Defender Oil leak between bell housing and engine
Results 1 to 5 of 5
    Exclamation Oil leak between bell housing and engine
    Hai all
    My TD5 has developed an oil leak on die bottom two bolts connecting the bell housing to the engine.
    The LR has also started to shudder when pulling away.
    Could the root cause be the crank oil seal?
    And will I have to replace my clutch?
    Thanks in advance for the feadback.
    Thanked: 13638
    Default Re: Oil leak between bell housing and engine
    That's the crank end seal. Known issue on the TD5 if I recall.
    And yes, oil on the clutch means a new clutch and pressure plate.
    Jan 2016
    Boksburg
    Hi
    Try to determine if it is engine oil or gearbox oil
    Hi Banjo
    Yes it is engine oil.
    Do you possibly know how much it will cost me to replace the clutch and crank end seal will cost jelo?
    Thanked: 13638
    Quote Originally Posted by Defender 90 lover View Post
    Hi Banjo
    Nope sorry. Ask LRExtreme what they will charge you. It's a sod of a job.
