Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 45
    Thanked: 7
    Default Sani Pass in a 2x4?
    Hi all,
    Thinking of doing Sani Pass next weekend. Is it manageable in a 2x4 if it is dry?
    I believe its tarred to just past the border? But the actual pass is still dirt...
    Thanks,
    There is a place, like no place on earth.
    Thanked: 119
    Default Re: Sani Pass in a 2x4?
    No..no its not
    Langs die rivier, op n berg
    Thanked: 3665
    Quote Originally Posted by Dustbin View Post
    No..no its not
    Not dirt anymore? So doable in 4x2? 4x2 met difflock is mos dieselfde as 4x4... Beide trek teoreties in 2 wiele...
    Feb 2015
    Thanked: 36
    Hi, it is very do-able in a 2x4 if dry. Seen a Ford Kuga with low profiles go up.... lots of noise from the undercarriage and it is an AWD though.
    Tae note though that there is a sign board prohibiting vehicles un-equipped with 4 wheel drive from going up the pass. I don't now how strongly this law is applied but I wouldn't take a chance.
    Thanked: 119
    Dis nog dirt... die pas, van die hek af.. is nof grondpad.
    Die laaste 150m tot bo, is nie jou maat nie.... en kan net gedoen word met n 4x2 as jy weet wat jy doen. En.....
    Dis eintlik nog winter....
    Thanked: 3665
    Wat ek eindlik bedoel het...
    Thanked: 311
    Quote Originally Posted by scotty780925 View Post
    Yup they do enforce the 4x4 bit .Sometimes they come out to check what kind of vehicle you drive .No 4x4 no drive the Pass
  8. The Following User Says Thank You to smarty For This Useful Post:
    Oct 2012
    Thanked: 22
    A new VW dune went up last week. So, a 4x2 should be fine.
    Ex:07 Disco 3 TDV6 SE
    2011 Disco 4 SDV6 SE
    Sinoville Pretoria
    Thanked: 650
    Stay away in your 2x4. What about Icy Corner?
    I've seen an @#$hole in a 2x4 who could not even approach Icy Corner, never mind negotiating bend itself. He eventually gave up and went home after constituting a danger to other road users. If you have a 2x4 stay on tarred roads and standard dirt roads, stay away from Sani , sand etc.
    IMHO a diff lock is for uneven rocky terrain only, and at slow speed. I tested my Prado on Mozzie beach once with diff lock. Makes vehicle utterly useless in sand and very difficult, if not impossible to make a u- turn on beach. Heard and felt severe strain on rear axle
    En as jy met groot honde loop moet jy jou been hoog lig
    Henk Pretorius D4 3,0 SDV6 HSE
  11. The Following User Says Thank You to julius caesar For This Useful Post:
    Nov 2014
    Thanked: 2411
    You might make it up, but coming down without low range is going to cook your brakes and be dangerous. The berg weather is also notoriously fickle, if it starts a little early summer storm you're well stuffed.
    You're also going to do some environmental damage from wheel spin and sliding, not to mention damaging the vehicle. It's not the law you need to consider first.
  13. The Following User Says Thank You to Gungets Tuft For This Useful Post:
  14. #11
    Wartburg
    Thanked: 2393
    If you know your 4x2, you should be able to do it when the pass is in relative good nick.
    But not allowing 4x2s should be more strongly enforced than it is, as even with rear difflock there is lot's of wheel spin, stuffing up the pass. Also, the lack of low range forces you to go way too fast if you don't ride your clutch.
    The first time we went up many years ago our slow moving convoy was passed at icy corner by a 4x2 bakkie, in first gear, wheels spinning, rocks flying and bouncing heavily. Seeing this made it crystal clear why they should not be allowed on the pass.
    Mike Lauterbach
  15. #12
    Thanked: 22
    Is there a rule that you must have 4x4 to go down Sani pass?
    AMAROK
    BLINKGAT ALU CANOPY
    JURGENS EXPLORER
    BLINKGAT DRAWER SYSTEMS AND FRIDGE SLIDE
  16. #13
    Dec 2009
    Gordon's Bay
    Thanked: 4378
    Quote Originally Posted by Fanatic View Post
    as far as I know, it's still a rule that you must have 4x4 to do the pass.
    Whether this is actually enforced in any way, I cannot say.
  17. #14
    Jul 2009
    Thanked: 568
    One guy did it in his Cobra, in snow I think.
  18. #15
    Aug 2015
    Maseru
    Thanked: 53
    It's a rule but it's not enforced, they have never checked our vehicles when going through there
    Old man- 2011 Toyota Land Cruiser 200 VX 4.6 V8
    Boss lady - 2012 Toyota 150 Prado D4D
    Young me - 2009 underpowered Corolla 1.4 professional
    Free for all - 2000 BMW 528i
  19. #16
    Dec 2009
    Gordon's Bay
    Thanked: 4378
    Quote Originally Posted by XJ Junkie View Post
    we did it on the Sheild in 1998 in various 2WD cars, all pre 1975. Mercs, Porsches, Peugeots, Escorts, Mustangs,
    It was legal as it was done with permission.
    it's more than doable most of the time , although I wouldn't like to do it in icy wet conditions in anything less than a decent 4x4, I do have a friend who managed to go off the edge and roll a **few** times down the steep and nasty bit.
    whether it's legal or not I can't say, which would obviously affect insurance etc.
  20. #17
    Nov 2014
    Thanked: 2411
    It is still a rule but I've never been checked, unless the border oke can see into the car park from his office. A really low vehicle will be caught 100m in the drag at the causeway.
    Waterfall bend nothing like it used to be - the attached was 2 weeks ago, lots of work done to keep the water off the road.
  21. #18
    Aug 2011
    Thanked: 73
    From Lesotho side, tarred up to the Lesotho customs. From Himeville, tarred up to the old trade post before the SA customs. The pass itself has been widened in some areas making it easier. This past weekend, traffic was quite heavy. Number of Taxi's up and down in various shapes an sizes. From 4x4 Hi-Ace, to what appears to be standard Quantum's. All taxi's were LOADED and the standard ones had to "run" the pass keeping momentum, could not stop and hooted at slow traffic ahead:-). The 4x4 taxi's appeared to have a Low gear and handled the uphill better.
    There was also an Ecosport that made it to the top.
    In summary: Yes it can certainly be done. Would I do it, with a vehicle other than a 4x4? Certainly not. I do not think anyone will guarantee that one would not damage your vehicle. Even in the areas at the bottom of the pass, there places where one would have to be careful and decent clearance would be nice. There are oil slicks on some rocky areas and also bits of Tupperware strewn in places - pieces of grills, bumpers etc. The weather can change in a flash, and being caught in a storm halfway up the pass would be very risky - especially if one is already aware of possible dangers.
    Latest Google earth is accurate as far as the tarred areas are concerned as well as the areas which have been widened.
  22. #19
    Greenstone Hill
    Thanked: 122
    Went down 3 weeks ago - here's a video (4x speed)
    Mark Trollope
    Prado 120 V6, Fortuner V6, Hilux 2.7, Cruiser 80 EFi, Cruiser 75, Lexus RX350, Rav4 GX, Jaguar JAKI4
  23. The Following 2 Users Say Thank You to Mark Trollope For This Useful Post:
  24. #20
    Aug 2010
    Centurion, Pretoria
    Thanked: 107
    Also went up Sani a few weeks back.
    Pass looks good, but will not do it in a 2x4...
    2011 Freelander 2 SD4 HSE AT.
    2016 Campmaster Compact 100 trailer.
