Trailblazer limited slip diff and smaller sparer wheel
Results 1 to 4 of 4
    Apr 2014
    Somerset West near Cape Town South Africa
    Thanked: 11
    Default Trailblazer limited slip diff and smaller sparer wheel
    My son mentioned where he worked the bakkies has limited slip diffs, the company trying to save money put a smaller size tyre on a rear wheel, after a few km's the diff was destroyed. With that in mind would a Trailblazer diff become damaged if the smaller spare when was used on the rear? And will GM cover the cost of a new rear diff?
    Just something to consider
    2013 Chev Trailblazer 2.8 4x4 auto.
    Brackenfell
    Thanked: 192
    Default Re: Trailblazer limited slip diff and smaller sparer wheel
    I was informed not to put the spare om the rear wheels but rather change with the front and put the correct size wheel on the back in case of a flat on either rear wheels.
    Uys Snyders
    Trailblazer 2.8DuraMax
    Bushlapa Vlooi B237
    Midrand (moving around too much)
    Thanked: 869
    Quote Originally Posted by Uys Snyders View Post
    If this is in the manual then GM will not take any responsibility.
    Stay Safe
    Disco-Deon
    This morning I woke up,
    Making today a great day.
    Nerdy, 2011 Honda Jazz, 1500 Exc
    Apr 2014
    Thanked: 11
    I just checked the owners manual and there is no mention of this whatsoever.
    I got around this conundrum by throwing out the 245/70/16 tyre and fitting a 265/70/16 on the spare wheel. The difference in diameter is around 2mm which is nothing in the great scheme of things
