Trailblazer wiring for trailer
Results 1 to 9 of 9
    Amorosa
    Thanked: 309
    Default Trailblazer wiring for trailer
    Has anybody added wiring to charge a 2nd battery or the battery in your trailer?
    How did you connect to the battery?
    Thinking of adding it to my trailblazer just incase.
    Bush Lapa Miskruier 586
    Amorosa
    Thanked: 309
    Default Re: Traimblazer wiring for trailer
    Spelling mistake. Should be trailblazer. How can I fix it?
    Aug 2015
    Melkbosstrand
    Thanked: 29
    Default Re: Trailblazer wiring for trailer
    Hi Bogaards,
    I did my Brad Harisson connection at Safari 4x4 Cape Town. The plug fits right next to normal towbar plug. I plug my camper trailer in while towing it and it charges the trailer battery all the time, no issues and works like a charm.
    2014 Chevrolet Trailblazer 2.8 Auto 4x4
    2015 Jurgens XT140 Ext... maar ek soek 'n Bush Lapa
    Who needs a diff lock if you have 500Nm's
    Amorosa
    Thanked: 309
    Thanks, how does it connect to the battery?
    Aug 2015
    Howick
    Thanked: 28
    Had a look at ours and the BH negative connects to the body next to the battery on a nut that also connects to the battery negative.
    The BH positive is fastened onto the top of the thingy that attaches to the positive( under the red plastic cover). The BH positive wire looks like it has an in-line fuse just next to the battery.
    Brackenfell
    Thanked: 200
    Mine connects in the exact same manner except I do have a fuse just after the main battery in the engine compartment.
    Uys Snyders
    Trailblazer 2.8DuraMax
    Bushlapa Vlooi B237
    Amorosa
    Thanked: 309
    Can you maybe post photos please?
  8. The Following User Says Thank You to Bogaards For This Useful Post:
    Aug 2015
    Howick
    Thanked: 28
    Pics below. Yellow scribble is negative. Red scribble is positive. You can see the in line fuse on the positive cable just before it connects to batt. Excuse the filthy engine compartment.
ID:	414451   Click image for larger version.
    Amorosa
    Thanked: 309
    Dankie
