D4: Low Battery Warning - "Please start vehicle" with CTEK
Page 1 of 8 1 2 3 4 5 6 7 8 LastLast
Results 1 to 20 of 143
    Nov 2006
    Lonehill
    Thanked: 350
    Default D4: Low Battery Warning - "Please start vehicle" with CTEK
    So I bought a CTEK.....something I swore never to do.
    Reason I bought it is the D4 is parked 90% of the time and is only used for trips. Also my old R600 cheapie, no name brand charger has a fan on it which i was worried will burn out if run for weeks on end.
    Anyway, when the CTEK is connected I get a low battery warning on the dash asking me to start vehicle even with the voltage in the battery being correct. I never get this with the cheap no name brand charger. If I drive the vehicle for 1 or 2 kms after getting this warning and then leave the charger unplugged i dont get this low battery warning.
    Ive left the battery disconnected from the CTEK charger for longer than a week and even then I dont get this warning. The battery has been checked and even after a week its sitting in the high 12v's.
    As soon as I connect the CTEK charger again I get the warning on the dash even if the battery is not showing low voltage .
    The CTEK is a CTEK MXS 5.0 eight stage charger, 12V 5A
    Anyone have any ideas?
    Thank you
    BruceT
    ZS6EBT
    Defender 130 Puma
    Thanked: 13611
    Default Re: D4: Low Battery Warning - "Please start vehicle" with CTEK
    Thank you
    1) you should drive the D4 more
    2) leaving the oil to drain out of the crank bearings is playing russian roulette
    Aug 2015
    Whyalla
    Thanked: 47
    How are you connecting the charger to the vehicle?
    Nov 2006
    Lonehill
    Thanked: 350
    Quote Originally Posted by Tombie View Post
    Direct to the battery
    LOL @ Jelo
    Question about chargers and a battery and it becomes a crank issue. True to form bud....... haha
    BruceT
    ZS6EBT
    Defender 130 Puma
  5. The Following User Says Thank You to BruceT For This Useful Post:
    Apr 2011
    Thanked: 1055
    I've read somewhere (think it was in the Disco manual actually...) that the correct way of charging the Disco's battery with a charger is to connect the positive to the "+" terminal on the battery and to connect the negative terminal NOT to the battery but rather any "grounded point".
    Not sure this will actually make any difference though.....
    I also have a CTek and my D4 have never given this message when connected to CTek.
    PS...sure George will be here asap.
    Aug 2015
    Whyalla
    Thanked: 47
    Exactly "Regard"..
    The D3/4/RRS has a device in the -Ve lead which the vehicle uses to sense condition and regulate its energy.
    ANY device connected into one of these vehicles can take + from the battery, however the - MUST be connected to one of the plethora of Earth points on the vehicle NOT directly to the battery -.
    Thanked: 46
    Mine not a D4 but D3, and it is connected to my small Ctek (800ma) one for 5 days a week and then I drive on weekends and I have never had any error message displaying. My Ctek is connected directly to the positive and negative terminals on the battery.
    I wonder if the Ctek isn't faulty.
    Discovery 3 V8 SE
    Self designed Rock and Tree Sliders.
    Next: Project Bashplate
    1981 Series 3 S R6 88" Allmost Perfectly Restored
    Aug 2015
    Whyalla
    Thanked: 47
    Also, there was a software update for the charging system to prevent a known error.
    What year is the vehicle and has it had the update?
    krugersdorp
    Thanked: 540
    my kids have a camper thing, it has a huge c teck thing in it. i plug in the camper use jumper cables from the camper battery and connect it to my d4 battery and walk away, never had a problem, the light on the camper thing go down a few lights then go back to the top green one after leaving it connected.
    2010 d4 v8 hse hers
    2018 D/C CRUISER V8
    Aug 2015
    Whyalla
    Thanked: 47
    Being across the water - are your D4s delivered with the 12N and 12S trailer plugs?
    If not what type?
    I have a charging lead I made up that allows me to connect the Ctek to the trailer plug..
    Much cleaner and easier than having the bonnet up etc.
