Defender How to get a nipple in here? ... a grease nipple.
Results 1 to 15 of 15
    Oct 2014
    JHB
    Thanked: 20
    Default How to get a nipple in here? ... a grease nipple.
    Howzit guys,
    I've some threads on the net about the clutch pivot bearing ad solving the noise/squeak...
    My Td5 doesn't have a thread in the clutch pedal box/housing to screw the grease fitting into.
    Any ideas? Can it be done on my Landy?
ID:	422662   Click image for larger version.
    Aug 2014
    Oppi plaas
    Thanked: 786
    Default Re: How to get a nipple in here? ... a grease nipple.
    Miks, this is what I did, and it's still quiet after 18 months.
    http://www.4x4community.co.za/forum/...edy?highlight=
    Oct 2014
    JHB
    Thanked: 20
    Thanks Bosvark, I'll look into it.
    Would still love some help with the grease nipple - anyone?
    Oct 2014
    JHB
    Thanked: 20
    Bump...
    Oct 2014
    JHB
    Thanked: 20
    Bump..
    Oct 2014
    JHB
    Thanked: 20
    Apologies for digging up an old thread.
    Where does the grease nipple fit into? I have been driving the car a lot again lately and the squeak is driving me mad.
    There does not seem to be a tapped hole in my Td5's clutch box, where the later Defenders seem to have it.
    Hopefully this doesn't mean I need to remove and dissemble the box, to get to the parts that need lubrication
    Fourways Gardens
    Thanked: 584
    Quote Originally Posted by miks. View Post
    Miks forget the nipple. Its not that effective. Just open the peddle box from the top (6 screws iirc), and spray liquid grease all over tgw shaft, spring and linkages. Close up and you done. Mine hasnt squeaked in over a year.
    Series III 88"
    Scout Nomad
  8. The Following 2 Users Say Thank You to ClaudeG For This Useful Post:
    Fourways Gardens
    Thanked: 584
    Any of these 2Click image for larger version.
    Series III 88"
    Scout Nomad
  10. The Following 2 Users Say Thank You to ClaudeG For This Useful Post:
    Oct 2014
    JHB
    Thanked: 20
    Got it - thanks Claude
    Oct 2015
    Thanked: 69
    How can grease in a bush not be effective?
    Spraying lube on the outside of a bush would be rather.
    Has anyobe drilled a hole into the shaft of the non nipple mod on a td5? Tapped with a grease nipple?
    I should think that the inner workings of the bush would work the same? Shall I drill a hole and tap it for a nipple?
    My only worry is that there might not be internal ports for the grease on the bush?
    ONE LIFE!
  13. #11
    Fourways Gardens
    Thanked: 584
    Just spray it with grease...easy peasy
    Series III 88"
    Scout Nomad
  14. #12
    Oct 2015
    Thanked: 69
    Can anyone confirm that all clutch pedal shafts has the grease ports in the as to go ahead abd fix a nipple to it to insert grease into?
    ONE LIFE!
  15. #13
    Apr 2011
    Thanked: 1003
    I did the whole nipple thing on my one Puma. Worked for a few weeks and then the squeak returned.
    There after I just do what Claude suggested every now and again and it seems to work better to prevent squeaks.
  16. #14
    Apr 2011
    Thanked: 1003
    So much of funny in this post
  17. #15
    Oct 2015
    Thanked: 69
    O my genade, defenetief nie die vraag wat ek wou vra nie.
    Wil net weet of die as die geboorde gate in het om die grease te versprei?
    ONE LIFE!
