Defender 17/18 inch rims and tires
Results 1 to 12 of 12
    Apr 2016
    Default Defender 17/18 inch rims and tires
    Hi guys,
    what at complexities are there if any going to a 17 or 18 inch rim on a 110 Defender (2007 model). The vehicle has a 50mm lift and 30mm wheel spacers/adapters.
    im currently on 16 inch rims and accidentally ordered a VERY expensive set of 17/18 inch, 6-pot brakes for the front from the UK. Unfortunately, I thought I was running 17's and ordered the brakes while my LR was at my mechanic having a Lexus V8 put in...
    i would obviously try sell my 16's with tires then to recover some costs on new rims/tires.
    Stellenbosch/Plett
    Thanked: 58
    Default Re: Defender 17/18 inch rims and tires
    It depends, what size tyres are you looking at putting on those rims? Since you've got a lift and spacers already, why not put on some 285/70R17's? You will still have enough profile to air down quite a bit when off-roading, and the Defender will look nice with the larger than standard tyres.
    2009 Land Rover Defender 110 Station Wagon - finally found its set of 35s
    2012 BMW R1200GS Adventure
    Apr 2016
    That's about the size I'd be looking at, struggling to find many 17 inch rim options though.
    Stellenbosch/Plett
    Thanked: 58
    Quote Originally Posted by shauncooper View Post
    Have you considered steel rims? Or are you specifically wanting alloys?
    Apr 2016
    No, I think alloy is a must for me.
    Thanked: 119
    Won't Disco rims fit?
    Thanked: 119
    Or Ranger Rover Rims..
    He He... Saying it sounds funny..
    Dec 2009
    Melkbosstrand
    Thanked: 427
    Old Disco (D1) and Range Rover (Classic) rims will fit but aren't available bigger than 16"
    The modern stuff has different PCD
    Only alloy solution is to get a new set of adapters made with a new PCD and centre bore. I would suggest going for the BMW 5/120 pattern which will allow most big LR wheels to fit. Alternatively you could fit D2 axles (not a straight bolt in though) which are apparently a bit tougher as well.
    I would avoid using car mags unless it will never go offroad as they are not designed to handle the impacts of offroading.
    D2 18" rims are pretty easy to find and not too expensive. I think D3 is 5/120 as well.
    Rob
    Series IIA 88" pickup
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Apr 2016
    Thanks for the suggestions.
    I wasn't aware I could get an adapter that could modify the pcd, I'll look into that.
    Apr 2016
    Adapters not cheap, that's for sure as I can't find any in SA. Cheapest I have seen is around 300GBP before shipping and customs duty charges...
    Dec 2009
    Melkbosstrand
    Thanked: 427
    You don't import an adapter made by an overpaid British workman in between his hourly tea breaks
    You get them made locally. Lump of alloy and a bit of lathe and milling time.
    They're not cheap but not GBP300 either.
    Rob
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Apr 2016
    Do you have somebody you could recommend to make some up, I'm in East London and workmanship, not to mention service standards, are not quite up to scratch here...
