Defender Defender V8 Lexus queries - Page 8
Page 8 of 8 FirstFirst 1 2 3 4 5 6 7 8
Results 141 to 145 of 145
  1. #141
    Mar 2015
    New Germany
    Thanked: 503
    Default Re: Defender V8 Lexus queries
    Quote Originally Posted by Pavli View Post
    Thanks Clive will look into the gear set change.
    Lockers and gear Ratios are next on my agenda to change
    if you're ever looking to sell that transfer case with the 1.003 ratios let me know
    thanks for the help
    this is a good gear calculator http://www.grimmjeeper.com/gears.html
    will do about case but no rush to sell it
    2005 Defender TD5
  2. #142
    Plettenberg
    Thanked: 108
    Cool Re: Defender V8 Lexus queries
    Thanks for the feedback
    flip...... i was hoping not hear that
    I see Ashcroft do a 1.100 which might be a better fit i would like to bring down my revs to around 2300 doing 120kmph
    cruising at that rev range would be great for long trips and great for fuel efficiency
    What were your revs like with 1.003 ? not enough torque?
    thanks for the help
    flip... So you want to change your final gear ratio to the same as a LEXUS 430 platkar. If I remember clivemd also had a thread about going to 1.003 I also mentioned at the time that in my view that is low. And that with a Yank V8.
  3. #143
    Mar 2015
    New Germany
    Thanked: 503
    Quote Originally Posted by Wilk View Post
    The 1.003 is mainly for the big Diesal conversions where you need the low RPM
    At 120 I was doing 1840RPM was nice for cruising but not good low down as the 4L80e Auto has a high 1st and 2nd compared to the 4L60e
    2005 Defender TD5
  4. #144
    Thanked: 14188
    Ashcrofts has a gear ratio calculator with preset options for defender and discovery among others.
  5. The Following User Says Thank You to jelo For This Useful Post:
  6. #145
    Apr 2017
Name:	Screenshot 2019-06-12 16.47.56.png
    so these are the numbers from ashcroft for the 1.100 gear set
    @120kmph its at 2372 rpm.........for cruising this would be ideal ideal at the moment im sitting at around 2700 doing 120kmph with the 1.2 ratio set
