Tyre pressure for AT tyres
Results 1 to 13 of 13
    Aug 2015
    Gaborone
    Thanked: 44
    Default Tyre pressure for AT tyres
    Hi guys. I recently bought a set of Goodyear Wrangler AT tyres for my 2001 RAV4 AWD - size 215/70R16.
    The guys at the tyre shop pumped them up to an "ideal" 2.2 bar. When I asked them what would be the lowest I could deflate them to for off-road driving, they said I shouldn't go less than 1.8 bar.
    My first question is whether that is really the lowest I can/should go when deflating and will that (small) difference have any effect at all on my grip in sand, on gravel etc.? I've heard that guys driving proper 4x4's with larger tyres go down to about 1 or even 0.8 (any less and the tyre may actually come off the rim), but can I not go that low with my tyres as well and what would indeed be the lowest I could/should go when tackling sand, gravel etc.?
    My second question is when should the tyre pressures differ between the front and back tyres? i.e. if I'm full-laden at the back, should the back tyre pressure be considerably higher than the front (and if so, why?) or should they more or less be kept the same?
    Any info on the matter would be appreciated, thanks. Jovan
    1999 Toyota Prado TZ, 3.4L, V6, petrol, auto
  2. The Following User Says Thank You to Jovan Djokic For This Useful Post:
    swakopmund
    Thanked: 1310
    Default Re: Tyre pressure for AT tyres
    They are clueless regarding tyres , shocking advice to give a client. a "70" profile can safely be deflated to 0.8 in soft sand , if he means gravel road the 1.8 would be ok, but very strange behaviour
  4. The Following User Says Thank You to Bartho For This Useful Post:
  5. #3
    Thanked: 498
    With your 70 profile AT tyre you could easily go down to 1.2(F) and 1.4(R) for rough gravel. It makes a world of difference if, as an example, you are driving in Kgalagadi on some badly corrugated sections. Just keep your speed below 80 at all times, preferably below 70.
    For relaxed sand driving even 0.7 is OK, but...
    Don't make any sharp turns or the tyres will debead.
    Eggie.
    - apology to Edward Langley.
  6. The Following User Says Thank You to Eggie For This Useful Post:
  7. #4
    Thanked: 371
    I am a Good Year Wrangler man for many moons. My tyre pressure for gravel is normally between 1.6 and 1.8, depending on the road. Driven a few thousand kilos on Nam gravel, and the well known Kgalagadi hoppers, even went as low as 1.2.
    Pajero GLS Exceed 2014 LWB &
    Jeep Cherokee 2001 2.5 Diesel, Gone to Jeep Heaven
    Toyota Hilux, plaas bakkie
    Platkar Swambo's MB
  8. The Following User Says Thank You to stevan For This Useful Post:
  9. #5
    Thanked: 34
    Have wranglers on my suzuki. Normal road pressure is 1.8. Dunes is 0.5-0.8. They are 245/70/16.
    2009 Toyota Fortuner Epic V6
  10. The Following User Says Thank You to faanie For This Useful Post:
  11. #6
    Aug 2015
    Gaborone
    Thanked: 44
    Thanks guys for the input! It did seem strange when the tyre-shop guy said "no lower than 1.8", but that's why this forum exists, to provide the answers that the "professionals" cant!
    Can't wait to test my Wranglers out on some sand and "horrible" gravel roads! A trip to Tuli Block in Botswana in September is already on the cards which will be a good starting point. Then SWAMBO and I are planning a 12-day roadtrip from Gaborone up to Kasane via Tuli-Gweta-Maun in December, and then the tyres will really show what they are made of!
    Thanks again for all the input!
    Cheers,
    Jovan
  12. #7
    Mar 2011
    Walker Bay
    Thanked: 1021
    I drive with 1,3 in Kgalagadi with the Suzuki and would be quite happy to go down to 1.1
    Even when they deliver a new car you find the tyres pumped to 2.6. Crazy!
  13. #8
    Aug 2010
    Thanked: 47
    On tar road AT Tyres are correct at about 2.4-2.5 it gives the correct road contact surface and allows correct sidewall support for speed.
    On on dirt roads smooth 1.8 is good.
    Corrugated 1.4-1.6 allows for directional control, during oscillation of the suspension
    soft sand and beach 0.8-1.2 will allow for floatation on the surface and provide an elongated tread surface contact area much like a small tank track.
    It is always not advisable to drive on a hard surface at too low a pressure at speed, the heat build up will damage the tyre.
  14. The Following User Says Thank You to hedjudd For This Useful Post:
  15. #9
    Cape Town or Jansenville or missing...
    Thanked: 3060
    We owned a RAV for 340 000km on mostly bad gravel, 1.8 seemed a good all round pressure. Brilliant vehicle.
    I'd say drop to 1.2 for trails, 0.8 for sand, no worries.
  16. #10
    Jeffreys Bay
    Greetings,
    Interesting chat on the AT tyres. I used to drive a Ford Ranger 4x4 with Goodyear AT Tyres. I now have built my own camper into a Hyundai H1 Panel Van and fitted Goodyear AT tyres. I no longer have 4x4, but the Hyundai is rear driven. We love to go to Kgalagadi and Namibia and have done a lot of gravel driving there. I intend to lower pressure to 1.6 in Kgalagadi and Namibian gravel. If I come across some sandy drifts on Namibian gravel routes should I lower the pressure even more to get through? Or will I be okay with 1.6? Should the drive wheels (rear) have a lower pressure in sand than the front free wheeling wheels? Thanks for any info on this.
  17. #11
    Thanked: 498
    Quote Originally Posted by Punda View Post
    Greetings,
    It does not sound as if you will need to go lower than your suggested 1.6.
    Should you hit a "really" bad road, drop to 1.4 for more comfortable driving.
    If you get stuck in sand, just don't dig in - stop. Lower tyres to 0.8 all round to get out and get through. It is amazing what one can get away with, even with 2x4. Do pressure up before driving off again.
    What is the profile no of the tyres?
    Eggie.
  18. #12
    Jeffreys Bay
    Thanks Eggie, my tyres are 215/70/16.
  19. #13
    Thanked: 498
    Good. A 70 profile leaves quite a bit for gravel & sand.
    They will serve you well for what you intend to do.
    Eggie.
  20. The Following User Says Thank You to Eggie For This Useful Post:
