300tdi Turbo recon/upgrade - Page 2
Results 21 to 33 of 33
    Sep 2016
    Hectorspruit
    Thanked: 62
    Default Re: 300tdi Turbo recon/upgrade
    Quote Originally Posted by Turksvy View Post
    Just a bit of an update.
    Thanks for all the comments and advice. I ended up doing the turbo upgrade through Stallion Turbos. They took a little longer due to some miscommunication but their work is solid. I ended up fitting a new radiator along with the upgraded turbo and the difference is phenominal!! Took the old lady to Kosi bay and Bhanga Nek and she performed beautifully. The turbo really makes a massive difference for that extra bit of power needed in soft sand at lower RPMs.
    At Kosi she did burst the oil cooling pipe (the one with the crimped piece of steel) but theres a guy in Manguzi (Andre) who's shop quickly sorted me out.
    All in all = turbo was definitely my money's worth!
    What did the turbo cost?
    Thanked: 87
    + 1 on the cost please as well
    thks
    Nov 2014
    Thanked: 15
    Quote Originally Posted by KoosDup View Post
    I paid R6000 including VAT. Took the turbo with the manifold for them and received the entire setup cleaned, upgraded and sprayed with some sort of coating.
    Turksvy
    "Stoffel" 2007 Landrover Discovery 3 TDV6 SE (with some add-ons)
    "Daisy" 1969 Landrover Series 2A 2.6L
    "Snaartjie" 1998 Landrover Discovery 1 300tdi (Sold unfortunately)
    Thanked: 87
    The coating must be that stuff herr Bosch talks about
    i had mine done by stallion but no coating around 3 years ago for 4500 so u must have hade the same inards changed as mine
    agree it made a difference as well
    to add
    the turbo herr Bosch is talking about is a 15 or 20 k thing and if u impressed with this increase in driveability then that turbo - i saw his - a lump about the size of the QE2 should blow your socks off
  5. #25
    Sep 2016
    Hectorspruit
    Thanked: 62
    Good investment! Fitting a bigger intercooler with this upgraded turbo, will that give even better performance? If so , where to fit and at what cost?
  6. #26
    Thanked: 87
    Koos
    i fitted the bigger intercooler first - about a year before my stallion turbo upgrade -
    and the bigger intercooler had more effect by far than the turbo upgrade
    i did the turbo upgrade purely cause I had dxcess money at that point and not cause thd old turbo was sub standard
  7. The Following 2 Users Say Thank You to RossJ For This Useful Post:
  8. #27
    Thanked: 451
    Quote Originally Posted by RossJ View Post
    Koos
    Hi Ross
    did you further tweak the injector pump, once the hybrid turbo was fitted? The hybrid turbo gives you loads of low down torque, if the pump is properly set up and the bigger intercooler lowers the EGT.
    There are a few tricks to get the 300Tdi to really kick ass below 2300rpm
    George Bosch
    Distributor for:
  9. #28
    Thanked: 451
    Koos
    And RossJ got that Allisport intercooler from me, when I upgraded for their biggest OEM version
    George Bosch
    Distributor for:
  10. #29
    Sep 2016
    Hectorspruit
    Thanked: 62
    Are these Allisport intercoolers freely available or only from specific suppliers? Am I correct in assuming that the turbo will help more with lowdown power?
  11. #30
    Thanked: 87
    Koos
    My impression was that the intercooler gave me low down grunt - 1200 rpm , so what was available at say 1600 is now at 1200 or max 1300 rpm , as well as breathing easier above 2700
    The turbo I think gave me far more in the 2500 plus range in that overtaking trucks etc has been halved so no need to do a detailed plan for the manouver
    In the beginning I used to catch myself after the overtaking manouver reaching to switch the aircon back on only to realise it was on all the time
  12. #31
    Sep 2016
    Hectorspruit
    Thanked: 62
    Thnks Ross, so where do I get this intercooler
  13. #32
    Thanked: 451
    Hi Koos
    you can get it from Baben at Torqtune www.torqtune.co.za Anthony Walley [email protected]
    George Bosch
    Distributor for:
  14. The Following User Says Thank You to hgbosch For This Useful Post:
  15. #33
    Sep 2016
    Hectorspruit
    Thanked: 62
    Hi Koos
    Thanks George
