Anyone removed the dashboard of a 2004 Nissan Hard body?
Results 1 to 5 of 5
    Oceans247 Guest
    Default Anyone removed the dashboard of a 2004 Nissan Hard body?
    I have a problem with a fitting below the radio. If only it was a Land rover, then no doubt the screws would be visible, but I don’t know where to start.
    It is the controls to my air suspension. One of the lights in the dial has blown and also i think there is an airleak behind the fitting.
    Gaborone, Botswana
    Thanked: 960
    Start looking at the bottom... remove the ash-tray and look in there.
    I removed the centre console on my older model once. There are onlly a few screws, and then it lifts up and clips out.
    Kobus
    Nissan
    Oceans247 Guest
    I managed it, it seems all I needed was some brute force and 2 screws.
    Nov 2011
    Hey chaps. Massively old thread, but my dashboard fan has stopped working as well as the warning alarm when leaving the lights on .
    Could you shed some more light on how to remove that central panel?? I removed the screws, but I'm weary to apply said brute force.. I'm notoriously good at breaking things!
    Klerksdorp
    remove the 2 screws above the fan/heating panel and the 2 ashtrays and put your fingers in the ashtray holes and pull with a "lekker ruk". should then just pop off.... taken the console out a few times on my bakkie
    "Blue Thunder"
    Gert Ferreira
  1. Replies: 6
    Last Post: 2011/07/18, 11:46 AM
  2. Advise Toyota vs Nissan Hard Body
    By RudiKruger in forum Toyota
    Last Post: 2010/07/21, 07:33 PM
  3. Nissan Quality Control
    By Stevh0 in forum Nissan
    Last Post: 2009/09/21, 02:02 PM
  4. Nissan Hard Body Recovery Point
    By Hansie in forum 4x4 Recovery & Recovery Gear
    Last Post: 2008/06/09, 09:26 AM
