Bought a SC 4x4 2005 2.0, power tips?
Results 1 to 2 of 2
    Feb 2015
    Cape Town / Seattle
    Default Bought a SC 4x4 2005 2.0, power tips?
    Still have to collect it and it's in daily use. As I've read this is a Peugeot motor? Thinking of servicing injectors and timing the pump. What components are prone to failure on these motors?
    Changed all timing components and injectors on a friends Land Rover tdi so hoping the diesel basics are the same?
    Am I correct in believing that the 4x4 gets about 10km/L and 4x2 gets 11.5-12? Why is this?
    Thanks!
    Feb 2015
    Cape Town / Seattle
    Default Re: Bought a SC 4x4 2005 2.0, power tips?
    Also, forgot to say I'm swapping the running cars motor into the better body, so will be removing the lot over and building up one using best bits.
    Do I need any specific tools to change timing belt?
    And what motor is in a 2005 4x4 model?
