the job, but ensure your housing is big enough, can breathe properly, and provide enough air.
    No idea on diff ratios for the Defender, but 2400-2600 should be ideal for cruising. If required, I drop a gear or two to overtake. I trust you can get it sorted easily enough!
    youtube clips
    Gen 2 2.8TDi, running with a Lexus heart since 290000kms
    - developed a drinking problem since - V8 inception 2014/03/28
    - looking up after some driver rehabilitation and fine tuning (5.5-8.7km/l) 2015/08/14
    - keep the wheels on the ground at all times - 2014/12/04
    - body maintenance completed -
    2015/02/19
    Thanked: 2895
    Quote Originally Posted by larry007 View Post
    Larry I tend to agree with you. This is where we plan to be with my sons Hilux 2400 to 2600rpm at 120.
    I have spend many hours calculating ratios for the Lexus converssion.
    Before I would do a ratio change I rather would have cams cut to 4x4 profiles on the Lexus. This move the torque peak to a lower band.
    Both my 347 and 302 Rangers do 2200rpm @120. The 302 average around 6.5km/[email protected] on the open road.
  12. #11
    Aug 2010
    Bellville
    Thanked: 30
    Mr V8... Doing those cams will surely address the performance under 3000rpm. Everyone on this forum should up to date that the lexus is lazy under 3000rpm, I can attest to that. Not that I will attempt it, but I would like to know the outcome thereof.
    Having said that, the motor still surprises when doing slow stuff, like idling over rocks. I was obviously concerned about the 4x4 capabilities of the Lexus, but in turn I am pleasantly surprised and happy with it, it merely idles through - better than I could have hoped for!
    I suspect that cam will make a difference when pulling a laden trailer and you are stuck behind a truck uphill, easily cruising along, but then want to overtake. I have often found 4th at 80 (2800) doesn't have the oompth, and then drop it to 3rd to ensure a safe and quick overtake - with acceleration so glorious one forgets about the trailer... and this is with a baby v8 compared to yours...
    youtube clips
    2015/02/19
  13. #12
    Thanked: 2895
    Post Re: Defender V8 Lexus queries
    I run the R380 vs Lexus AE650 on the http://www.grimmjeeper.com/gears.html ratio calculator.
    Ratio of above mentioned boxes really close.
    Agree with Hagu13 if a Rover v8 can run those ratio`s a Lexus should do better.
    Me think the Lexus in this conversion is out of tune.
  14. #13
    May 2011
    doonside
    Thanked: 6
    Yes the series 3 cw bolts up to the defender carrier but it does not work. Need a spacer ring machined first to space the cw away drop the carrier. About 5mm.
    Wesley
    1988 Range Rover 4 door. 2.7 turbo diesel. 4.7:1 diff ratios. 2" body lift. 255/85R16 maxxis bighorn's + camel cut. AKA: shady
    A true oil burner that runs on Black Diesel.
  15. The Following User Says Thank You to wild spike For This Useful Post:
  16. #14
    Thanked: 448
    Thanks WildSpike....that should shut the Jello-lush up for a bit
    So basically the Series pinion is thinner in diameter and the CG needs to be spaced to compensate.......
    AFAIK the Rover pumpkin bolts in, the Sailsbury is mounted in the diff and has a loose cover....thats why I say fit the complete pumpkin.
  17. #15
    Thanked: 14187
    Quote Originally Posted by GaryFrank View Post
    Jello-lush
    that coming from my Vaaljapie Cuz from the Cape.....
    I need to come and visit. We can destroy the last bit of our livers.
  18. #16
    Thanked: 14187
    Quote Originally Posted by wild spike View Post
    great stuff.
    Read that somewhere, now that I think about it.
    So a nice new standard 4.7 set and a spacer?
    here we go:
    http://www.ashcroft-transmissions.co...acer-ring.html
  19. #17
    Thanked: 448
    and he calls me a geriatric old fart......
    now tell me if you got the 5.7.......
  20. #18
    Thanked: 14187
    5.57 you old knob
  21. #19
    Thanked: 448
    Eish----old timers
    Im just gonna stick to my Series from now on.....