  12. The Following User Says Thank You to Tombie For This Useful Post:
  13. #11
    Apr 2011
    Thanked: 1055
    Doesn't the D4's have both 12? and 12S plugs? What is the difference between the black and white plug?
  14. #12
    Thanked: 2444
    The reason why chargers and jump starting uses a ground on the chassis is to avoid a spark close to the battery where flammable gasses may be.
    The low voltage may be due to the charger "loading" the battery to test it's condition before running a charging map.
    If it's easy to get to, just undo one of the poles and leave the charger straight on the battery.
  15. #13
    Nov 2006
    Lonehill
    Thanked: 350
    Thanks Regard and all. I will try connect as suggested and see if the fault continues.
    BruceT
    ZS6EBT
    Defender 130 Puma
  16. #14
    Thanked: 13611
    LOL @ Jelo
    I only need a SMALL gap
    Like SFA.
  17. #15
    Nov 2006
    Lonehill
    Thanked: 350
    That makes sense (the loading of the battery) but why do i still get the low voltage error after it being on charge for a week plus? Surely it should have completed the charging map?
    Wont be able to lock the vehicle with the battery disconnected.
    BruceT
    ZS6EBT
    Defender 130 Puma
  18. #16
    Thanked: 292
    Txs, you just gave me a great idea. I am gonna fit a Brad Harrison adaptor to my battery charger, and simply plug it into the BH plug on rear of my Disco which is connected straight to the battery anyway. No need to open the bonnet and battery cover anymore. BTW, ive got a D2, not a D4.
    2006 VW Touareg 4.2 V8 Auto
    2000 Disco 2 GS 4.6 V8 Auto
    2013 Wildebeest Kalfie Boswa
    2002 Audi S6 4.2 V8 quattro
    2013 Freelander SD4 (SWAMBO)
    ORRA Z07
  19. The Following User Says Thank You to TwinDisco For This Useful Post:
  20. #17
    Nov 2006
    Lonehill
    Thanked: 350
    Quote Originally Posted by TwinDisco View Post
    Thats what I used to do with my cheapie charger. Also do the same when using solar power.
    Some replies I got on Disco3 for future reference:
    Dudleydisco wrote:
    If you use the -ve terminal of the battery rather than a chassis ground, then the BMS doesn't register the charge you're putting onto the battery. This can give you all sorts of problems
    dgardel wrote:
    Yes correct, the charger/maintainer connected directly mislead the BMS; your battery is fully charged but the BMS still "think" that the battery charge is always as before, unchanged.
    BruceT
    ZS6EBT
    Defender 130 Puma
  21. #18
    Thanked: 451
    Hi BruceT
    yes the negative terminal of the comfort connect plug MUST be connected to an earth point. There are a few of them around the battery area. That way you won't experience any issues.
    This BTW is how to connect long term maintenance chargers to vehicles with lots of electronics and "smart alternators". All our modern cars have their leads connected like that. Never had an issue.
    Try it that way and I am sure it will be ok. If not check if you have auxiliary equipment added to the vehicle, which may interfere due to incorrect wiring.
    Let us know the outcome please.
    good luck!
    George Bosch
    Distributor for:
  22. The Following User Says Thank You to hgbosch For This Useful Post:
  23. #19
    Thanked: 988
    OK - D3 older technology
    I have a Brad Harrison on my front bumper connected directly to the battery via a fuse.
    Use this where I need power for compressor etc, have also connected my charger here, not a fancy, clever one though, and have never had any issues.
    Stay Safe
    Disco-Deon
    This morning I woke up,
    Making today a great day.
    Nerdy, 2011 Honda Jazz, 1500 Exc
  24. #20
    Aug 2015
    Whyalla
    Thanked: 47
    Not on these vehicles it isn't.
    The charging and engine management profiles are measured via the negative lead to the battery (there is a processor in there).
    The vehicle cannot measure its power reserves or demands if you go directly to the battery.
    If you do as I mentioned and connect Charger Pos to Battery Pos and Charger Neg to the Earth point directly in front of the battery box it will work perfectly.
  25. The Following 2 Users Say Thank You to Tombie For This Useful Post:
