Defender Defender V8 Lexus queries - Page 5
Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 81 to 100 of 145
  1. #81
    Aug 2010
    Thanked: 16
    Default Re: Defender V8 Lexus queries
    It has been mentioned a few times by a few people here, the Lexus develops at least 300nm torque from just above startup to red line. First make sure the engine is running 100% before changing gearing, tires and the like. 4000rpm in a 4l v8 at 120. My little 1300 spins at 3500 with a third of the torque and about half the mass. Even the 3L V6 ford courier ran at 3000rpm at 120 and that thing was a lazy donkey with a torque peak of only +-200nm.
    So far all evidence you have posted is pointing to one unhappy V8.
    I thought I was wrong, but I was mistaken.
  2. #82
    Thanked: 14188
    I'll take the non running LexFender for a nominal fee, say R25k?
  3. #83
    Apr 2016
    SO - had the Defender on the dyno yesterday. It was confirmed that it is running very rich at open throttle. The guy here has actually done a few Lexus conversions so I believe he knows a bit about the engines (he has a Lexus in a Range Rover of his). He has a chip system that he will put in so that we can adjust the fuel ratio's.
    He did however say that my diff ratio's are way too high geared at the standard 3.54 and I should look at a diff ratio of 4.1 and up for the vehicle.
    So that pretty much leaves me back at the original problem of sourcing diff that I have been struggling to do. It looks like my only option at the moment is to import the Ashcroft CW&P from the UK. Not looking forward to those import duties and VAT.
  4. #84
    Thanked: 53
    Quote Originally Posted by shauncooper View Post
    I would rather change the transfer case instead of spending plenty $$$ on 4.1 CW&P's
    The transfer case swap only affects high range gearing. The 4.1's might be too low for low range, unless you're running big tires.
    Jean
    '98 Defender 90 2.8i aka "saad van die psigopaat"
    Defender - http://www.youtube.com/watch?v=y0YKlc8Cwrs
  5. #85
    Apr 2016
    From a pricing perspective, the Ashcroft CW&P's are GPB500 shipped (about R9k) and add in some import duty and VAT, you're likely up to about R11.5k.
    I have been quoted a second hand transfer case for R7,500 but that means I also have to send them my transfer case from East London which I'm guessing will be about R1,500 to ship (I think its to Cape Town) so about R9,000 in total for a used TC.
    I hear your concern though on the low range...
  6. #86
    Thanked: 14188
    All prices being equal, just do the Ashcrofts CW&P
  7. #87
    Thanked: 448
    I still dont seen the problem Series 3 diffs (complete) can be picked up for R1, 5k each.
    With a grinder and a welding machine, anythings possible. If push comes to shove, cut off the pumpkin mounting plate or make a new one.....playing doesn't cost a cent if you DIY.
    Hell, if you can fit Toy diffs under a Defender, anythings possible
  8. #88
    Mar 2015
    New Germany
    Thanked: 503
    has yours Defender got the P38 diff in the back if so Ashcrofts do a stock 3.54 and 4.10 C&P and for the Front it is a rover long nose which they do the following stock 3.54 and HD(heavy duty) 3.5 3.75 4.12 4.37 4.75 so looking at the C&P don't think you can match up unless you use 4.10 and a 4.12 maybe see what KAM do in C&Pyour other option is T-Case with 1.667with my build i am getting rid of the P38 and putting a Long nose in the back so can run HD 3.5 C&P as there P38 selection is very minimal try this link for gear ratio `http://www.grimmjeeper.com/gears.html
    2005 Defender TD5
  9. #89
    Thanked: 14188
    and all you need from a Series 3 diff is the CW&P
    Gary, don't the Series Rover CW&P fit the later Rover carrier?
  10. #90
    Thanked: 448
    I think there mybe a spline issue but other than tht, dont see anything else..
    I do know that the Rngy pumpkins have to be worked to fit the Disco 2 diffs.
  11. #91
    Kathu
    Thanked: 2895
    For the sake of interest, what was the dyno results.
  12. #92
    Thanked: 14188
    no read my post you old geriatric fart
    Series CROWN WHEEL: does it fit the later Rover CENTER PORTION? The splines are part of the center portion
  13. The Following User Says Thank You to jelo For This Useful Post:
  14. #93
    Dec 2014
    Thanked: 1915
    That's you told, Gary!
    Even if it does fit, you will also need the pinion wheel to match, so that needs to fit, too.
  15. The Following User Says Thank You to JohnnoK For This Useful Post:
  16. #94
    Thanked: 14188
    Ja OK so here is Differentials 101
    I need the Old Fart to see if the Bevel Ring Gear (also called the crown wheel) fits on the later Differential Cage (also called the center portion). Yes, the Bevel Pinion and Pinion Shaft (commonly just called the pinion) must fit the center portion casing properly, but that SHOULD be fine if the "nose" of the casing is the same. There WERE short nose and long nose casings, hence my question to Old Fart.
  17. #95
    Thanked: 448
    Eish, this oldtimers thing is taking its toll.....
    Funny thing is that Rob was in last month to rebuild his pumpkin.....
    I've never tried mix matching CG and Pinions into the other carriers. I normally just move the whole pumpkin over......
    Damn it, ask me Series questions while I can still answer them.......
    (Johno you sod, just wait until you want to "borrow" an LT230 TC again......)
  18. #96
    doonside
    Yes the series 3 cw bolts up to the defender carrier but it does not work. Need a spacer ring machined first to space the cw away drop the carrier. About 5mm.
    Wesley
    1988 Range Rover 4 door. 2.7 turbo diesel. 4.7:1 diff ratios. 2" body lift. 255/85R16 maxxis bighorn's + camel cut. AKA: shady
    A true oil burner that runs on Black Diesel.
  19. The Following User Says Thank You to wild spike For This Useful Post:
  20. #97
    Thanked: 448
    Thanks WildSpike....that should shut the Jello-lush up for a bit
    So basically the Series pinion is thinner in diameter and the CG needs to be spaced to compensate.......
    AFAIK the Rover pumpkin bolts in, the Sailsbury is mounted in the diff and has a loose cover....thats why I say fit the complete pumpkin.
  21. #98
    Thanked: 448
    5.7........
  22. #99
    Thanked: 14188
    Quote Originally Posted by wild spike View Post
    great stuff.
    Read that somewhere, now that I think about it.
    So a nice new standard 4.7 set and a spacer?
    here we go:
    http://www.ashcroft-transmissions.co...acer-ring.html
  23. #100
    Thanked: 14188
    Jello-lush
    that coming from my Vaaljapie Cuz from the Cape.....
    I need to come and visit. We can destroy the last bit of our livers.
