2000 LC 105 GX 4.5EFI Service
Results 1 to 16 of 16
    Jul 2015
    Garsfontein
    Thanked: 147
    Default 2000 LC 105 GX 4.5EFI Service
    Took my 2000 LC 105 GX 4.5EFI in for a 160000k service this morning. I said check EVERYTHING. We are doing the "Faces of the Namib" tour in Desember.
    The only thing I noticed was a very small leak at the transfer case.
    Got the phone call a bit later.
    (hope I am saying this correctly) Main engine seal leaking - must replace and while it is open do the clutch and bearing - R18 500.00
    Front knuckles leaking - replace seals - R6670.00
    Rear brake pads + handbrake shoes - replace - 4590.00
    Sumps - reseal - 3400.00
    Transfer case - replace seal - R1350.00
    Normal major service - R 11500.00
    Total: R 46000.00
    I told them to go ahead, but:
    Is it necessary to do all of this to be on the safe side? The so called leaks must be very minor, as my paving is clean of any oil (accept for the transfer case)
    The vehicle is also 16 years old, so is it time anyway to have this done?
    Flip le Roux
    2012 Fortuner D4D 4x4 Auto
    2016 Jurgens Exclusive
    2014 BMW R1200RT
    2016 BMW F800GS ADV
    2016 Kia Picanto - Swambo
    2019 2.2 Ranger D/C XLS 4x4 Auto - Work
    GP0015
    Nigel
    Thanked: 2283
    Default Re: 2000 LC 105 GX 4.5EFI Service
    Eina. I wouldn't spend that money. If there is no problem with the clutch, leave it be. They saw you coming.
    Uniglide
    +27 zero eight 2 four 95 9252
    Jul 2015
    Garsfontein
    Thanked: 147
    Thanx Henris, I think so to.
    Phoned them back and said: do the service, transfer case leak and brakes only.
    Flip le Roux
    2014 BMW R1200RT
    2016 BMW F800GS ADV
    GP0015
  4. The Following User Says Thank You to Riekielouw For This Useful Post:
    Jul 2010
    Garsfontein, Pretoria
    Thanked: 436
    What Henris said.....
    And as I said. Let them do the service. Then take it to N1 4x4 that specialises in cruisers. And let them look at the rest.
    Johan De Graaf
    2019 Ford Ranger Wildtrak 2.0 Biturbo 4x2 D/C
    2013 Range Rover e-vogue HSE Dynamic SD4
    2010 Range Rover Vogue TDV8
    Nigel
    Thanked: 2283
    The sweating at the knuckles is fairly normal.
    If it is not dripping oil, it can wait.
    That clutch is as tough as nails. If it feels good, it is good. I have the same size clutch in the Troopie and it is still fine, at 280,000km.
    What you could do, is to replace all the fluids, if they were not done in the last 40,000km.
    Uniglide
    Jul 2015
    Garsfontein
    Thanked: 147
    Quote Originally Posted by Oldtimer View Post
    Thanks for the advice buurman.......
    Flip le Roux
    2014 BMW R1200RT
    2016 BMW F800GS ADV
    GP0015
    Thanked: 13546
    You took your 160,000km LC to a dealer and said quote on everything?
  9. The Following User Says Thank You to jelo For This Useful Post:
    Jul 2015
    Garsfontein
    Thanked: 147
    Yea, I was obviously not thinking.......but so we learn......luckily only a quote....
    Flip le Roux
    2014 BMW R1200RT
    2016 BMW F800GS ADV
    GP0015
    Jul 2015
    Garsfontein
    Thanked: 147
    Included in the major service quote.
    Flip le Roux
    2014 BMW R1200RT
    2016 BMW F800GS ADV
    GP0015
    Dec 2013
    Thanked: 17
    Quote Originally Posted by Riekielouw View Post
    How is a major service R11k? 160k km service on FJ is R4k, inclusive all diff fluids etc.
  13. #11
    Garden Route
    Thanked: 108
    At 160000km you're crazy to go anywhere near a dealer . There are PLENTY good indies who will see you right for MUCH less money . I go to a dealer when there is no other alternative & that is not very often
  14. The Following User Says Thank You to rodneykdc For This Useful Post:
  15. #12
    Robertson/ Larissa, Greece
    Thanked: 3287
    Flip I have had 3 Cruisers over the years and had my share of problems and wear and tear items. I would have all the things attended to that you mention, maybe just use a reliable indy instead a a dealer.
    Cruisers, as most big tough 4x4's are not cheap to maintain and at times big money needs to be spent to keep it going for some time to come.
    In my opinion any leak or sweat should be attended to. But then I am a bit anal about vehicle maintenance
  16. #13
    Oct 2006
    Thanked: 152
    Quote Originally Posted by jarnojvv View Post
    My thought exactly. R11k is WAY too much.
    Current: Touareg V6 TDi
    Ex: Discovery 4 V8 - Sold at 149 000 km. Awesome vehicle, but a bottomless pit.
    Ex: Fortuner D4D - Best vehicle I've owned Sold at 267 000 km.
    Ex: Hilux 2.7i - sold at 241 000 km.
    Ex: Hilux D4D - sold at 330 000 km.
  17. #14
    Thanked: 344
    N1 4x4 don't always use genuine parts. Go to Ralph at Toyo Service Centre in Krugersdorp, 011 660 8834.
    http://www.toyoservicecentre.co.za/
  18. #15
    Nigel
    Thanked: 2283
    The whole Genuine part thing is a fallacy. They use OEM parts. Even the dealers.
    Uniglide
  19. #16
    Thanked: 344
    Perhaps but the rear propshaft oil seal on the transfercase from N1 4x4 leaked more than the old one and the one from Toyota not a drop after 4 years. Their manual locking hubs that look like Aisin, even gold in colour, will cost me R8.9k while Aisin is close to R20k. Will you be as comfortable with them as with originals? I really would like to know as the first time the auto hubs break I will fit manual.
    Also compare an OEM dieselfilter with a Fram or GUD and see the difference. Guess from below the original can be recognised.
    https://www.facebook.com/JbsAutoRepa...354095/?type=3
