Defender Sliding Window replacement.
Results 1 to 9 of 9
    Jun 2016
    Cape town
    Default Defender Sliding Window replacement.
    Hi Everyone.
    I'm back again with some more questions as I always get amazing advice on here.
    So I'm planning on replacing the rear sliding windows in my 2002 defender 90 td5 with a solid glass as I never open them and they just leak, rattle and drive me nuts. Also the Solid glass pane actually looks really nice.
    I was thinking of fitting the panorama glass but unfortunately my bank account won't allow it.
    I went to Glassfit earlier today and they told me that they can't do it because its Armoured glass.
    So my question is, has anyone done this and where did you get it done and how much did it cost all in?
    Thanks In advance.
    Thanked: 12
    Default Re: Sliding Window replacement.
    If you go to someone like PG, they can make a template and send it off for the curved pane of glass to be made. In about a week you should have it.
    I just went through the process after a glass top of a coffee table was shattered.
  3. The Following User Says Thank You to Eben For This Useful Post:
    Jun 2016
    Cape town
    Thanks Eben. I'll go try that. Hopefully it won't be too expensive.
    Thanked: 12
    Quote Originally Posted by Theo Botha View Post
    I was pleasantly surprised as to how cheap a piece of armoured glass is.
    Nov 2006
    Lonehill
    Thanked: 334
    I have a set of brand new puma ones that will not rattle if anyone is interested
    BruceT
    ZS6EBT
    Defender 130 Puma
    Jun 2016
    Cape town
    Hi Bruce. I have the Puma style frames atm. I bought a Puma roof and sides to convert my pick up into a station wagon.
    Only Problem is that the one side had some damage and the &*%$# who fixed it put the window frame back with Rivets from the outside, Much like you would fit the older style frames, so obviously this looks terrible. That's another reason why I have to replace them.
    Do you have any Idea how the Puma frames are fitted? I had quick look the other day but can't figure out how, maybe bonded to the side or something? That's the reason why I'm planning on fitting the older Td5 style frames, straight forward 24 rivets.
    Nov 2006
    Lonehill
    Thanked: 334
    Hi Theo,
    Yes they are bonded to the vehicle but they also have little plastic "wedges" to keep them in place.
    BruceT
    ZS6EBT
    Defender 130 Puma
    Jun 2016
    Cape town
    Thanks Bruce, will check it out.
    Do you have any idea with what they are bonded?
    Nov 2006
    Lonehill
    Thanked: 334
    IIRC it was a 0.8mm double sided tape but Im sure you could use a silicon type product to bond them with also.
    BruceT
    ZS6EBT
    Defender 130 Puma
  11. The Following User Says Thank You to BruceT For This Useful Post:
